rtems-test not running tests for leon3
Richi Dubey
richidubey at gmail.com
Tue Mar 23 14:18:56 UTC 2021
Afaik minimum tests are supposed to fail.
On Tue, Mar 23, 2021 at 7:37 PM Ryan Long <ryan.long at oarcorp.com> wrote:
> Hi,
> I’ve been trying to run the tests for leon3, but the only test that runs
> properly is the minimum test. All of the others produce output like so in
> the log file.
> [334/597] p:0 f:0 u:0 e:0 I:0 B:0 t:0 L:0 i:329 W:0 |
> sparc/leon3: nsecs.exe
> Result: invalid Time: 0:00:02.754956
> nsecs.exe
> => gdb: /home/rlong/rtems-work/tools/bin/sparc-rtems6-gdb -i=mi --nx
> --quiet rtems/build/sparc/leon3/testsuites/samples/nsecs.exe
> => Reading symbols from
> rtems/build/sparc/leon3/testsuites/samples/nsecs.exe...
> => target sim
> -leon3
> => Undefined target command: "sim -leon3". Try "help
> target".
> => quit
> Does anyone know how to run these?
> And should I file a ticket for this and fix it in rtems-test?
> Thanks,
> Ryan
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210323/e87d3932/attachment.html>
