[PATCH 24/27] score/cpu/v850: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Feb 25 18:06:09 UTC 2022
Updates #3053.
cpukit/score/cpu/v850/cpu.c | 25 ++++++++++++++++---
cpukit/score/cpu/v850/cpu_asm.S | 25 ++++++++++++++++---
.../score/cpu/v850/include/rtems/score/cpu.h | 25 ++++++++++++++++---
.../cpu/v850/include/rtems/score/cpu_asm.h | 25 ++++++++++++++++---
.../cpu/v850/include/rtems/score/cpuatomic.h | 25 ++++++++++++++++---
.../cpu/v850/include/rtems/score/cpuimpl.h | 25 ++++++++++++++++---
.../score/cpu/v850/include/rtems/score/v850.h | 25 ++++++++++++++++---
.../cpu/v850/v850-exception-frame-print.c | 25 ++++++++++++++++---
8 files changed, 176 insertions(+), 24 deletions(-)
diff --git a/cpukit/score/cpu/v850/cpu.c b/cpukit/score/cpu/v850/cpu.c
index d659d9257e..e61874f9c1 100644
--- a/cpukit/score/cpu/v850/cpu.c
+++ b/cpukit/score/cpu/v850/cpu.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
* COPYRIGHT (c) 1989-2012.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/cpukit/score/cpu/v850/cpu_asm.S b/cpukit/score/cpu/v850/cpu_asm.S
index e9aa738d13..579d26bcee 100644
--- a/cpukit/score/cpu/v850/cpu_asm.S
+++ b/cpukit/score/cpu/v850/cpu_asm.S
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpu.h b/cpukit/score/cpu/v850/include/rtems/score/cpu.h
index 6bf69de3e6..958bed5dc3 100644
--- a/cpukit/score/cpu/v850/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/include/rtems/score/cpu.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_SCORE_CPU_H
diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpu_asm.h b/cpukit/score/cpu/v850/include/rtems/score/cpu_asm.h
index 8a74cc6410..87a91c6052 100644
--- a/cpukit/score/cpu/v850/include/rtems/score/cpu_asm.h
+++ b/cpukit/score/cpu/v850/include/rtems/score/cpu_asm.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_SCORE_CPU_ASM_H
diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/v850/include/rtems/score/cpuatomic.h
index 598ee76b20..01bb99cda3 100644
--- a/cpukit/score/cpu/v850/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/v850/include/rtems/score/cpuatomic.h
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2012-2013 Deng Hengyi.
+ * are met:
#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
index 2e95738ed6..23c1437ba0 100644
--- a/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -7,9 +9,26 @@
* Copyright (c) 2013 embedded brains GmbH
+ * are met:
#ifndef _RTEMS_SCORE_CPUIMPL_H
diff --git a/cpukit/score/cpu/v850/include/rtems/score/v850.h b/cpukit/score/cpu/v850/include/rtems/score/v850.h
index 26ab6c209d..9b9729d16e 100644
--- a/cpukit/score/cpu/v850/include/rtems/score/v850.h
+++ b/cpukit/score/cpu/v850/include/rtems/score/v850.h
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
+ * are met:
#ifndef _RTEMS_SCORE_V850_H
diff --git a/cpukit/score/cpu/v850/v850-exception-frame-print.c b/cpukit/score/cpu/v850/v850-exception-frame-print.c
index e54eb60e9f..106f153ba1 100644
--- a/cpukit/score/cpu/v850/v850-exception-frame-print.c
+++ b/cpukit/score/cpu/v850/v850-exception-frame-print.c
@@ -1,3 +1,5 @@
* Copyright (c) 2012 embedded brains GmbH. All rights reserved.
@@ -7,9 +9,26 @@
* Germany
* <rtems at embedded-brains.de>
+ * are met:
2.24.4
