[PATCH v1 0/2] [libbsd] Install correct machine include headers
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Mon May 31 07:29:41 UTC 2021
Ping :)
> -----Original Message-----
> From: Gedare Bloom <gedare at rtems.org>
> Sent: Monday, May 10, 2021 10:55 PM
> To: Sommer, Jan <Jan.Sommer at dlr.de>
> Cc: devel at rtems.org
> Subject: Re: [PATCH v1 0/2] [libbsd] Install correct machine include headers
> I can't review these currently, just want to put a note out there.
> Hopefully someone else gets to it. Otherwise ping it in a week or two and I
> might have more time to look myself..
> On Mon, May 10, 2021 at 11:26 AM Jan Sommer <jan.sommer at dlr.de>
> wrote:
> > Hello,
> > This is a follow-up on this discussion regarding the installed header
> > files in libbsd:
> > https://lists.rtems.org/pipermail/devel/2021-April/066211.html
> > The current situation is, that for example for all machines the bus.h
> > is installed from within the rtemsbsd directory
> (https://git.rtems.org/rtems-libbsd/tree/rtemsbsd/include/machine/bus.h).
> > According to the file docu it originates from the amd64 version of this file.
> > It also has the following section in it which we ran into when compiling
> Chris' ptpd2 archive:
> > #ifdef __i386__
> >   #error "your include paths are wrong"
> > #endif
> > This patchset does the following:
> > - Add the target dependent machine include directory to 'header-paths'
> > in libbsd.py
> > - Import (mostly) '_bus.h', 'bus.h' and 'cpufunc.h' for the targets
> > from freebsd-org
> > - Remove those header files from rtemsbsd directory
> > As a result the matching versions for machine dependent header files
> > are now installed for each BSP.
> > Would this be an acceptable solution?
> > So far I compiled some BSPs for i386, arm, aarch64, powerpc, riscv, sparc
> and sparc64 to check that they still compile after the changes.
> > Are there any other architectures which should be included?
> > I ran into one problem regarding the compilation of
> > rtemsbsd/sys/dev/dw_mmc/dw_mmc.c:105
> > > return (bus_space_read_4(0, sc->bushandle, off));
> > The first parameter creates an error for riscv (I think because dereferencing
> a NULL pointer).
> > Are there any suggestion how to solve it (I am not familiar with the bus
> space and there is a lot of macro magic going on)?
> > Also, I am not sure if I always added the header files in the right
> > module in libbsd.py. Any suggestions where to put them instead would be
> welcome.
> > Best regards,
> >     Jan
> > Jan Sommer (2):
> >   rtemsbd: Remove machine dependent files and use the ones from
> freebsd
> >   machine: Add machine dependent header files to libbsd.py
> >  freebsd/sys/arm/include/machine/_bus.h        |  47 +
> >  freebsd/sys/arm/include/machine/bus.h         | 769 ++++++++++++++++
> >  freebsd/sys/arm64/include/machine/_bus.h      |  46 +
> >  freebsd/sys/arm64/include/machine/bus.h       | 469 ++++++++++
> >  freebsd/sys/powerpc/include/machine/_bus.h    |  50 +
> >  freebsd/sys/powerpc/include/machine/bus.h     | 467 ++++++++++
> >  freebsd/sys/riscv/include/machine/_bus.h      |  46 +
> >  freebsd/sys/riscv/include/machine/bus.h       | 469 ++++++++++
> >  freebsd/sys/riscv/include/machine/cpufunc.h   | 135 +++
> >  freebsd/sys/riscv/include/machine/riscvreg.h  | 246 +++++
> >  .../sys/sparc}/include/machine/_bus.h         |   0
> >  .../sys/sparc}/include/machine/bus.h          |   0
> >  freebsd/sys/sparc/include/machine/cpufunc.h   |   0
> >  freebsd/sys/sparc64/include/machine/_bus.h    |  41 +
> >  freebsd/sys/sparc64/include/machine/bus.h     | 852
> >  libbsd.py                                     |  26 +-
> >  rtemsbsd/include/machine/cpufunc.h            |   1 -
> >  waf_libbsd.py                                 |   2 -
> >  18 files changed, 3660 insertions(+), 6 deletions(-)  create mode
> > 100644 freebsd/sys/arm/include/machine/_bus.h
> >  create mode 100644 freebsd/sys/arm/include/machine/bus.h
> >  create mode 100644 freebsd/sys/arm64/include/machine/_bus.h
> >  create mode 100644 freebsd/sys/arm64/include/machine/bus.h
> >  create mode 100644 freebsd/sys/powerpc/include/machine/_bus.h
> >  create mode 100644 freebsd/sys/powerpc/include/machine/bus.h
> >  create mode 100644 freebsd/sys/riscv/include/machine/_bus.h
> >  create mode 100644 freebsd/sys/riscv/include/machine/bus.h
> >  create mode 100644 freebsd/sys/riscv/include/machine/cpufunc.h
> >  create mode 100644 freebsd/sys/riscv/include/machine/riscvreg.h
> >  rename {rtemsbsd => freebsd/sys/sparc}/include/machine/_bus.h (100%)
> > rename {rtemsbsd => freebsd/sys/sparc}/include/machine/bus.h (100%)
> > create mode 100644 freebsd/sys/sparc/include/machine/cpufunc.h
> >  create mode 100644 freebsd/sys/sparc64/include/machine/_bus.h
> >  create mode 100644 freebsd/sys/sparc64/include/machine/bus.h
> >  delete mode 100644 rtemsbsd/include/machine/cpufunc.h
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
