[PATCH] spec/libdebugger: Only enable for supported architectures
Thu Oct 21 05:30:15 UTC 2021
On 21/10/2021 04:09, chrisj at rtems.org wrote:
> From: Chris Johns<chrisj at rtems.org>
>   spec/build/cpukit/libdebugger.yml             | 5 ++++-
>   spec/build/testsuites/libtests/debugger01.yml | 4 +---
>   2 files changed, 5 insertions(+), 4 deletions(-)
> diff --git a/spec/build/cpukit/libdebugger.yml b/spec/build/cpukit/libdebugger.yml
> index f316cc18e8..4e689044e7 100644
> --- a/spec/build/cpukit/libdebugger.yml
> +++ b/spec/build/cpukit/libdebugger.yml
> @@ -5,7 +5,9 @@ copyrights:
>   - Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>   cppflags: []
>   cxxflags: []
> -enabled-by: true
> +enabled-by:
> +- arm
> +- i386
>   includes: []
>   install: []
>   install-path: ${BSP_LIBDIR}
> @@ -24,4 +26,5 @@ source:
>   - cpukit/libdebugger/rtems-debugger-target.c
>   - cpukit/libdebugger/rtems-debugger-threads.c
>   target: debugger
> +name: BUILD_LIBDEBUGGER
>   type: build
Library items cannot have a name. You need an option item for this.
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
