[PATCH 07/39] testsuites/ada/tmtests/tm1*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Apr 8 14:45:35 UTC 2022
Updates #3053.
testsuites/ada/tmtests/tm10/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm10/tm10.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm10/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm10/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm11/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm11/tm11.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm11/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm11/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm12/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm12/tm12.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm12/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm12/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm13/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm13/tm13.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm13/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm13/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm14/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm14/tm14.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm14/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm14/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm15/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm15/tm15.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm15/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm15/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm16/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm16/tm16.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm16/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm16/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm17/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm17/tm17.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm17/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm17/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm18/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm18/tm18.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm18/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm18/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm19/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm19/tm19.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm19/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm19/tmtest.ads | 25 ++++++++++++++++++++++---
40 files changed, 880 insertions(+), 120 deletions(-)
diff --git a/testsuites/ada/tmtests/tm10/init.c b/testsuites/ada/tmtests/tm10/init.c
index 3c3c5261b5..2102a33243 100644
--- a/testsuites/ada/tmtests/tm10/init.c
+++ b/testsuites/ada/tmtests/tm10/init.c
@@ -1,3 +1,5 @@
/* config.h
* This include file defines the Configuration Table for this test.
@@ -5,9 +7,26 @@
* COPYRIGHT (c) 1989-1997.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may in
- * the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
diff --git a/testsuites/ada/tmtests/tm10/tm10.adb b/testsuites/ada/tmtests/tm10/tm10.adb
index 4117d7a01a..4076083ec6 100644
--- a/testsuites/ada/tmtests/tm10/tm10.adb
+++ b/testsuites/ada/tmtests/tm10/tm10.adb
@@ -1,3 +1,5 @@
+-- SPDX-License-Identifier: BSD-2-Clause
-- MAIN / BODY
@@ -12,9 +14,26 @@
-- COPYRIGHT (c) 1989-2011.
-- On-Line Applications Research Corporation (OAR).
--- The license and distribution terms for this file may in
--- the file LICENSE in this distribution or at
--- http://www.rtems.org/license/LICENSE.
+-- Redistribution and use in source and binary forms, with or without
+-- modification, are permitted provided that the following conditions
+-- are met:
+-- 1. Redistributions of source code must retain the above copyright
+-- notice, this list of conditions and the following disclaimer.
+-- 2. Redistributions in binary form must reproduce the above copyright
+-- notice, this list of conditions and the following disclaimer in the
+-- documentation and/or other materials provided with the distribution.
+-- THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+-- AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+-- IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+-- ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+-- LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+-- CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+-- SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+-- INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+-- CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+-- ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+-- POSSIBILITY OF SUCH DAMAGE.
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm10/tmtest.adb b/testsuites/ada/tmtests/tm10/tmtest.adb
index 54836fb77d..ec5be849a1 100644
--- a/testsuites/ada/tmtests/tm10/tmtest.adb
+++ b/testsuites/ada/tmtests/tm10/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
with INTERFACES; use INTERFACES;
diff --git a/testsuites/ada/tmtests/tm10/tmtest.ads b/testsuites/ada/tmtests/tm10/tmtest.ads
index 224630e1d5..df9e8617d8 100644
--- a/testsuites/ada/tmtests/tm10/tmtest.ads
+++ b/testsuites/ada/tmtests/tm10/tmtest.ads
@@ -1,3 +1,5 @@
-- TMTEST / SPECIFICATION
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm11/init.c b/testsuites/ada/tmtests/tm11/init.c
index 93f4e1d1e4..fe34ddf192 100644
--- a/testsuites/ada/tmtests/tm11/init.c
+++ b/testsuites/ada/tmtests/tm11/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm11/tm11.adb b/testsuites/ada/tmtests/tm11/tm11.adb
index bcc91aa905..6b6427f0d9 100644
--- a/testsuites/ada/tmtests/tm11/tm11.adb
+++ b/testsuites/ada/tmtests/tm11/tm11.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm11/tmtest.adb b/testsuites/ada/tmtests/tm11/tmtest.adb
index 82ab9da4f1..08c61652b8 100644
--- a/testsuites/ada/tmtests/tm11/tmtest.adb
+++ b/testsuites/ada/tmtests/tm11/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm11/tmtest.ads b/testsuites/ada/tmtests/tm11/tmtest.ads
index 6718933b04..cd9cc48b90 100644
--- a/testsuites/ada/tmtests/tm11/tmtest.ads
+++ b/testsuites/ada/tmtests/tm11/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm12/init.c b/testsuites/ada/tmtests/tm12/init.c
index 421e44fab3..7ac3debe6c 100644
--- a/testsuites/ada/tmtests/tm12/init.c
+++ b/testsuites/ada/tmtests/tm12/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm12/tm12.adb b/testsuites/ada/tmtests/tm12/tm12.adb
index bea5e83b79..86f28d8253 100644
--- a/testsuites/ada/tmtests/tm12/tm12.adb
+++ b/testsuites/ada/tmtests/tm12/tm12.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm12/tmtest.adb b/testsuites/ada/tmtests/tm12/tmtest.adb
index fa469a1eb4..2dd877ff1a 100644
--- a/testsuites/ada/tmtests/tm12/tmtest.adb
+++ b/testsuites/ada/tmtests/tm12/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm12/tmtest.ads b/testsuites/ada/tmtests/tm12/tmtest.ads
index 15ff276c7c..f7891de833 100644
--- a/testsuites/ada/tmtests/tm12/tmtest.ads
+++ b/testsuites/ada/tmtests/tm12/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm13/init.c b/testsuites/ada/tmtests/tm13/init.c
index ecf18b29ab..66a79607b6 100644
--- a/testsuites/ada/tmtests/tm13/init.c
+++ b/testsuites/ada/tmtests/tm13/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm13/tm13.adb b/testsuites/ada/tmtests/tm13/tm13.adb
index ba2ab58065..a5a41ba41f 100644
--- a/testsuites/ada/tmtests/tm13/tm13.adb
+++ b/testsuites/ada/tmtests/tm13/tm13.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm13/tmtest.adb b/testsuites/ada/tmtests/tm13/tmtest.adb
index 886579c986..7360b68466 100644
--- a/testsuites/ada/tmtests/tm13/tmtest.adb
+++ b/testsuites/ada/tmtests/tm13/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm13/tmtest.ads b/testsuites/ada/tmtests/tm13/tmtest.ads
index 270bcda7e2..06f714fece 100644
--- a/testsuites/ada/tmtests/tm13/tmtest.ads
+++ b/testsuites/ada/tmtests/tm13/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm14/init.c b/testsuites/ada/tmtests/tm14/init.c
index 3555139575..c9ecdd5826 100644
--- a/testsuites/ada/tmtests/tm14/init.c
+++ b/testsuites/ada/tmtests/tm14/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm14/tm14.adb b/testsuites/ada/tmtests/tm14/tm14.adb
index 3835813b60..cc289f2a57 100644
--- a/testsuites/ada/tmtests/tm14/tm14.adb
+++ b/testsuites/ada/tmtests/tm14/tm14.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm14/tmtest.adb b/testsuites/ada/tmtests/tm14/tmtest.adb
index 72d95bee3c..29a8de65df 100644
--- a/testsuites/ada/tmtests/tm14/tmtest.adb
+++ b/testsuites/ada/tmtests/tm14/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm14/tmtest.ads b/testsuites/ada/tmtests/tm14/tmtest.ads
index c90b1cadc3..9f8bedcd7a 100644
--- a/testsuites/ada/tmtests/tm14/tmtest.ads
+++ b/testsuites/ada/tmtests/tm14/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm15/init.c b/testsuites/ada/tmtests/tm15/init.c
index c1b831d4bf..710599245a 100644
--- a/testsuites/ada/tmtests/tm15/init.c
+++ b/testsuites/ada/tmtests/tm15/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm15/tm15.adb b/testsuites/ada/tmtests/tm15/tm15.adb
index 31e40968da..b5a887101e 100644
--- a/testsuites/ada/tmtests/tm15/tm15.adb
+++ b/testsuites/ada/tmtests/tm15/tm15.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm15/tmtest.adb b/testsuites/ada/tmtests/tm15/tmtest.adb
index 33ff7df2f0..d767140100 100644
--- a/testsuites/ada/tmtests/tm15/tmtest.adb
+++ b/testsuites/ada/tmtests/tm15/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS_CALLING_OVERHEAD;
diff --git a/testsuites/ada/tmtests/tm15/tmtest.ads b/testsuites/ada/tmtests/tm15/tmtest.ads
index b8ab38d6cd..c9c7a502d0 100644
--- a/testsuites/ada/tmtests/tm15/tmtest.ads
+++ b/testsuites/ada/tmtests/tm15/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with TIME_TEST_SUPPORT;
diff --git a/testsuites/ada/tmtests/tm16/init.c b/testsuites/ada/tmtests/tm16/init.c
index 64e613fbd8..b54f3559b5 100644
--- a/testsuites/ada/tmtests/tm16/init.c
+++ b/testsuites/ada/tmtests/tm16/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm16/tm16.adb b/testsuites/ada/tmtests/tm16/tm16.adb
index a6d67d93ce..33e96f391b 100644
--- a/testsuites/ada/tmtests/tm16/tm16.adb
+++ b/testsuites/ada/tmtests/tm16/tm16.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm16/tmtest.adb b/testsuites/ada/tmtests/tm16/tmtest.adb
index 982adc8684..42124b1385 100644
--- a/testsuites/ada/tmtests/tm16/tmtest.adb
+++ b/testsuites/ada/tmtests/tm16/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm16/tmtest.ads b/testsuites/ada/tmtests/tm16/tmtest.ads
index ab42eb259c..f5255aa66b 100644
--- a/testsuites/ada/tmtests/tm16/tmtest.ads
+++ b/testsuites/ada/tmtests/tm16/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm17/init.c b/testsuites/ada/tmtests/tm17/init.c
index a4115412e3..e9252771cb 100644
--- a/testsuites/ada/tmtests/tm17/init.c
+++ b/testsuites/ada/tmtests/tm17/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm17/tm17.adb b/testsuites/ada/tmtests/tm17/tm17.adb
index efc2766479..9447aaef69 100644
--- a/testsuites/ada/tmtests/tm17/tm17.adb
+++ b/testsuites/ada/tmtests/tm17/tm17.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm17/tmtest.adb b/testsuites/ada/tmtests/tm17/tmtest.adb
index 1e093c839e..174eda97c5 100644
--- a/testsuites/ada/tmtests/tm17/tmtest.adb
+++ b/testsuites/ada/tmtests/tm17/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm17/tmtest.ads b/testsuites/ada/tmtests/tm17/tmtest.ads
index b2c9369e26..380e72e396 100644
--- a/testsuites/ada/tmtests/tm17/tmtest.ads
+++ b/testsuites/ada/tmtests/tm17/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm18/init.c b/testsuites/ada/tmtests/tm18/init.c
index b9f602170f..104134d726 100644
--- a/testsuites/ada/tmtests/tm18/init.c
+++ b/testsuites/ada/tmtests/tm18/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm18/tm18.adb b/testsuites/ada/tmtests/tm18/tm18.adb
index 856b6f1127..f205df9609 100644
--- a/testsuites/ada/tmtests/tm18/tm18.adb
+++ b/testsuites/ada/tmtests/tm18/tm18.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm18/tmtest.adb b/testsuites/ada/tmtests/tm18/tmtest.adb
index 25c4594318..1a221d1998 100644
--- a/testsuites/ada/tmtests/tm18/tmtest.adb
+++ b/testsuites/ada/tmtests/tm18/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm18/tmtest.ads b/testsuites/ada/tmtests/tm18/tmtest.ads
index 0b919d44a4..9e75691dfa 100644
--- a/testsuites/ada/tmtests/tm18/tmtest.ads
+++ b/testsuites/ada/tmtests/tm18/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm19/init.c b/testsuites/ada/tmtests/tm19/init.c
index 5dda49aaee..1961769118 100644
--- a/testsuites/ada/tmtests/tm19/init.c
+++ b/testsuites/ada/tmtests/tm19/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm19/tm19.adb b/testsuites/ada/tmtests/tm19/tm19.adb
index 0b232d833a..f22d1939ef 100644
--- a/testsuites/ada/tmtests/tm19/tm19.adb
+++ b/testsuites/ada/tmtests/tm19/tm19.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm19/tmtest.adb b/testsuites/ada/tmtests/tm19/tmtest.adb
index df05cb42ed..c2047fa330 100644
--- a/testsuites/ada/tmtests/tm19/tmtest.adb
+++ b/testsuites/ada/tmtests/tm19/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm19/tmtest.ads b/testsuites/ada/tmtests/tm19/tmtest.ads
index 7776b41b35..27005b752a 100644
--- a/testsuites/ada/tmtests/tm19/tmtest.ads
+++ b/testsuites/ada/tmtests/tm19/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
2.24.4
