rtems-central appears to be out of sync with rtems and rtems-docs
Joel Sherrill
joel at rtems.org
Tue Aug 30 20:44:37 UTC 2022
Hi
When I am on master of rtems-central.git and sub spec2modules.py, it
generates updates to rtems-docs and rtems. My understanding is that if they
were in sync, there would be no changes in rtems-docs and rtems.
(env) [joel at localhost rtems-central]$ ./spec2modules.py
(env) [joel at localhost rtems-central]$ cd modules/rtems-docs/
(env) [joel at localhost rtems-docs]$ git st
# HEAD detached at 657f744
# Changes not staged for commit:
# (use "git add <file>..." to update what will be committed)
# (use "git checkout -- <file>..." to discard changes in working
directory)
# modified: c-user/config/device-driver.rst
# modified: c-user/config/general.rst
# modified: c-user/config/idle-task.rst
# modified: c-user/glossary.rst
# modified: eng/req/items.rst
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220830/54144d77/attachment.htm>
