rtems-central appears to be out of sync with rtems and rtems-docs
Sebastian Huber
Wed Aug 31 10:00:06 UTC 2022
Hello Joel,
On 30/08/2022 22:44, Joel Sherrill wrote:
> When I am on master of rtems-central.git and sub spec2modules.py, it
> generates updates to rtems-docs and rtems. My understanding is that if
> they were in sync, there would be no changes in rtems-docs and rtems.
> (env) [joel at localhost rtems-central]$ ./spec2modules.py
> (env) [joel at localhost rtems-central]$ cd modules/rtems-docs/
> (env) [joel at localhost rtems-docs]$ git st
> # HEAD detached at 657f744
> # Changes not staged for commit:
> # (use "git add <file>..." to update what will be committed)
> # (use "git checkout -- <file>..." to discard changes in working
> directory)
> # modified: c-user/config/device-driver.rst
> # modified: c-user/config/general.rst
> # modified: c-user/config/idle-task.rst
> # modified: c-user/glossary.rst
> # modified: eng/req/items.rst
I updated rtems-central. There should be no changes in modules/rtems
after the update. The modifications modules/rtems-docs should be now
much smaller. There are still modifications in rtems-docs since I didn't
add a private documentation branch. The integration of these changes got
stuck in:
https://lists.rtems.org/pipermail/devel/2021-September/069453.html
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
