[PATCH 2/3] Changed variable type to fix AARCH64 test issues
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Mar 18 20:59:43 UTC 2021
Yes, a different fix for this went in a couple weeks back. This patch needs to be dropped from the set.
Kinsey
From: devel <devel-bounces at rtems.org> On Behalf Of Joel Sherrill
Sent: Thursday, March 18, 2021 15:57
To: Gedare Bloom <gedare at rtems.org>
Cc: devel at rtems.org
Subject: Re: [PATCH 2/3] Changed variable type to fix AARCH64 test issues
On Thu, Mar 18, 2021 at 3:53 PM Gedare Bloom <gedare at rtems.org<mailto:gedare at rtems.org>> wrote:
I've lost some context, but wasn't this already addressed?
https://lists.rtems.org/pipermail/devel/2021-March/065021.html
Ryan .. is this a case where the internal tree fixed it one way and
Sebastian fixed it another? Perhaps Sebastian fixed it while this
patch was queued up to go out.
Does aarch64 give a warning or fail without this patch? If not,
then this patch probably isn't needed.
Although I think size_t is probably the right type for this. Please check
that the test has an issue on the master without this patch.
On Thu, Mar 18, 2021 at 2:27 PM Ryan Long <ryan.long at oarcorp.com<mailto:ryan.long at oarcorp.com>> wrote:
> Changed maximum_pending_messages to type size_t to fix the
> ts-validation0 test.
> cpukit/include/rtems/rtems/message.h | 2 +-
> cpukit/include/rtems/score/coremsgimpl.h | 2 +-
> cpukit/score/src/coremsg.c | 2 +-
> testsuites/validation/tc-message-construct-errors.c | 2 +-
> 4 files changed, 4 insertions(+), 4 deletions(-)
> diff --git a/cpukit/include/rtems/rtems/message.h b/cpukit/include/rtems/rtems/message.h
> index 14083b8..7bb48ba 100644
> --- a/cpukit/include/rtems/rtems/message.h
> +++ b/cpukit/include/rtems/rtems/message.h
> @@ -51,7 +51,7 @@ typedef struct {
> * @brief This member defines the maximum number of pending messages supported
> * by the message queue.
> - uint32_t maximum_pending_messages;
> + size_t maximum_pending_messages;
> * @brief This member defines the maximum message size supported by the message
> diff --git a/cpukit/include/rtems/score/coremsgimpl.h b/cpukit/include/rtems/score/coremsgimpl.h
> index 6f6a01b..c7a424c 100644
> --- a/cpukit/include/rtems/score/coremsgimpl.h
> +++ b/cpukit/include/rtems/score/coremsgimpl.h
> @@ -144,7 +144,7 @@ void *_CORE_message_queue_Workspace_allocate(
> Status_Control _CORE_message_queue_Initialize(
> CORE_message_queue_Control *the_message_queue,
> CORE_message_queue_Disciplines discipline,
> - uint32_t maximum_pending_messages,
> + size_t maximum_pending_messages,
> size_t maximum_message_size,
> CORE_message_queue_Allocate_buffers allocate_buffers,
> const void *arg
> diff --git a/cpukit/score/src/coremsg.c b/cpukit/score/src/coremsg.c
> index cf7f44e..530f057 100644
> --- a/cpukit/score/src/coremsg.c
> +++ b/cpukit/score/src/coremsg.c
> @@ -35,7 +35,7 @@ RTEMS_STATIC_ASSERT(
> const void *arg
> diff --git a/testsuites/validation/tc-message-construct-errors.c b/testsuites/validation/tc-message-construct-errors.c
> index 3512b45..170b687 100644
> --- a/testsuites/validation/tc-message-construct-errors.c
> +++ b/testsuites/validation/tc-message-construct-errors.c
> @@ -338,7 +338,7 @@ static void RtemsMessageReqConstructErrors_Pre_MaxPending_Prepare(
> * configuration shall be big enough so that a calculation to get the
> * message buffer storage area size overflows.
> - ctx->config.maximum_pending_messages = UINT32_MAX;
> + ctx->config.maximum_pending_messages = SIZE_MAX;
> break;
> 1.8.3.1
> devel mailing list
> devel at rtems.org<mailto:devel at rtems.org>
devel mailing list
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210318/cf27c833/attachment-0001.html>
