Interested in working on ticket #2902, #4328, or #4334
Prateek Pardeshi
prateekpardeshi9 at gmail.com
Mon Nov 15 16:25:33 UTC 2021
Hello Christian and Joel,
On Fri, 12 Nov 2021 at 20:50, Christian MAUDERER
<christian.mauderer at embedded-brains.de> wrote:
> Hello Prateek Pardeshi and Joel,
> Am 11.11.21 um 19:06 schrieb Joel Sherrill:
> > On Thu, Nov 11, 2021 at 10:34 AM Prateek Pardeshi
> > <prateekpardeshi9 at gmail.com> wrote:
> >> Hello Everyone,
> >> I doubt that my email went into spam. Sorry for the inconvenience.
> > I have no idea. I know I have been swamped with work and personal matters.
> >> Email link:
> >> https://lists.rtems.org/pipermail/devel/2021-November/069853.html
> >> From now on, I'll be using *Gmail* for sending emails on this list.
> > Mostly it is a matter of using text format. Some clients do not do well
> > with threaded discussions also.
> > And now for the tickets:
> > #2902 - Microblaze port
> > I just closed this. The Microblaze port was recently merged. It has a
> > BSP for HW and Qemu. Network support for libbsd and lwip should be
> > close. libdl and libdebugger support are missing. libdl should be approachable.
> > #4328 - New POSIX APIs from Issue 8 (2021/2022)
> > Matthew Joyce worked on this list for GSoC 2021. I've cc'ed him for
> > suggestions on which APIs make sense to tackle next.
> > #4334 - Replace Mongoose with Civetweb
> > Is still an open project. I'm not sure whether we would ultimately
> > want a "cloned and owned" snapshot of civitweb or if it would make
> > more sense to have an RSB package which could build it.
> > It would be a change from the current usage pattern to have it
> > from RSB, but that is likely the better long term solution.
> From my point of view, adding it to RSB and building it as a library
> would be a good solution (if we find a way to handle the options). It
> might would be even better to send all patches upstream that are
> necessary for RTEMS (it's not much) and add some documentation to RTEMS
> how to use it. The civetweb developer is quite open to patches in my
> experience.
I agree with your point over here, adding it to RSB would be a good
option in my opinion too.
Thanks & Regards,
Prateek
> Best regards
> Christian
> > --joel
> >> Thanking you,
> >> Prateek
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
> embedded brains GmbH
> Herr Christian MAUDERER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> phone: +49-89-18 94 741 - 18
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
