[PATCH] score: Simplify _Thread_Try_initialize()
Wed Sep 22 13:31:35 UTC 2021
ok
On Tue, Sep 21, 2021 at 5:25 AM Sebastian Huber
> Move a code block to its own new function
> _Thread_Initialize_scheduler_and_wait_nodes().  Add comments.
>  cpukit/score/src/threadinitialize.c | 180 +++++++++++++++++-----------
>  1 file changed, 108 insertions(+), 72 deletions(-)
> diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
> index 9c1b809c3a..e10eb1af88 100644
> --- a/cpukit/score/src/threadinitialize.c
> +++ b/cpukit/score/src/threadinitialize.c
> @@ -96,6 +96,113 @@ void _Thread_Free(
>    _Objects_Free( &information->Objects, &the_thread->Object );
> +static void _Thread_Initialize_scheduler_and_wait_nodes(
> +  Thread_Control             *the_thread,
> +  const Thread_Configuration *config
> +  Scheduler_Node          *scheduler_node;
> +#if defined(RTEMS_SMP)
> +  Scheduler_Node          *scheduler_node_for_index;
> +  const Scheduler_Control *scheduler_for_index;
> +  size_t                   scheduler_index;
> +#endif
> +  scheduler_node = NULL;
> +  scheduler_node_for_index = the_thread->Scheduler.nodes;
> +  scheduler_for_index = &_Scheduler_Table[ 0 ];
> +  scheduler_index = 0;
> +   * In SMP configurations, the thread has exactly one scheduler node for each
> +   * configured scheduler.  Initialize the scheduler nodes of each scheduler.
> +   * The application configuration ensures that we have at least one scheduler
> +   * configured.
> +  while ( scheduler_index < _Scheduler_Count ) {
> +    Priority_Control priority_for_index;
> +    if ( scheduler_for_index == config->scheduler ) {
> +      priority_for_index = config->priority;
> +      scheduler_node = scheduler_node_for_index;
> +    } else {
> +       * Use the idle thread priority for the non-home scheduler instances by
> +       * default.
> +      priority_for_index = _Scheduler_Map_priority(
> +        scheduler_for_index,
> +        scheduler_for_index->maximum_priority
> +    _Scheduler_Node_initialize(
> +      scheduler_node_for_index,
> +      the_thread,
> +     * Since the size of a scheduler node depends on the application
> +     * configuration, the _Scheduler_Node_size constant is used to get the next
> +     * scheduler node.  Using sizeof( Scheduler_Node ) would be wrong.
> +    scheduler_node_for_index = (Scheduler_Node *)
> +      ( (uintptr_t) scheduler_node_for_index + _Scheduler_Node_size );
> +    ++scheduler_for_index;
> +    ++scheduler_index;
> +   * The thread is initialized to use exactly one scheduler node which is
> +   * provided by its home scheduler.
> +  _Assert( scheduler_node != NULL );
> +  _Chain_Initialize_one(
> +    &the_thread->Scheduler.Wait_nodes,
> +    &scheduler_node->Thread.Wait_node
> +    &the_thread->Scheduler.Scheduler_nodes,
> +    &scheduler_node->Thread.Scheduler_node.Chain
> +#else
> +   * In uniprocessor configurations, the thread has exactly one scheduler node.
> +  scheduler_node = _Thread_Scheduler_get_home_node( the_thread );
> +    config->scheduler,
> +    scheduler_node,
> +    the_thread,
> +    config->priority
> +#endif
> +   * The current priority of the thread is initialized to exactly the real
> +   * priority of the thread.  During the lifetime of the thread, it may gain
> +   * more priority nodes, for example through locking protocols such as
> +   * priority inheritance or priority ceiling.
> +  _Priority_Node_initialize( &the_thread->Real_priority, config->priority );
> +  _Priority_Initialize_one(
> +    &scheduler_node->Wait.Priority,
> +    &the_thread->Real_priority
> +  RTEMS_STATIC_ASSERT( THREAD_SCHEDULER_BLOCKED == 0, Scheduler_state );
> +  the_thread->Scheduler.home_scheduler = config->scheduler;
> +  _ISR_lock_Initialize( &the_thread->Scheduler.Lock, "Thread Scheduler" );
> +  _ISR_lock_Initialize( &the_thread->Wait.Lock.Default, "Thread Wait Default" );
> +  _Thread_queue_Gate_open( &the_thread->Wait.Lock.Tranquilizer );
> +  _RBTree_Initialize_node( &the_thread->Wait.Link.Registry_node );
> +#endif
>  static bool _Thread_Try_initialize(
>    Thread_Information         *information,
> @@ -107,12 +214,6 @@ static bool _Thread_Try_initialize(
>    char                    *stack_begin;
>    char                    *stack_end;
>    uintptr_t                stack_align;
> -  Scheduler_Node          *scheduler_node;
> -#if defined(RTEMS_SMP)
> -  Scheduler_Node          *scheduler_node_for_index;
> -  const Scheduler_Control *scheduler_for_index;
> -  size_t                   scheduler_index;
> -#endif
>    Per_CPU_Control         *cpu = _Per_CPU_Get_by_index( 0 );
>    memset(
> @@ -182,78 +283,13 @@ static bool _Thread_Try_initialize(
>    the_thread->Start.stack_free       = config->stack_free;
>    _Thread_Timer_initialize( &the_thread->Timer, cpu );
> +  _Thread_Initialize_scheduler_and_wait_nodes( the_thread, config );
> -  scheduler_node = NULL;
> -  scheduler_node_for_index = the_thread->Scheduler.nodes;
> -  scheduler_for_index = &_Scheduler_Table[ 0 ];
> -  scheduler_index = 0;
> -  while ( scheduler_index < _Scheduler_Count ) {
> -    Priority_Control priority_for_index;
> -    if ( scheduler_for_index == config->scheduler ) {
> -      priority_for_index = config->priority;
> -      scheduler_node = scheduler_node_for_index;
> -    } else {
> -       * Use the idle thread priority for the non-home scheduler instances by
> -       * default.
> -      priority_for_index = _Scheduler_Map_priority(
> -        scheduler_for_index,
> -        scheduler_for_index->maximum_priority
> -    _Scheduler_Node_initialize(
> -      scheduler_node_for_index,
> -      the_thread,
> -    scheduler_node_for_index = (Scheduler_Node *)
> -      ( (uintptr_t) scheduler_node_for_index + _Scheduler_Node_size );
> -    ++scheduler_for_index;
> -    ++scheduler_index;
> -  _Assert( scheduler_node != NULL );
> -  _Chain_Initialize_one(
> -    &the_thread->Scheduler.Wait_nodes,
> -    &scheduler_node->Thread.Wait_node
> -    &the_thread->Scheduler.Scheduler_nodes,
> -    &scheduler_node->Thread.Scheduler_node.Chain
> -#else
> -  scheduler_node = _Thread_Scheduler_get_home_node( the_thread );
> -    config->scheduler,
> -    scheduler_node,
> -    the_thread,
> -    config->priority
> -#endif
> -  _Priority_Node_initialize( &the_thread->Real_priority, config->priority );
> -  _Priority_Initialize_one(
> -    &scheduler_node->Wait.Priority,
> -    &the_thread->Real_priority
> -  RTEMS_STATIC_ASSERT( THREAD_SCHEDULER_BLOCKED == 0, Scheduler_state );
> -  the_thread->Scheduler.home_scheduler = config->scheduler;
> -  _ISR_lock_Initialize( &the_thread->Scheduler.Lock, "Thread Scheduler" );
>    _Processor_mask_Assign(
>      &the_thread->Scheduler.Affinity,
>      _SMP_Get_online_processors()
> -  _ISR_lock_Initialize( &the_thread->Wait.Lock.Default, "Thread Wait Default" );
> -  _Thread_queue_Gate_open( &the_thread->Wait.Lock.Tranquilizer );
> -  _RBTree_Initialize_node( &the_thread->Wait.Link.Registry_node );
>    _SMP_lock_Stats_initialize( &the_thread->Potpourri_stats, "Thread Potpourri" );
>    _SMP_lock_Stats_initialize( &the_thread->Join_queue.Lock_stats, "Thread State" );
>  #endif
> 2.31.1
> devel mailing list
> devel at rtems.org
