[PATCH 2/2] cpukit/aarch64: Add Per_CPU_Control accessor
Kinsey Moore kinsey.moore at oarcorp.com
Fri Feb 25 23:33:08 UTC 2022
Add an architecture-specific implementation for
_CPU_Get_current_per_CPU_control() to reduce overhead for getting the
current CPU's Per_CPU_Control structure.
 .../cpu/aarch64/include/rtems/score/cpuimpl.h | 23 +++++++++++++++++++
 1 file changed, 23 insertions(+)
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
index 90fd48ad4e..ffdef2f30a 100644
--- a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
@@ -125,6 +125,29 @@ typedef struct {
   uint64_t register_fpcr;
 } CPU_Interrupt_frame;
+#ifdef RTEMS_SMP
+static inline
+struct Per_CPU_Control *_AARCH64_Get_current_per_CPU_control( void )
+  struct Per_CPU_Control *cpu_self;
+  uint64_t value;
+  __asm__ volatile (
+    "mrs %0, TPIDR_EL1" : "=&r" ( value ) : : "memory"
+  /* Use EL1 Thread ID Register (TPIDR_EL1) */
+  cpu_self = (struct Per_CPU_Control *)(uintptr_t)value;
+  return cpu_self;
+#define _CPU_Get_current_per_CPU_control() \
+  _AARCH64_Get_current_per_CPU_control()
+#endif /* RTEMS_SMP */
 void _CPU_Context_volatile_clobber( uintptr_t pattern );
 void _CPU_Context_validate( uintptr_t pattern );
2.30.2
