[PATCH 25/27] cpukit/include/adainclude: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Feb 25 18:06:10 UTC 2022
Updates #3053.
cpukit/include/adainclude/rtems-barrier.adb | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-barrier.ads | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-clock.adb | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-clock.ads | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-cpu_usage.ads | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-event.adb | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-event.ads | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-extension.adb | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-extension.ads | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-fatal.adb | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-fatal.ads | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-interrupt.ads | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-io.adb | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-io.ads | 25 ++++++++++++++++---
.../adainclude/rtems-message_queue.adb | 25 ++++++++++++++++---
.../adainclude/rtems-message_queue.ads | 25 ++++++++++++++++---
.../adainclude/rtems-multiprocessing.adb | 25 ++++++++++++++++---
.../adainclude/rtems-multiprocessing.ads | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-object.adb | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-object.ads | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-partition.adb | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-partition.ads | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-port.adb | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-port.ads | 25 ++++++++++++++++---
.../adainclude/rtems-rate_monotonic.adb | 25 ++++++++++++++++---
.../adainclude/rtems-rate_monotonic.ads | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-region.adb | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-region.ads | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-semaphore.adb | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-semaphore.ads | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-signal.adb | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-signal.ads | 25 ++++++++++++++++---
.../adainclude/rtems-stack_checker.ads | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-tasks.adb | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-tasks.ads | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-timer.adb | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems-timer.ads | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems.adb | 25 ++++++++++++++++---
cpukit/include/adainclude/rtems.ads | 25 ++++++++++++++++---
39 files changed, 858 insertions(+), 117 deletions(-)
diff --git a/cpukit/include/adainclude/rtems-barrier.adb b/cpukit/include/adainclude/rtems-barrier.adb
index 18f675bccb..43d2d1c782 100644
--- a/cpukit/include/adainclude/rtems-barrier.adb
+++ b/cpukit/include/adainclude/rtems-barrier.adb
@@ -1,3 +1,5 @@
+-- SPDX-License-Identifier: BSD-2-Clause
-- RTEMS / Body
@@ -13,9 +15,26 @@
-- COPYRIGHT (c) 1997-2011.
-- On-Line Applications Research Corporation (OAR).
--- The license and distribution terms for this file may in
--- the file LICENSE in this distribution or at
--- http://www.rtems.org/license/LICENSE.
+-- Redistribution and use in source and binary forms, with or without
+-- modification, are permitted provided that the following conditions
+-- are met:
+-- 1. Redistributions of source code must retain the above copyright
+-- notice, this list of conditions and the following disclaimer.
+-- 2. Redistributions in binary form must reproduce the above copyright
+-- notice, this list of conditions and the following disclaimer in the
+-- documentation and/or other materials provided with the distribution.
+-- THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+-- AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+-- IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+-- ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+-- LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+-- CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+-- SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+-- INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+-- CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+-- ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+-- POSSIBILITY OF SUCH DAMAGE.
with Ada;
diff --git a/cpukit/include/adainclude/rtems-barrier.ads b/cpukit/include/adainclude/rtems-barrier.ads
index a84778f8da..0ae7ed0325 100644
--- a/cpukit/include/adainclude/rtems-barrier.ads
+++ b/cpukit/include/adainclude/rtems-barrier.ads
@@ -1,3 +1,5 @@
-- RTEMS / Specification
@@ -14,9 +16,26 @@
+-- are met:
with System;
diff --git a/cpukit/include/adainclude/rtems-clock.adb b/cpukit/include/adainclude/rtems-clock.adb
index d6f596a5d5..cc744be293 100644
--- a/cpukit/include/adainclude/rtems-clock.adb
+++ b/cpukit/include/adainclude/rtems-clock.adb
@@ -1,3 +1,5 @@
-- RTEMS / Body
@@ -13,9 +15,26 @@
+-- are met:
package body RTEMS.Clock is
diff --git a/cpukit/include/adainclude/rtems-clock.ads b/cpukit/include/adainclude/rtems-clock.ads
index 12afb42454..d04bb97fce 100644
--- a/cpukit/include/adainclude/rtems-clock.ads
+++ b/cpukit/include/adainclude/rtems-clock.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
diff --git a/cpukit/include/adainclude/rtems-cpu_usage.ads b/cpukit/include/adainclude/rtems-cpu_usage.ads
index 97717587a4..1b0af97833 100644
--- a/cpukit/include/adainclude/rtems-cpu_usage.ads
+++ b/cpukit/include/adainclude/rtems-cpu_usage.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
with System;
diff --git a/cpukit/include/adainclude/rtems-event.adb b/cpukit/include/adainclude/rtems-event.adb
index 4e92976903..1e6cd8b274 100644
--- a/cpukit/include/adainclude/rtems-event.adb
+++ b/cpukit/include/adainclude/rtems-event.adb
@@ -1,3 +1,5 @@
-- RTEMS / Body
@@ -13,9 +15,26 @@
+-- are met:
package body RTEMS.Event is
diff --git a/cpukit/include/adainclude/rtems-event.ads b/cpukit/include/adainclude/rtems-event.ads
index 1851336bba..79de5ee16c 100644
--- a/cpukit/include/adainclude/rtems-event.ads
+++ b/cpukit/include/adainclude/rtems-event.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
package RTEMS.Event is
diff --git a/cpukit/include/adainclude/rtems-extension.adb b/cpukit/include/adainclude/rtems-extension.adb
index a2540c74d4..f3d71a1176 100644
--- a/cpukit/include/adainclude/rtems-extension.adb
+++ b/cpukit/include/adainclude/rtems-extension.adb
@@ -1,3 +1,5 @@
-- RTEMS / Body
@@ -13,9 +15,26 @@
+-- are met:
package body RTEMS.Extension is
diff --git a/cpukit/include/adainclude/rtems-extension.ads b/cpukit/include/adainclude/rtems-extension.ads
index 18111d99b3..da6a4c9c1e 100644
--- a/cpukit/include/adainclude/rtems-extension.ads
+++ b/cpukit/include/adainclude/rtems-extension.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
package RTEMS.Extension is
diff --git a/cpukit/include/adainclude/rtems-fatal.adb b/cpukit/include/adainclude/rtems-fatal.adb
index 5231d7d8c7..52f9a25638 100644
--- a/cpukit/include/adainclude/rtems-fatal.adb
+++ b/cpukit/include/adainclude/rtems-fatal.adb
@@ -1,3 +1,5 @@
-- RTEMS / Body
@@ -13,9 +15,26 @@
+-- are met:
package body RTEMS.Fatal is
diff --git a/cpukit/include/adainclude/rtems-fatal.ads b/cpukit/include/adainclude/rtems-fatal.ads
index 8518b7ba0e..9d9bf9e0b5 100644
--- a/cpukit/include/adainclude/rtems-fatal.ads
+++ b/cpukit/include/adainclude/rtems-fatal.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
package RTEMS.Fatal is
diff --git a/cpukit/include/adainclude/rtems-interrupt.ads b/cpukit/include/adainclude/rtems-interrupt.ads
index 02b6c80a46..ec64045f79 100644
--- a/cpukit/include/adainclude/rtems-interrupt.ads
+++ b/cpukit/include/adainclude/rtems-interrupt.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
package RTEMS.Interrupt is
diff --git a/cpukit/include/adainclude/rtems-io.adb b/cpukit/include/adainclude/rtems-io.adb
index d6d4f0cd10..41a315c93a 100644
--- a/cpukit/include/adainclude/rtems-io.adb
+++ b/cpukit/include/adainclude/rtems-io.adb
@@ -1,3 +1,5 @@
-- RTEMS / Body
@@ -13,9 +15,26 @@
+-- are met:
with Ada;
diff --git a/cpukit/include/adainclude/rtems-io.ads b/cpukit/include/adainclude/rtems-io.ads
index 2a599023b5..0dc9c32411 100644
--- a/cpukit/include/adainclude/rtems-io.ads
+++ b/cpukit/include/adainclude/rtems-io.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
with System;
diff --git a/cpukit/include/adainclude/rtems-message_queue.adb b/cpukit/include/adainclude/rtems-message_queue.adb
index 7437670554..fd43febfc0 100644
--- a/cpukit/include/adainclude/rtems-message_queue.adb
+++ b/cpukit/include/adainclude/rtems-message_queue.adb
@@ -1,3 +1,5 @@
-- RTEMS / Body
@@ -13,9 +15,26 @@
+-- are met:
package body RTEMS.Message_Queue is
diff --git a/cpukit/include/adainclude/rtems-message_queue.ads b/cpukit/include/adainclude/rtems-message_queue.ads
index 929b659d75..a59ce17326 100644
--- a/cpukit/include/adainclude/rtems-message_queue.ads
+++ b/cpukit/include/adainclude/rtems-message_queue.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
package RTEMS.Message_Queue is
diff --git a/cpukit/include/adainclude/rtems-multiprocessing.adb b/cpukit/include/adainclude/rtems-multiprocessing.adb
index 805975814c..9d5c7bc8ac 100644
--- a/cpukit/include/adainclude/rtems-multiprocessing.adb
+++ b/cpukit/include/adainclude/rtems-multiprocessing.adb
@@ -1,3 +1,5 @@
-- RTEMS Multiprocessing Manager/ Body
@@ -12,9 +14,26 @@
-- COPYRIGHT (c) 1997.
+-- are met:
package body RTEMS.Multiprocessing is
diff --git a/cpukit/include/adainclude/rtems-multiprocessing.ads b/cpukit/include/adainclude/rtems-multiprocessing.ads
index cb462f1e94..a91d646c71 100644
--- a/cpukit/include/adainclude/rtems-multiprocessing.ads
+++ b/cpukit/include/adainclude/rtems-multiprocessing.ads
@@ -1,3 +1,5 @@
-- RTEMS Multiprocessing Manager/ Specification
@@ -12,9 +14,26 @@
+-- are met:
package RTEMS.Multiprocessing is
diff --git a/cpukit/include/adainclude/rtems-object.adb b/cpukit/include/adainclude/rtems-object.adb
index 7be02ecd4c..28cf1440a1 100644
--- a/cpukit/include/adainclude/rtems-object.adb
+++ b/cpukit/include/adainclude/rtems-object.adb
@@ -1,3 +1,5 @@
-- RTEMS / Body
@@ -13,9 +15,26 @@
+-- are met:
with Interfaces; use Interfaces;
diff --git a/cpukit/include/adainclude/rtems-object.ads b/cpukit/include/adainclude/rtems-object.ads
index 93636eab74..cec5894479 100644
--- a/cpukit/include/adainclude/rtems-object.ads
+++ b/cpukit/include/adainclude/rtems-object.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
package RTEMS.Object is
diff --git a/cpukit/include/adainclude/rtems-partition.adb b/cpukit/include/adainclude/rtems-partition.adb
index 3530092334..6acf7771e3 100644
--- a/cpukit/include/adainclude/rtems-partition.adb
+++ b/cpukit/include/adainclude/rtems-partition.adb
@@ -1,3 +1,5 @@
-- RTEMS / Body
@@ -13,9 +15,26 @@
+-- are met:
package body RTEMS.Partition is
diff --git a/cpukit/include/adainclude/rtems-partition.ads b/cpukit/include/adainclude/rtems-partition.ads
index 3972fe957c..83cd6118db 100644
--- a/cpukit/include/adainclude/rtems-partition.ads
+++ b/cpukit/include/adainclude/rtems-partition.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
package RTEMS.Partition is
diff --git a/cpukit/include/adainclude/rtems-port.adb b/cpukit/include/adainclude/rtems-port.adb
index dda655b8c2..4cc0dd787a 100644
--- a/cpukit/include/adainclude/rtems-port.adb
+++ b/cpukit/include/adainclude/rtems-port.adb
@@ -1,3 +1,5 @@
-- RTEMS / Body
@@ -13,9 +15,26 @@
+-- are met:
package body RTEMS.Port is
diff --git a/cpukit/include/adainclude/rtems-port.ads b/cpukit/include/adainclude/rtems-port.ads
index cd29eb8a1e..f3cb0e301c 100644
--- a/cpukit/include/adainclude/rtems-port.ads
+++ b/cpukit/include/adainclude/rtems-port.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
package RTEMS.Port is
diff --git a/cpukit/include/adainclude/rtems-rate_monotonic.adb b/cpukit/include/adainclude/rtems-rate_monotonic.adb
index 2eb462b71a..e518401ab8 100644
--- a/cpukit/include/adainclude/rtems-rate_monotonic.adb
+++ b/cpukit/include/adainclude/rtems-rate_monotonic.adb
@@ -1,3 +1,5 @@
-- RTEMS / Body
@@ -13,9 +15,26 @@
+-- are met:
package body RTEMS.Rate_Monotonic is
diff --git a/cpukit/include/adainclude/rtems-rate_monotonic.ads b/cpukit/include/adainclude/rtems-rate_monotonic.ads
index 5830f1d6f8..f2f8bdcbd2 100644
--- a/cpukit/include/adainclude/rtems-rate_monotonic.ads
+++ b/cpukit/include/adainclude/rtems-rate_monotonic.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
package RTEMS.Rate_Monotonic is
diff --git a/cpukit/include/adainclude/rtems-region.adb b/cpukit/include/adainclude/rtems-region.adb
index e1425b8496..73ca6d47b6 100644
--- a/cpukit/include/adainclude/rtems-region.adb
+++ b/cpukit/include/adainclude/rtems-region.adb
@@ -1,3 +1,5 @@
-- RTEMS / Body
@@ -13,9 +15,26 @@
+-- are met:
package body RTEMS.Region is
diff --git a/cpukit/include/adainclude/rtems-region.ads b/cpukit/include/adainclude/rtems-region.ads
index 753588d7a8..0027787b79 100644
--- a/cpukit/include/adainclude/rtems-region.ads
+++ b/cpukit/include/adainclude/rtems-region.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
package RTEMS.Region is
diff --git a/cpukit/include/adainclude/rtems-semaphore.adb b/cpukit/include/adainclude/rtems-semaphore.adb
index 4dad4556f3..dc86527f70 100644
--- a/cpukit/include/adainclude/rtems-semaphore.adb
+++ b/cpukit/include/adainclude/rtems-semaphore.adb
@@ -1,3 +1,5 @@
-- RTEMS / Body
@@ -13,9 +15,26 @@
+-- are met:
package body RTEMS.Semaphore is
diff --git a/cpukit/include/adainclude/rtems-semaphore.ads b/cpukit/include/adainclude/rtems-semaphore.ads
index 916ef0489e..c0b2ef6859 100644
--- a/cpukit/include/adainclude/rtems-semaphore.ads
+++ b/cpukit/include/adainclude/rtems-semaphore.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
with RTEMS.Tasks;
diff --git a/cpukit/include/adainclude/rtems-signal.adb b/cpukit/include/adainclude/rtems-signal.adb
index 873e73fbb8..a70eacf9c1 100644
--- a/cpukit/include/adainclude/rtems-signal.adb
+++ b/cpukit/include/adainclude/rtems-signal.adb
@@ -1,3 +1,5 @@
-- RTEMS / Body
@@ -13,9 +15,26 @@
+-- are met:
package body RTEMS.Signal is
diff --git a/cpukit/include/adainclude/rtems-signal.ads b/cpukit/include/adainclude/rtems-signal.ads
index 92ca921fa2..5cc7f6c162 100644
--- a/cpukit/include/adainclude/rtems-signal.ads
+++ b/cpukit/include/adainclude/rtems-signal.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
package RTEMS.Signal is
diff --git a/cpukit/include/adainclude/rtems-stack_checker.ads b/cpukit/include/adainclude/rtems-stack_checker.ads
index 6e14bd5d46..8901ea1412 100644
--- a/cpukit/include/adainclude/rtems-stack_checker.ads
+++ b/cpukit/include/adainclude/rtems-stack_checker.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
with System;
diff --git a/cpukit/include/adainclude/rtems-tasks.adb b/cpukit/include/adainclude/rtems-tasks.adb
index bc34af681b..a9dd334581 100644
--- a/cpukit/include/adainclude/rtems-tasks.adb
+++ b/cpukit/include/adainclude/rtems-tasks.adb
@@ -1,3 +1,5 @@
-- RTEMS / Body
@@ -13,9 +15,26 @@
-- COPYRIGHT (c) 1997-2008.
+-- are met:
package body RTEMS.Tasks is
diff --git a/cpukit/include/adainclude/rtems-tasks.ads b/cpukit/include/adainclude/rtems-tasks.ads
index ca249961b5..6d6255a28f 100644
--- a/cpukit/include/adainclude/rtems-tasks.ads
+++ b/cpukit/include/adainclude/rtems-tasks.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
package RTEMS.Tasks is
diff --git a/cpukit/include/adainclude/rtems-timer.adb b/cpukit/include/adainclude/rtems-timer.adb
index c6f115d863..d5d99b3efd 100644
--- a/cpukit/include/adainclude/rtems-timer.adb
+++ b/cpukit/include/adainclude/rtems-timer.adb
@@ -1,3 +1,5 @@
-- RTEMS / Body
@@ -13,9 +15,26 @@
+-- are met:
package body RTEMS.Timer is
diff --git a/cpukit/include/adainclude/rtems-timer.ads b/cpukit/include/adainclude/rtems-timer.ads
index de00c3f305..88daa1c5b7 100644
--- a/cpukit/include/adainclude/rtems-timer.ads
+++ b/cpukit/include/adainclude/rtems-timer.ads
@@ -1,3 +1,5 @@
@@ -14,9 +16,26 @@
+-- are met:
with RTEMS.Tasks;
diff --git a/cpukit/include/adainclude/rtems.adb b/cpukit/include/adainclude/rtems.adb
index d88f1827b4..97aa34d167 100644
--- a/cpukit/include/adainclude/rtems.adb
+++ b/cpukit/include/adainclude/rtems.adb
@@ -1,3 +1,5 @@
-- RTEMS / Body
-- DESCRIPTION:
@@ -12,9 +14,26 @@
+-- are met:
with Ada;
diff --git a/cpukit/include/adainclude/rtems.ads b/cpukit/include/adainclude/rtems.ads
index 0b4b3e7e5f..1eb67592dc 100644
--- a/cpukit/include/adainclude/rtems.ads
+++ b/cpukit/include/adainclude/rtems.ads
@@ -1,3 +1,5 @@
-- DESCRIPTION:
@@ -13,9 +15,26 @@
+-- are met:
with System;
2.24.4
