[PATCH 08/39] testsuites/ada/tmtests/tm0*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Apr 8 14:45:36 UTC 2022
Updates #3053.
testsuites/ada/tmtests/tm01/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm01/tm01.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm01/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm01/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm02/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm02/tm02.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm02/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm02/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm03/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm03/tm03.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm03/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm03/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm04/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm04/tm04.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm04/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm04/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm05/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm05/tm05.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm05/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm05/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm06/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm06/tm06.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm06/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm06/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm07/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm07/tm07.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm07/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm07/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm08/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm08/tm08.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm08/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm08/tmtest.ads | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm09/init.c | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm09/tm09.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm09/tmtest.adb | 25 ++++++++++++++++++++++---
testsuites/ada/tmtests/tm09/tmtest.ads | 25 ++++++++++++++++++++++---
36 files changed, 792 insertions(+), 108 deletions(-)
diff --git a/testsuites/ada/tmtests/tm01/init.c b/testsuites/ada/tmtests/tm01/init.c
index 8f2fb49790..6c9ec3ff44 100644
--- a/testsuites/ada/tmtests/tm01/init.c
+++ b/testsuites/ada/tmtests/tm01/init.c
@@ -1,3 +1,5 @@
/* config.h
* This include file defines the Configuration Table for this test.
@@ -5,9 +7,26 @@
* COPYRIGHT (c) 1989-1997.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may in
- * the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
diff --git a/testsuites/ada/tmtests/tm01/tm01.adb b/testsuites/ada/tmtests/tm01/tm01.adb
index 47c83a17e0..42a20dfed1 100644
--- a/testsuites/ada/tmtests/tm01/tm01.adb
+++ b/testsuites/ada/tmtests/tm01/tm01.adb
@@ -1,3 +1,5 @@
+-- SPDX-License-Identifier: BSD-2-Clause
-- MAIN / BODY
@@ -12,9 +14,26 @@
-- COPYRIGHT (c) 1989-2011.
-- On-Line Applications Research Corporation (OAR).
--- The license and distribution terms for this file may in
--- the file LICENSE in this distribution or at
--- http://www.rtems.org/license/LICENSE.
+-- Redistribution and use in source and binary forms, with or without
+-- modification, are permitted provided that the following conditions
+-- are met:
+-- 1. Redistributions of source code must retain the above copyright
+-- notice, this list of conditions and the following disclaimer.
+-- 2. Redistributions in binary form must reproduce the above copyright
+-- notice, this list of conditions and the following disclaimer in the
+-- documentation and/or other materials provided with the distribution.
+-- THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+-- AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+-- IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+-- ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+-- LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+-- CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+-- SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+-- INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+-- CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+-- ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+-- POSSIBILITY OF SUCH DAMAGE.
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm01/tmtest.adb b/testsuites/ada/tmtests/tm01/tmtest.adb
index 4f48668cf0..485cca38a8 100644
--- a/testsuites/ada/tmtests/tm01/tmtest.adb
+++ b/testsuites/ada/tmtests/tm01/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
with INTERFACES; use INTERFACES;
diff --git a/testsuites/ada/tmtests/tm01/tmtest.ads b/testsuites/ada/tmtests/tm01/tmtest.ads
index 6d00d05715..c174131b62 100644
--- a/testsuites/ada/tmtests/tm01/tmtest.ads
+++ b/testsuites/ada/tmtests/tm01/tmtest.ads
@@ -1,3 +1,5 @@
-- TMTEST / SPECIFICATION
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm02/init.c b/testsuites/ada/tmtests/tm02/init.c
index d8123f0452..84fc053e17 100644
--- a/testsuites/ada/tmtests/tm02/init.c
+++ b/testsuites/ada/tmtests/tm02/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm02/tm02.adb b/testsuites/ada/tmtests/tm02/tm02.adb
index 9476c87878..4ade119161 100644
--- a/testsuites/ada/tmtests/tm02/tm02.adb
+++ b/testsuites/ada/tmtests/tm02/tm02.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm02/tmtest.adb b/testsuites/ada/tmtests/tm02/tmtest.adb
index c2386a5f51..ca1ae1302c 100644
--- a/testsuites/ada/tmtests/tm02/tmtest.adb
+++ b/testsuites/ada/tmtests/tm02/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm02/tmtest.ads b/testsuites/ada/tmtests/tm02/tmtest.ads
index 0857c93313..be4e50ed6f 100644
--- a/testsuites/ada/tmtests/tm02/tmtest.ads
+++ b/testsuites/ada/tmtests/tm02/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm03/init.c b/testsuites/ada/tmtests/tm03/init.c
index 439c8ca168..9e88b1cb55 100644
--- a/testsuites/ada/tmtests/tm03/init.c
+++ b/testsuites/ada/tmtests/tm03/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm03/tm03.adb b/testsuites/ada/tmtests/tm03/tm03.adb
index 9a95e5e1d0..4912f066d1 100644
--- a/testsuites/ada/tmtests/tm03/tm03.adb
+++ b/testsuites/ada/tmtests/tm03/tm03.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm03/tmtest.adb b/testsuites/ada/tmtests/tm03/tmtest.adb
index 577b5fd121..febc7f665d 100644
--- a/testsuites/ada/tmtests/tm03/tmtest.adb
+++ b/testsuites/ada/tmtests/tm03/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm03/tmtest.ads b/testsuites/ada/tmtests/tm03/tmtest.ads
index 4acd5f7a77..8cc5b39ca0 100644
--- a/testsuites/ada/tmtests/tm03/tmtest.ads
+++ b/testsuites/ada/tmtests/tm03/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm04/init.c b/testsuites/ada/tmtests/tm04/init.c
index 2cf05da2e1..826795e729 100644
--- a/testsuites/ada/tmtests/tm04/init.c
+++ b/testsuites/ada/tmtests/tm04/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm04/tm04.adb b/testsuites/ada/tmtests/tm04/tm04.adb
index 28e75c7db5..2aab521514 100644
--- a/testsuites/ada/tmtests/tm04/tm04.adb
+++ b/testsuites/ada/tmtests/tm04/tm04.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm04/tmtest.adb b/testsuites/ada/tmtests/tm04/tmtest.adb
index 30ab443668..65b1af1dab 100644
--- a/testsuites/ada/tmtests/tm04/tmtest.adb
+++ b/testsuites/ada/tmtests/tm04/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm04/tmtest.ads b/testsuites/ada/tmtests/tm04/tmtest.ads
index e1f303ee2f..5842225751 100644
--- a/testsuites/ada/tmtests/tm04/tmtest.ads
+++ b/testsuites/ada/tmtests/tm04/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with TIME_TEST_SUPPORT;
diff --git a/testsuites/ada/tmtests/tm05/init.c b/testsuites/ada/tmtests/tm05/init.c
index 7fb0f854ee..9e0036e809 100644
--- a/testsuites/ada/tmtests/tm05/init.c
+++ b/testsuites/ada/tmtests/tm05/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm05/tm05.adb b/testsuites/ada/tmtests/tm05/tm05.adb
index eaa0741592..458a798365 100644
--- a/testsuites/ada/tmtests/tm05/tm05.adb
+++ b/testsuites/ada/tmtests/tm05/tm05.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm05/tmtest.adb b/testsuites/ada/tmtests/tm05/tmtest.adb
index 46362e752a..343408f207 100644
--- a/testsuites/ada/tmtests/tm05/tmtest.adb
+++ b/testsuites/ada/tmtests/tm05/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm05/tmtest.ads b/testsuites/ada/tmtests/tm05/tmtest.ads
index f705c936df..a3c8a09393 100644
--- a/testsuites/ada/tmtests/tm05/tmtest.ads
+++ b/testsuites/ada/tmtests/tm05/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm06/init.c b/testsuites/ada/tmtests/tm06/init.c
index 88f27f6b2f..e7da9b9a48 100644
--- a/testsuites/ada/tmtests/tm06/init.c
+++ b/testsuites/ada/tmtests/tm06/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm06/tm06.adb b/testsuites/ada/tmtests/tm06/tm06.adb
index db064adb4d..dfe85f9f36 100644
--- a/testsuites/ada/tmtests/tm06/tm06.adb
+++ b/testsuites/ada/tmtests/tm06/tm06.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm06/tmtest.adb b/testsuites/ada/tmtests/tm06/tmtest.adb
index fc43355645..ccebbf71b2 100644
--- a/testsuites/ada/tmtests/tm06/tmtest.adb
+++ b/testsuites/ada/tmtests/tm06/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm06/tmtest.ads b/testsuites/ada/tmtests/tm06/tmtest.ads
index a6eb2b2df8..11e9f78f5c 100644
--- a/testsuites/ada/tmtests/tm06/tmtest.ads
+++ b/testsuites/ada/tmtests/tm06/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm07/init.c b/testsuites/ada/tmtests/tm07/init.c
index dcbf73a3ae..e2b2e476f9 100644
--- a/testsuites/ada/tmtests/tm07/init.c
+++ b/testsuites/ada/tmtests/tm07/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm07/tm07.adb b/testsuites/ada/tmtests/tm07/tm07.adb
index 342406b38f..16b1530d30 100644
--- a/testsuites/ada/tmtests/tm07/tm07.adb
+++ b/testsuites/ada/tmtests/tm07/tm07.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm07/tmtest.adb b/testsuites/ada/tmtests/tm07/tmtest.adb
index 4f2f4abdbd..6b46f10e96 100644
--- a/testsuites/ada/tmtests/tm07/tmtest.adb
+++ b/testsuites/ada/tmtests/tm07/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm07/tmtest.ads b/testsuites/ada/tmtests/tm07/tmtest.ads
index 3abc539505..7c2155ab13 100644
--- a/testsuites/ada/tmtests/tm07/tmtest.ads
+++ b/testsuites/ada/tmtests/tm07/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm08/init.c b/testsuites/ada/tmtests/tm08/init.c
index ded1a2e130..d7a38a816b 100644
--- a/testsuites/ada/tmtests/tm08/init.c
+++ b/testsuites/ada/tmtests/tm08/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/testsuites/ada/tmtests/tm08/tm08.adb b/testsuites/ada/tmtests/tm08/tm08.adb
index d927a18d63..84695749d3 100644
--- a/testsuites/ada/tmtests/tm08/tm08.adb
+++ b/testsuites/ada/tmtests/tm08/tm08.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm08/tmtest.adb b/testsuites/ada/tmtests/tm08/tmtest.adb
index 9f14c9383a..067d212930 100644
--- a/testsuites/ada/tmtests/tm08/tmtest.adb
+++ b/testsuites/ada/tmtests/tm08/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm08/tmtest.ads b/testsuites/ada/tmtests/tm08/tmtest.ads
index 695235f479..34ca6a50cd 100644
--- a/testsuites/ada/tmtests/tm08/tmtest.ads
+++ b/testsuites/ada/tmtests/tm08/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm09/init.c b/testsuites/ada/tmtests/tm09/init.c
index 0db14c4815..42482a2f69 100644
--- a/testsuites/ada/tmtests/tm09/init.c
+++ b/testsuites/ada/tmtests/tm09/init.c
@@ -1,3 +1,5 @@
/* config.h
@@ -5,9 +7,26 @@
* COPYRIGHT (c) 1989-2007.
+ * are met:
diff --git a/testsuites/ada/tmtests/tm09/tm09.adb b/testsuites/ada/tmtests/tm09/tm09.adb
index 6fe1971d44..fd3c8f7b14 100644
--- a/testsuites/ada/tmtests/tm09/tm09.adb
+++ b/testsuites/ada/tmtests/tm09/tm09.adb
@@ -1,3 +1,5 @@
-- MAIN / BODY
@@ -12,9 +14,26 @@
+-- are met:
with RTEMS;
diff --git a/testsuites/ada/tmtests/tm09/tmtest.adb b/testsuites/ada/tmtests/tm09/tmtest.adb
index 88c016364b..69a17fd399 100644
--- a/testsuites/ada/tmtests/tm09/tmtest.adb
+++ b/testsuites/ada/tmtests/tm09/tmtest.adb
@@ -1,3 +1,5 @@
-- TMTEST / BODY
@@ -13,9 +15,26 @@
+-- are met:
diff --git a/testsuites/ada/tmtests/tm09/tmtest.ads b/testsuites/ada/tmtests/tm09/tmtest.ads
index ca02e74a51..e65360a12d 100644
--- a/testsuites/ada/tmtests/tm09/tmtest.ads
+++ b/testsuites/ada/tmtests/tm09/tmtest.ads
@@ -1,3 +1,5 @@
@@ -13,9 +15,26 @@
+-- are met:
with RTEMS;
2.24.4
