GCC version for RTEMS 6? (Can Ada be used?)
Karel Gardas
karel at functional.vision
Wed Apr 27 17:46:15 UTC 2022
On 4/27/22 19:25, Frank Kühndel wrote:
> I do not need ADA but ADA may be worth considering. With GCC 10 one
> needed to have a GNAT 10 compiler installed to build the tools incl.
> --with_ada. I presume, one would need a GNAT 12 to build ADA with the
> GCC 12 sources? The current Fedora 35 has GNAT 11. All other distros I
> know of have GNAT 10 at best (I have not checked on tumbleweed yet).
> OpenSUSE may get ADA 12 from an unusual repro???
On https://gcc.gnu.org/install/prerequisites.html there is a text:
GNAT
In order to build GNAT, the Ada compiler, you need a working GNAT
compiler (GCC version 5.1 or later).
is it outdated? If so, this would require some bugreport to gcc team?
Thanks,
Karel
