[PATCH 26/27] cpukit/ftpd: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Feb 25 18:06:11 UTC 2022
Not all files could be changed.
Updates #3053.
cpukit/ftpd/ftpd-init.c | 25 ++++++++++++++++++++++---
1 file changed, 22 insertions(+), 3 deletions(-)
diff --git a/cpukit/ftpd/ftpd-init.c b/cpukit/ftpd/ftpd-init.c
index dcc7b6178c..cf781425fb 100644
--- a/cpukit/ftpd/ftpd-init.c
+++ b/cpukit/ftpd/ftpd-init.c
@@ -1,9 +1,28 @@
* Copyright (c) 2018 embedded brains GmbH. All rights reserved.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
2.24.4
