[PATCH] bsps/xilinx/versal: Remove IPL32 BSPs, add aiedge and change defaults
chrisj at rtems.org chrisj at rtems.org
Mon Aug 22 06:53:48 UTC 2022
- Versal has IO mapped to the upper 64bit address space and
  needs full 64bit addresses.
- Add xilinx_versal_aiedge for custom hardware
- Make the hardware settings the defaults and qemu as variants
Closes #4693
 spec/build/bsps/aarch64/xilinx-versal/abi.yml | 10 +--
 .../{bspqemuilp32.yml => bspaiedge.yml}       |  8 +-
 .../{bspqemulp64.yml => bspqemu.yml}          |  4 +-
 .../{bspvck190lp64.yml => bspvck190.yml}      |  2 +-
 .../{bspvck190ilp32.yml => grp_aiedge.yml}    | 16 ++--
 .../aarch64/xilinx-versal/linkcmds_ilp32.yml  | 74 -------------------
 .../bsps/aarch64/xilinx-versal/optclkuart.yml |  9 +--
 .../bsps/aarch64/xilinx-versal/optloadoff.yml |  7 +-
 .../bsps/aarch64/xilinx-versal/optramori.yml  |  7 +-
 .../bsps/aarch64/xilinx-versal/tstaiedge.yml  | 15 ++++
 10 files changed, 42 insertions(+), 110 deletions(-)
 rename spec/build/bsps/aarch64/xilinx-versal/{bspqemuilp32.yml => bspaiedge.yml} (67%)
 rename spec/build/bsps/aarch64/xilinx-versal/{bspqemulp64.yml => bspqemu.yml} (82%)
 rename spec/build/bsps/aarch64/xilinx-versal/{bspvck190lp64.yml => bspvck190.yml} (91%)
 rename spec/build/bsps/aarch64/xilinx-versal/{bspvck190ilp32.yml => grp_aiedge.yml} (51%)
 delete mode 100644 spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
 create mode 100644 spec/build/bsps/aarch64/xilinx-versal/tstaiedge.yml
diff --git a/spec/build/bsps/aarch64/xilinx-versal/abi.yml b/spec/build/bsps/aarch64/xilinx-versal/abi.yml
index 90bfca9f76..b52df18fb3 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/abi.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/abi.yml
@@ -5,16 +5,10 @@ actions:
 - env-append: null
 build-type: option
 copyrights:
-- Copyright (C) 2021 Gedare Bloom
+- Copyright (C) 2021 Gedare Bloom
 default:
 - -mcpu=cortex-a72
-default-by-variant:
-- value:
-  - -mcpu=cortex-a72
-  - -mabi=ilp32
-  variants:
-  - aarch64/xilinx_versal_ilp32_qemu
-  - aarch64/xilinx_versal_ilp32_vck190
+default-by-variant: []
 description: |
   ABI flags
 enabled-by: true
diff --git a/spec/build/bsps/aarch64/xilinx-versal/bspqemuilp32.yml b/spec/build/bsps/aarch64/xilinx-versal/bspaiedge.yml
similarity index 67%
rename from spec/build/bsps/aarch64/xilinx-versal/bspqemuilp32.yml
rename to spec/build/bsps/aarch64/xilinx-versal/bspaiedge.yml
index cdad919b1c..f8c9011143 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/bspqemuilp32.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/bspaiedge.yml
@@ -1,10 +1,10 @@
 SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
 arch: aarch64
-bsp: xilinx_versal_ilp32_qemu
+bsp: xilinx_versal_aiedge
 build-type: bsp
 cflags: []
 copyrights:
+- Copyright (C) 2022 Chris Johns <chris at contemporary.software>
 cppflags: []
 enabled-by: true
 family: xilinx-versal
@@ -12,8 +12,8 @@ includes: []
 install: []
 links:
 - role: build-dependency
-  uid: grp_qemu
+  uid: grp_aiedge
-  uid: linkcmds_ilp32
+  uid: linkcmds_lp64
 source: []
 type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/bspqemulp64.yml b/spec/build/bsps/aarch64/xilinx-versal/bspqemu.yml
similarity index 82%
rename from spec/build/bsps/aarch64/xilinx-versal/bspqemulp64.yml
rename to spec/build/bsps/aarch64/xilinx-versal/bspqemu.yml
index bd8dab6a6e..f7f167dbfb 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/bspqemulp64.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/bspqemu.yml
@@ -1,10 +1,10 @@
 arch: aarch64
-bsp: xilinx_versal_lp64_qemu
+bsp: xilinx_versal_qemu
 build-type: bsp
 cflags: []
 copyrights:
 cppflags: []
 enabled-by: true
diff --git a/spec/build/bsps/aarch64/xilinx-versal/bspvck190lp64.yml b/spec/build/bsps/aarch64/xilinx-versal/bspvck190.yml
similarity index 91%
rename from spec/build/bsps/aarch64/xilinx-versal/bspvck190lp64.yml
rename to spec/build/bsps/aarch64/xilinx-versal/bspvck190.yml
index b33a10f8f0..bc2bbc1c5d 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/bspvck190lp64.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/bspvck190.yml
@@ -1,6 +1,6 @@
 arch: aarch64
-bsp: xilinx_versal_lp64_vck190
+bsp: xilinx_versal_vck190
 build-type: bsp
 cflags: []
 copyrights:
diff --git a/spec/build/bsps/aarch64/xilinx-versal/bspvck190ilp32.yml b/spec/build/bsps/aarch64/xilinx-versal/grp_aiedge.yml
similarity index 51%
rename from spec/build/bsps/aarch64/xilinx-versal/bspvck190ilp32.yml
rename to spec/build/bsps/aarch64/xilinx-versal/grp_aiedge.yml
index 741b28c6e8..680584f36c 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/bspvck190ilp32.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/grp_aiedge.yml
@@ -1,19 +1,19 @@
-arch: aarch64
-bsp: xilinx_versal_ilp32_vck190
-build-type: bsp
+build-type: group
 cflags: []
 copyrights:
-- Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
 cppflags: []
+cxxflags: []
 enabled-by: true
-family: xilinx-versal
 includes: []
 install: []
+ldflags: []
 links:
-  uid: grp_vck190
+  uid: grp
-source: []
+  uid: tstaiedge
 type: build
+use-after: []
+use-before: []
diff --git a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml b/spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
deleted file mode 100644
index 2d7a922495..0000000000
--- a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
+++ /dev/null
@@ -1,74 +0,0 @@
-SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
-build-type: config-file
-content: |
-  /* SPDX-License-Identifier: BSD-2-Clause */
-   * Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
-   * Redistribution and use in source and binary forms, with or without
-   * modification, are permitted provided that the following conditions
-   * are met:
-   * 1. Redistributions of source code must retain the above copyright
-   *    notice, this list of conditions and the following disclaimer.
-   * 2. Redistributions in binary form must reproduce the above copyright
-   *    notice, this list of conditions and the following disclaimer in the
-   *    documentation and/or other materials provided with the distribution.
-   * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
-   * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-   * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-   * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
-   * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
-   * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-   * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
-   * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
-   * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
-   * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-   * POSSIBILITY OF SUCH DAMAGE.
-  MEMORY {
-    RAM       : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_LOAD_OFFSET}, LENGTH = ${BSP_XILINX_VERSAL_RAM_LENGTH} - ${BSP_XILINX_VERSAL_LOAD_OFFSET} - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
-    NOCACHE   : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_RAM_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}) - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}, LENGTH = ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}
-    RAM_MMU   : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_RAM_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}), LENGTH = 0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}
-  REGION_ALIAS ("REGION_START",          RAM);
-  REGION_ALIAS ("REGION_VECTOR",         RAM);
-  REGION_ALIAS ("REGION_TEXT",           RAM);
-  REGION_ALIAS ("REGION_TEXT_LOAD",      RAM);
-  REGION_ALIAS ("REGION_RODATA",         RAM);
-  REGION_ALIAS ("REGION_RODATA_LOAD",    RAM);
-  REGION_ALIAS ("REGION_DATA",           RAM);
-  REGION_ALIAS ("REGION_DATA_LOAD",      RAM);
-  REGION_ALIAS ("REGION_FAST_TEXT",      RAM);
-  REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
-  REGION_ALIAS ("REGION_FAST_DATA",      RAM);
-  REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
-  REGION_ALIAS ("REGION_BSS",            RAM);
-  REGION_ALIAS ("REGION_WORK",           RAM);
-  REGION_ALIAS ("REGION_STACK",          RAM);
-  REGION_ALIAS ("REGION_NOCACHE",        NOCACHE);
-  REGION_ALIAS ("REGION_NOCACHE_LOAD",   NOCACHE);
-  bsp_stack_exception_size = DEFINED (bsp_stack_exception_size) ? bsp_stack_exception_size : 1024;
-  bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
-  bsp_vector_table_in_start_section = 1;
-  bsp_translation_table_base = ORIGIN (RAM_MMU);
-  bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
-  OUTPUT_FORMAT ("elf32-littleaarch64")
-  OUTPUT_ARCH (aarch64:ilp32)
-  INCLUDE linkcmds.base
-copyrights:
-enabled-by: true
-install-path: ${BSP_LIBDIR}
-links: []
-target: linkcmds
-type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml b/spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml
index 4ba449b8fd..fb344019e2 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml
@@ -4,13 +4,12 @@ actions:
 - define: null
 build-type: option
 copyrights:
-default: 24000000
+- Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
+default: 100000000
 default-by-variant:
-- value: 100000000
+- value: 24000000
   variants:
-  - aarch64/xilinx_versal_ilp32.*
-  - aarch64/xilinx_versal_lp64.*
+  - aarch64/xilinx_versal_qemu
 description: |
   Versal UART clock frequency in Hz
 enabled-by: true
diff --git a/spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml b/spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml
index 41023dcf3e..577a1451dd 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml
@@ -7,12 +7,11 @@ actions:
 build-type: option
 copyrights:
-default: 32768
+default: 0x0
 default-by-variant:
-- value: 0x0
+- value: 32768
   variants:
-  - aarch64/xilinx_versal_lp64_vck190
 description: |
   offset of RAM region from memory area base
 enabled-by: true
diff --git a/spec/build/bsps/aarch64/xilinx-versal/optramori.yml b/spec/build/bsps/aarch64/xilinx-versal/optramori.yml
index 8ab8f5bc13..6e94f55b7e 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/optramori.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/optramori.yml
 build-type: option
 copyrights:
-default: 0x20000000
+default: 0x10000000
 default-by-variant:
-- value: 0x10000000
+- value: 0x20000000
   variants:
 description: |
   base address of memory area available to the BSP
 enabled-by: true
diff --git a/spec/build/bsps/aarch64/xilinx-versal/tstaiedge.yml b/spec/build/bsps/aarch64/xilinx-versal/tstaiedge.yml
new file mode 100644
index 0000000000..cbc1c7e381
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/tstaiedge.yml
@@ -0,0 +1,15 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- set-test-state:
+    # expected to produce a fatal-error when run
+    minimum: exclude
+build-type: option
+copyrights:
+default: null
+description: ''
+enabled-by: true
+links: []
+type: build
2.19.1
