[PATCH rtems-docs v2 3/6] rtems-docs: Edit command to install toolsuite
Ida Delphine
idadelm at gmail.com
Thu Mar 18 02:42:36 UTC 2021
I just installed texlive and trying to do a top level build using ./waf
configure. But looks like it doesn't work well...I get this error at the
end:
Setting top to :
/home/idadel/Desktop/gsoc/docs/rtems-docs
Setting out to :
/home/idadel/Desktop/gsoc/docs/rtems-docs/build
Checking for program 'git' : /usr/bin/git
Checking for program 'sphinx-build' :
/home/idadel/anaconda3/bin/sphinx-build
Checking for program 'aspell' : /usr/bin/aspell
Checking if Sphinx is at least 1.3 : yes (3.5)
Checking Sphinx Options : none
Checking Sphinx Nit-Pick mode : no
Checking for 'sphinx.ext.autodoc' : found
Checking for 'sphinx.ext.coverage' : found
Checking for 'sphinx.ext.doctest' : found
Checking for 'sphinx.ext.graphviz' : found
Checking for 'sphinx.ext.intersphinx' : found
Checking for 'sphinx.ext.mathjax' : found
Checking for 'sphinxcontrib.bibtex' : not found (see README.txt)
The configuration failed
(complete log in /home/idadel/Desktop/gsoc/docs/rtems-docs/build/config.log)
On Wed, Mar 17, 2021 at 9:37 PM Ida Delphine <idadelm at gmail.com> wrote:
> Ok, I will do that.
> On Tue, Mar 16, 2021 at 7:56 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Tue, Mar 16, 2021 at 12:16 PM Ida Delphine <idadelm at gmail.com> wrote:
>> > I ran the commands and copied and pasted wherever there were mismatches
>> especially with respect to the version numbers.
>> OK, I noticed some inconsistencies and was wondering. It would be
>> better to provide the actual output for the entire snippets, see
>> further below what I noticed.
>> > Should I resend the patchset with a better commit message?
>> Yes. I think it would be better to also update the entire output
>> examples, and to separate them from the manual changes you make to the
>> version numbers. In other words, update the version numbers by hand
>> for some things, and update the console output examples separately.
>> You can put multiple changes together in one patch that are related,
>> for example you might just send one patch with all the console output
>> example updates.
>> > On Tue, 16 Mar 2021, 6:50 pm Gedare Bloom, <gedare at rtems.org> wrote:
>> >> Hi Ida,
>> >> Since the patches now indicate rtems-docs, you don't need to include
>> >> that in the commit message. Instead, it is recommended to put the
>> >> manual directory name that is modified as the first part of the
>> >> commit, e.g., "user: bump version 5 to 6 in start/tools.rst"
>> >> More below:
>> >> On Tue, Mar 16, 2021 at 2:16 AM Ida Delphine <idadelm at gmail.com>
>> wrote:
>> >> > Edit edit sample output of tool suite installation.
>> >> > Edit command to check if C cross compiler works and sample output of
>> this command.
>> >> > user/start/tools.rst | 26 +++++++++++++-------------
>> >> > 1 file changed, 13 insertions(+), 13 deletions(-)
>> >> > diff --git a/user/start/tools.rst b/user/start/tools.rst
>> >> > index baa2387..9a915ab 100644
>> >> > --- a/user/start/tools.rst
>> >> > +++ b/user/start/tools.rst
>> >> > @@ -12,7 +12,7 @@ Install the Tool Suite
>> >> > You have chosen an installation prefix, the BSP to build, the tool's
>> >> > architecure and prepared the source for the RSB in the previous
>> sections. We
>> unrelated, fix typo: architecture
>> >> > -have chosen :file:`$HOME/quick-start/rtems/5` as the installation
>> prefix, the
>> >> > +have chosen :file:`$HOME/quick-start/rtems/6` as the installation
>> prefix, the
>> >> > ``erc32`` BSP and the SPARC architecture name of ``sparc-rtems5``,
>> and unpacked
>> >> > the RSB source in :file:`$HOME/quick-start/src`.
>> >> > @@ -25,7 +25,7 @@ Build and install the tool suite:
>> >> > .. code-block:: none
>> >> > cd $HOME/quick-start/src/rsb/rtems
>> >> > - ../source-builder/sb-set-builder
>> --prefix=$HOME/quick-start/rtems/5 5/rtems-sparc
>> >> > + ../source-builder/sb-set-builder
>> --prefix=$HOME/quick-start/rtems/6 6/rtems-sparc
>> >> > This command should output something like this (omitted lines are
>> denoted by
>> >> > ...). The build host appears as part of the name of the package
>> being
>> >> > @@ -33,19 +33,19 @@ built. The name you see may vary depending on
>> the host you are using:
>> >> > - RTEMS Source Builder - Set Builder, 5.1.0
>> >> > - Build Set: 5/rtems-sparc
>> >> > + RTEMS Source Builder - Set Builder, 6
>> >> > + Build Set: 6/rtems-sparc
>> >> > config: tools/rtems-binutils-2.34.cfg
>> >> > - package: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
>> >> > - building: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
>> >> > - sizes: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1:
>> 305.866MB (installed: 29.966MB)
>> >> > - cleaning: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
>> >> > + package: sparc-rtems6=-binutils-2.34-x86_64-freebsd12.1-1
>> The = sign here is what got me thinking something odd is going on.
>> Please copy-paste the entire output/snippet you get, and update the
>> examples completely so that each snippet is self-consistent at least.
>> >> > + building: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1
>> >> > + sizes: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1:
>> >> > + cleaning: sparc-rtems6-binutils-2.34-x86_64-freebsd12.1-1
>> >> > reporting: tools/rtems-binutils-2.34.cfg ->
>> sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.txt
>> sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.xml
>> >> > config: tools/rtems-gcc-7.5.0-newlib-fbaa096.cfg
>> >> > - package:
>> sparc-rtems5-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
>> >> > - building:
>> >> > + package:
>> sparc-rtems6-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
>> >> > + building:
>> >> > Build Sizes: usage: 5.684GB total: 1.112GB (sources: 143.803MB,
>> patches: 21.348KB, installed 995.188MB)
>> >> > Build Set: Time 0:21:35.626294
>> >> Did you run the command and capture the sample output, or do you edit
>> >> the sample output manually?
>> >> It would be better to copy-paste the actual sample output. Making this
>> >> version change update automatic could be a nice small scripting
>> >> exercise.
>> >> > @@ -55,7 +55,7 @@ works with the following command:
>> >> > - $HOME/quick-start/rtems/5/bin/sparc-rtems5-gcc --version
>> >> > + $HOME/quick-start/rtems/6/bin/sparc-rtems6-gcc --version
>> >> > This command should output something like below. The version
>> informtion helps
>> >> Unrelated, but can you fix this typo: information
>> >> > you to identify the exact sources used to build the cross compiler
>> of your
>> >> > @@ -69,8 +69,8 @@ source code used.
>> >> > - sparc-rtems5-gcc (GCC) 7.5.0 20191114 (RTEMS 5, RSB 5.1.0,
>> Newlib fbaa096)
>> >> > - Copyright (C) 2017 Free Software Foundation, Inc.
>> >> > + sparc-rtems6-gcc (GCC) 10.2.1 20210309 (RTEMS 6, RSB
>> 5e449fb5c2cb6812a238f9f9764fd339cbbf05c2, Newlib d10d0d9)
>> >> > + Copyright (C) 2020 Free Software Foundation, Inc.
>> >> > This is free software; see the source for copying conditions.
>> There is NO
>> >> > warranty; not even for MERCHANTABILITY or FITNESS FOR A
>> PARTICULAR PURPOSE.
>> >> > 2.25.1
>> >> > _______________________________________________
>> >> > devel mailing list
>> >> > devel at rtems.org
>> >> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210318/d1c42bca/attachment.html>
