Interested in working on ticket #2902, #4328, or #4334
Christian MAUDERER christian.mauderer at embedded-brains.de
Fri Nov 12 15:20:22 UTC 2021
Hello Prateek Pardeshi and Joel,
Am 11.11.21 um 19:06 schrieb Joel Sherrill:
> On Thu, Nov 11, 2021 at 10:34 AM Prateek Pardeshi
> <prateekpardeshi9 at gmail.com> wrote:
>> Hello Everyone,
>> I doubt that my email went into spam. Sorry for the inconvenience.
> I have no idea. I know I have been swamped with work and personal matters.
>> Email link:
>> https://lists.rtems.org/pipermail/devel/2021-November/069853.html
>>  From now on, I'll be using *Gmail* for sending emails on this list.
> Mostly it is a matter of using text format. Some clients do not do well
> with threaded discussions also.
> And now for the tickets:
> #2902 - Microblaze port
> I just closed this. The Microblaze port was recently merged. It has a
> BSP for HW and Qemu. Network support for libbsd and lwip should be
> close. libdl and libdebugger support are missing. libdl should be approachable.
> #4328 - New POSIX APIs from Issue 8 (2021/2022)
> Matthew Joyce worked on this list for GSoC 2021. I've cc'ed him for
> suggestions on which APIs make sense to tackle next.
> #4334 - Replace Mongoose with Civetweb
> Is still an open project.  I'm not sure whether we would ultimately
> want a "cloned and owned" snapshot of civitweb or if it would make
> more sense to have an RSB package which could build it.
> It would be a change from the current usage pattern to have it
> from RSB, but that is likely the better long term solution.
 From my point of view, adding it to RSB and building it as a library
would be a good solution (if we find a way to handle the options). It
might would be even better to send all patches upstream that are
necessary for RTEMS (it's not much) and add some documentation to RTEMS
how to use it. The civetweb developer is quite open to patches in my
experience.
Best regards
Christian
> --joel
>> Thanking you,
>> Prateek
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
