rtems-test not running tests for leon3
Ryan Long
ryan.long at oarcorp.com
Tue Mar 23 14:07:21 UTC 2021
Hi,
I've been trying to run the tests for leon3, but the only test that runs properly is the minimum test. All of the others produce output like so in the log file.
[334/597] p:0 f:0 u:0 e:0 I:0 B:0 t:0 L:0 i:329 W:0 | sparc/leon3: nsecs.exe
Result: invalid Time: 0:00:02.754956 nsecs.exe
=> gdb: /home/rlong/rtems-work/tools/bin/sparc-rtems6-gdb -i=mi --nx --quiet rtems/build/sparc/leon3/testsuites/samples/nsecs.exe
=> Reading symbols from rtems/build/sparc/leon3/testsuites/samples/nsecs.exe...
=> target sim -leon3
=> Undefined target command: "sim -leon3". Try "help target".
=> quit
Does anyone know how to run these?
And should I file a ticket for this and fix it in rtems-test?
Thanks,
Ryan
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210323/b3784b88/attachment-0001.html>
