waf bsp_defaults appears to be broken
Christian MAUDERER
christian.mauderer at embedded-brains.de
Mon Oct 4 14:12:59 UTC 2021
Am 04.10.21 um 15:51 schrieb Joel Sherrill:
> On Mon, Oct 4, 2021 at 2:32 AM Christian MAUDERER
> <christian.mauderer at embedded-brains.de> wrote:
>> Hello Joel,
>> Am 03.10.21 um 18:06 schrieb Joel Sherrill:
>>> Hi
>>> No BSP was successfully built in the build sweep Friday. All have
>>> failures like this:
>>> $ ./waf bsp_defaults --rtems-bsps=powerpc/psim
>> I just tested this command and everything seems to work fine. I get a
>> default config for the BSP.
>>> There is no top-level group with UID '/grp' in the specification
>> Maybe something cache related? The whole build specification files are
>> parsed and put into a cache as a first step. If that doesn't work
>> correctly, it might lead to odd results.
> This must be it. I suppose I should delete the build/ subdirectory as part
> of setting up for a sweep.
If you want to get a clean repository again, you could also use a "git
clean -dxf". But be very careful with that command. It doesn't ask
before deleting anything that is not versioned.
>>> The script fetches the BSP's defaults and then changes settings for
>>> enable tests, etc.
>> Do you use a fresh checkout or an update from a previous one?
> It's an update to minimize what needs to be done. If the RSB changed, tools
> and RTEMS are built. If only RTEMS changed, only RTEMS BSPs are built.
> If nothing changed (rare in a week), then nothing is done.
> I ended up recloning rtems this time and it seems ok now.
If you get the error again, it would be interesting to find out what
caused it. That sounds like something that shouldn't happen. It seems
that the wscript uses a simple file modification time to find out
whether the cache has to be re-generated. So if your system time changed
backward, that might could lead to such errors.
Best regards
Christian
> Thanks.
> --joel
>> Best regards
>> Christian
>>> Anyone else see this?
>>> --joel
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> embedded brains GmbH
>> Herr Christian MAUDERER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: christian.mauderer at embedded-brains.de
>> phone: +49-89-18 94 741 - 18
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
Dornierstr. 4
82178 Puchheim
Germany
