[PATCH v4] cpukit/aarch64: Add ESR register decoding
Gedare Bloom
gedare at rtems.org
Tue Mar 23 16:03:33 UTC 2021
On Tue, Mar 23, 2021 at 9:57 AM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Mar 23, 2021 at 10:49 AM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> Hello Alex,
>> this file has little in common with the RTEMS coding style. This is
>> quite understandable since the style is very exotic. I don't think we
>> will have a formatting tool which is able to produce the RTEMS style in
>> the near future. This gives raise to some general questions.
>> 1. Do we care about the coding style?
> Yes.
>> 2. Who wants to enforce the coding style?
> I hope we all catch these when we spot them.
> Alex will reformat it.
>> 3. Should new files use a new style understood by a well known tool and
>> a well known coding style?
> That would be preferable but like the license change and SPDX markers, this
> is down the list.
> You have something that is close. If you want to add it to rtems-tools as a starting
> point that is accessible, we can start to use it and see how it goes.
>> I see a lot of
>> type var = initial_value;
>> Maybe we should drop the stone age variable declarations at block begin
>> if we choose a new style and declare and initialize local variables upon
>> first use.
> I don't know when this was started but it was never part of the original
> RTEMS style.
> Personally I have never liked it.
It is a holdover from K&R and the gcc -ansi flag would complain if you
didn't do it. (For older compiler writers, it made it a lot easier to
parse and generate the code if you could pass over all the stack
allocations in one group.)
> --joel
>> embedded brains GmbH
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.huber at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
