AW: AW: AW: [PATCH 00/27] Update kern_tc in rtems 5 for ntp support
Sebastian Huber
Mon Nov 29 12:24:15 UTC 2021
On 24/11/2021 10:57, Gabriel.Moyano at dlr.de wrote:
>>>>>> I am fine with this change being pushed to the 5 branch but I think it needs to built with the tier 1 archs (i386, powerpc, arm).
>>>>> I could compile them for the BSPs of those archs.
>>>> Thanks.
>>>>> Does it make sense to run some test in qemu?
>>>> Test results are always welcome.
>>> I've run the following tests:
>>> - sptimecounter02, 03 and 04 are pass on pc686 and Xilinx_zynq_a9.
>>> - sptimecounter01 doesn't print something since everything happens inside of boot_card(). How the result of this test is verified?
>> Re-run the test using rtems-test.
>> - sptimecounter01, 02, 03 and 04 are marked as pass on Xilinx_zynq_a9 and psim
>> - sptimecounter02, 03 and 04 are marked as pass on pc686
>> - sptimecounter01 is marked as invalid on pc686. This result is with and without the patch set. I guess it is because nothing is printed
>> out.
>>> Are there any other tests that can be interested to run?
>> If there isn't any other test to run, I would say that the patch set is ready.
> After running the whole testsuite for pc686, xilinx_zynq_a9 and psim; there are no new failures introduced.
For me this is fine, what do you think Chris?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
