AW: AW: AW: [PATCH 00/27] Update kern_tc in rtems 5 for ntp support
Gabriel.Moyano at dlr.de
Wed Nov 24 09:57:00 UTC 2021
> > > >> I am fine with this change being pushed to the 5 branch but I think it needs to built with the tier 1 archs (i386, powerpc, arm).
> > > > I could compile them for the BSPs of those archs.
> > > Thanks.
> > > > Does it make sense to run some test in qemu?
> > > Test results are always welcome.
> > I've run the following tests:
> > - sptimecounter02, 03 and 04 are pass on pc686 and Xilinx_zynq_a9.
> > - sptimecounter01 doesn't print something since everything happens inside of boot_card(). How the result of this test is verified?
> Re-run the test using rtems-test.
> - sptimecounter01, 02, 03 and 04 are marked as pass on Xilinx_zynq_a9 and psim
> - sptimecounter02, 03 and 04 are marked as pass on pc686
> - sptimecounter01 is marked as invalid on pc686. This result is with and without the patch set. I guess it is because nothing is printed
> out.
> > Are there any other tests that can be interested to run?
> If there isn't any other test to run, I would say that the patch set is ready.
After running the whole testsuite for pc686, xilinx_zynq_a9 and psim; there are no new failures introduced.
Results for pc686:
Passed: 561
Failed: 5
User Input: 6
Expected Fail: 0
Indeterminate: 0
Benchmark: 3
Timeout: 13
Invalid: 6
Wrong Version: 0
Wrong Build: 0
Wrong Tools: 0
Total: 594
Failures:
dl06.exe
psx12.exe
psxfenv01.exe
spfatal30.exe
tmcontext01.exe
User Input:
dl10.exe
monitor.exe
termios.exe
top.exe
capture.exe
fileio.exe
Benchmark:
dhrystone.exe
linpack.exe
whetstone.exe
Timeouts:
dl05.exe
psxintrcritical01.exe
cdtest.exe
cxx_iostream.exe
spintrcritical06.exe
spintrcritical07.exe
spintrcritical11.exe
spintrcritical12.exe
spintrcritical13.exe
spintrcritical14.exe
spintrcritical15.exe
spintrcritical18.exe
spintrcritical24.exe
Invalid:
spfatal09.exe
spfatal12.exe
spinternalerror01.exe
spstkalloc02.exe
spstkalloc03.exe
sptimecounter01.exe
Results for psim:
Passed: 567
Failed: 0
User Input: 6
Expected Fail: 16
Indeterminate: 0
Benchmark: 3
Timeout: 1
Invalid: 0
Wrong Version: 0
Wrong Build: 0
Wrong Tools: 0
Total: 593
User Input:
dl10.exe
monitor.exe
termios.exe
top.exe
capture.exe
fileio.exe
Expected Fail:
fsimfsgeneric01.exe
block11.exe
rbheap01.exe
termios01.exe
ttest01.exe
psx12.exe
psxchroot01.exe
psxfenv01.exe
psximfs02.exe
psxpipe01.exe
spextensions01.exe
spfatal31.exe
spfifo02.exe
spmountmgr01.exe
spprivenv01.exe
spstdthreads01.exe
Benchmark:
linpack.exe
dhrystone.exe
whetstone.exe
Timeouts:
fsrfsbitmap01.exe
Results for xilinx_zynq_a9:
Passed: 572
Failed: 1
User Input: 6
Expected Fail: 2
Indeterminate: 0
Benchmark: 3
Timeout: 10
Invalid: 0
Wrong Version: 0
Wrong Build: 0
Wrong Tools: 0
Total: 594
Failures:
psx12.exe
User Input:
dl10.exe
monitor.exe
termios.exe
top.exe
capture.exe
fileio.exe
Expected Fail:
dl06.exe
psxfenv01.exe
Benchmark:
whetstone.exe
linpack.exe
dhrystone.exe
Timeouts:
