[PATCH 23/27] score/cpu/sparc64: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Feb 25 18:06:08 UTC 2022
cpukit/score/cpu/sparc64/context.S | 25 ++++++++++++++++---
cpukit/score/cpu/sparc64/cpu.c | 25 ++++++++++++++++---
.../cpu/sparc64/include/rtems/score/cpu.h | 25 ++++++++++++++++---
.../sparc64/include/rtems/score/cpuatomic.h | 25 ++++++++++++++++---
.../cpu/sparc64/include/rtems/score/cpuimpl.h | 25 ++++++++++++++++---
.../cpu/sparc64/include/rtems/score/sparc64.h | 25 ++++++++++++++++---
cpukit/score/cpu/sparc64/interrupt.S | 25 ++++++++++++++++---
.../sparc64/sparc64-exception-frame-print.c | 25 ++++++++++++++++---
cpukit/score/cpu/sparc64/sparc64-syscall.S | 25 ++++++++++++++++---
9 files changed, 198 insertions(+), 27 deletions(-)
diff --git a/cpukit/score/cpu/sparc64/context.S b/cpukit/score/cpu/sparc64/context.S
index e83507d6c9..8e9178218f 100644
--- a/cpukit/score/cpu/sparc64/context.S
+++ b/cpukit/score/cpu/sparc64/context.S
@@ -1,3 +1,5 @@
/* context.S
* This file contains the basic algorithms for all assembly code used
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 2010. Gedare Bloom.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#include <rtems/asm.h>
diff --git a/cpukit/score/cpu/sparc64/cpu.c b/cpukit/score/cpu/sparc64/cpu.c
index e8d6017d2c..c93b68a2cc 100644
--- a/cpukit/score/cpu/sparc64/cpu.c
+++ b/cpukit/score/cpu/sparc64/cpu.c
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
* provide support for the SPARC-v9.
+ * are met:
#include <rtems/score/cpuimpl.h>
diff --git a/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
index 1d8813da35..03f6e2aa63 100644
--- a/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc64/include/rtems/score/cpu.h
@@ -1,3 +1,5 @@
* @file
@@ -16,9 +18,26 @@
* to support the SPARC64 processor.
+ * are met:
#ifndef _RTEMS_SCORE_CPU_H
diff --git a/cpukit/score/cpu/sparc64/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/sparc64/include/rtems/score/cpuatomic.h
index 598ee76b20..01bb99cda3 100644
--- a/cpukit/score/cpu/sparc64/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/sparc64/include/rtems/score/cpuatomic.h
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2012-2013 Deng Hengyi.
+ * are met:
#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
diff --git a/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h
index 521612d555..c026687d01 100644
--- a/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -7,9 +9,26 @@
* Copyright (c) 2013 embedded brains GmbH
+ * are met:
#ifndef _RTEMS_SCORE_CPUIMPL_H
diff --git a/cpukit/score/cpu/sparc64/include/rtems/score/sparc64.h b/cpukit/score/cpu/sparc64/include/rtems/score/sparc64.h
index d20c2ff509..14020e75d0 100644
--- a/cpukit/score/cpu/sparc64/include/rtems/score/sparc64.h
+++ b/cpukit/score/cpu/sparc64/include/rtems/score/sparc64.h
@@ -1,3 +1,5 @@
* @file
@@ -15,9 +17,26 @@
+ * are met:
#ifndef _RTEMS_SCORE_SPARC_H
diff --git a/cpukit/score/cpu/sparc64/interrupt.S b/cpukit/score/cpu/sparc64/interrupt.S
index d249b39e8b..70ae679fd2 100644
--- a/cpukit/score/cpu/sparc64/interrupt.S
+++ b/cpukit/score/cpu/sparc64/interrupt.S
@@ -1,3 +1,5 @@
/* cpu_asm.s
@@ -7,9 +9,26 @@
* COPYRIGHT (c) 1989-2007. On-Line Applications Research Corporation (OAR).
+ * are met:
diff --git a/cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c b/cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c
index e54eb60e9f..106f153ba1 100644
--- a/cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c
+++ b/cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c
@@ -1,3 +1,5 @@
* Copyright (c) 2012 embedded brains GmbH. All rights reserved.
@@ -7,9 +9,26 @@
* Germany
* <rtems at embedded-brains.de>
+ * are met:
#ifdef HAVE_CONFIG_H
diff --git a/cpukit/score/cpu/sparc64/sparc64-syscall.S b/cpukit/score/cpu/sparc64/sparc64-syscall.S
index ffd6e8538d..9a467e8922 100644
--- a/cpukit/score/cpu/sparc64/sparc64-syscall.S
+++ b/cpukit/score/cpu/sparc64/sparc64-syscall.S
@@ -1,3 +1,5 @@
* systrap.S
@@ -10,9 +12,26 @@
+ * are met:
2.24.4
