[PATCH 22/27] score/cpu/sparc: Change license to BSD-2
Fri Feb 25 18:06:07 UTC 2022
Updates #3053.
 cpukit/score/cpu/sparc/access_le.c            | 25 ++++++++++++++++---
 cpukit/score/cpu/sparc/cpu.c                  | 25 ++++++++++++++++---
 cpukit/score/cpu/sparc/cpu_asm.S              | 25 ++++++++++++++++---
 .../score/cpu/sparc/include/libcpu/access.h   | 25 ++++++++++++++++---
 .../cpu/sparc/include/libcpu/byteorder.h      | 25 ++++++++++++++++---
 .../score/cpu/sparc/include/rtems/score/cpu.h | 25 ++++++++++++++++---
 .../cpu/sparc/include/rtems/score/cpuatomic.h | 25 ++++++++++++++++---
 .../cpu/sparc/include/rtems/score/cpuimpl.h   | 25 ++++++++++++++++---
 .../cpu/sparc/include/rtems/score/sparc.h     | 25 ++++++++++++++++---
 .../cpu/sparc/include/rtems/score/sparcimpl.h | 25 ++++++++++++++++---
 cpukit/score/cpu/sparc/sparc-access.S         | 25 ++++++++++++++++---
 .../score/cpu/sparc/sparc-context-validate.S  | 25 ++++++++++++++++---
 .../sparc/sparc-context-volatile-clobber.S    | 25 ++++++++++++++++---
 cpukit/score/cpu/sparc/sparc-counter-asm.S    | 25 ++++++++++++++++---
 cpukit/score/cpu/sparc/sparc-isr-handler.S    | 25 ++++++++++++++++---
 cpukit/score/cpu/sparc/sparc-isr-install.c    | 25 ++++++++++++++++---
 16 files changed, 352 insertions(+), 48 deletions(-)
diff --git a/cpukit/score/cpu/sparc/access_le.c b/cpukit/score/cpu/sparc/access_le.c
index d3a0e93adb..b1bde6da4b 100644
--- a/cpukit/score/cpu/sparc/access_le.c
+++ b/cpukit/score/cpu/sparc/access_le.c
@@ -1,12 +1,31 @@
  *  Little-endian access routines for SPARC
  *  COPYRIGHT (c) 2011
  *  Aeroflex Gaisler.
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #include <libcpu/byteorder.h>
diff --git a/cpukit/score/cpu/sparc/cpu.c b/cpukit/score/cpu/sparc/cpu.c
index 10ad44049a..b910d96d8d 100644
--- a/cpukit/score/cpu/sparc/cpu.c
+++ b/cpukit/score/cpu/sparc/cpu.c
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
  *  Copyright (c) 2017 embedded brains GmbH
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/cpukit/score/cpu/sparc/cpu_asm.S b/cpukit/score/cpu/sparc/cpu_asm.S
index afd9b9644b..af54e273b2 100644
--- a/cpukit/score/cpu/sparc/cpu_asm.S
+++ b/cpukit/score/cpu/sparc/cpu_asm.S
@@ -1,3 +1,5 @@
 /*  cpu_asm.s
  *  This file contains the basic algorithms for all assembly code used
@@ -9,9 +11,26 @@
  *  Copyright (c) 2014, 2017 embedded brains GmbH
+ * are met:
  *  Ported to ERC32 implementation of the SPARC by On-Line Applications
  *  Research Corporation (OAR) under contract to the European Space
diff --git a/cpukit/score/cpu/sparc/include/libcpu/access.h b/cpukit/score/cpu/sparc/include/libcpu/access.h
index 4f2a780895..f414d6f22f 100644
--- a/cpukit/score/cpu/sparc/include/libcpu/access.h
+++ b/cpukit/score/cpu/sparc/include/libcpu/access.h
@@ -1,12 +1,31 @@
  *  access.h  - access routines for SPARC. SPARC is big endian only.
  *  Aeroflex Gaisler.
+ * are met:
 #ifndef _LIBCPU_ACCESS_H
diff --git a/cpukit/score/cpu/sparc/include/libcpu/byteorder.h b/cpukit/score/cpu/sparc/include/libcpu/byteorder.h
index 6726a785f8..38b1f18f63 100644
--- a/cpukit/score/cpu/sparc/include/libcpu/byteorder.h
+++ b/cpukit/score/cpu/sparc/include/libcpu/byteorder.h
@@ -1,12 +1,31 @@
  *  byteorder.h  - Endian conversion for SPARC. SPARC is big endian only.
  *  Aeroflex Gaisler.
+ * are met:
 #ifndef _LIBCPU_BYTEORDER_H
diff --git a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
index af15f35b62..225eaf96c6 100644
--- a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
@@ -1,3 +1,5 @@
  * @file
@@ -11,9 +13,26 @@
  *  COPYRIGHT (c) 1989-2011.
  *  On-Line Applications Research Corporation (OAR).
+ * are met:
 #ifndef _RTEMS_SCORE_CPU_H
diff --git a/cpukit/score/cpu/sparc/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/sparc/include/rtems/score/cpuatomic.h
index 598ee76b20..01bb99cda3 100644
--- a/cpukit/score/cpu/sparc/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/sparc/include/rtems/score/cpuatomic.h
@@ -1,9 +1,28 @@
  * COPYRIGHT (c) 2012-2013 Deng Hengyi.
+ * are met:
 #ifndef _RTEMS_SCORE_ATOMIC_CPU_H
diff --git a/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h
index 14038cbdbe..7197eb960e 100644
--- a/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h
@@ -1,3 +1,5 @@
  * @file
@@ -8,9 +10,26 @@
  * Copyright (c) 1989, 2007 On-Line Applications Research Corporation (OAR)
  * Copyright (c) 2013, 2016 embedded brains GmbH
+ * are met:
 #ifndef _RTEMS_SCORE_CPUIMPL_H
diff --git a/cpukit/score/cpu/sparc/include/rtems/score/sparc.h b/cpukit/score/cpu/sparc/include/rtems/score/sparc.h
index 166e89d58a..4ac3cc48c9 100644
--- a/cpukit/score/cpu/sparc/include/rtems/score/sparc.h
+++ b/cpukit/score/cpu/sparc/include/rtems/score/sparc.h
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
+ * are met:
 #ifndef _RTEMS_SCORE_SPARC_H
diff --git a/cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h b/cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h
index edc03bd074..1f7f64dc94 100644
--- a/cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h
+++ b/cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h
@@ -1,3 +1,5 @@
  * Copyright (c) 2016, 2018 embedded brains GmbH.  All rights reserved.
@@ -7,9 +9,26 @@
  *  Germany
  *  <rtems at embedded-brains.de>
+ * are met:
 #ifndef _RTEMS_SCORE_SPARCIMPL_H
diff --git a/cpukit/score/cpu/sparc/sparc-access.S b/cpukit/score/cpu/sparc/sparc-access.S
index 277fb7e652..e6628d9eb7 100644
--- a/cpukit/score/cpu/sparc/sparc-access.S
+++ b/cpukit/score/cpu/sparc/sparc-access.S
@@ -1,3 +1,5 @@
  *  Optimized access routines for SPARC.
@@ -16,9 +18,26 @@
  *  Aeroflex Gaisler.
+ * are met:
 #include <rtems/asm.h>
diff --git a/cpukit/score/cpu/sparc/sparc-context-validate.S b/cpukit/score/cpu/sparc/sparc-context-validate.S
index 8bc116d700..3c6200347b 100644
--- a/cpukit/score/cpu/sparc/sparc-context-validate.S
+++ b/cpukit/score/cpu/sparc/sparc-context-validate.S
@@ -1,3 +1,5 @@
  * Copyright (c) 2015, 2017 embedded brains GmbH.  All rights reserved.
@@ -7,9 +9,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S b/cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S
index 716bcf2884..540a9173fa 100644
--- a/cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S
+++ b/cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S
@@ -1,3 +1,5 @@
  * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
@@ -7,9 +9,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/sparc/sparc-counter-asm.S b/cpukit/score/cpu/sparc/sparc-counter-asm.S
index 44c3fa8edb..ff57a9f1eb 100644
--- a/cpukit/score/cpu/sparc/sparc-counter-asm.S
+++ b/cpukit/score/cpu/sparc/sparc-counter-asm.S
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/sparc/sparc-isr-handler.S b/cpukit/score/cpu/sparc/sparc-isr-handler.S
index 068fad1e84..264f839f2d 100644
--- a/cpukit/score/cpu/sparc/sparc-isr-handler.S
+++ b/cpukit/score/cpu/sparc/sparc-isr-handler.S
@@ -1,3 +1,5 @@
  *  in an specific CPU port of RTEMS.  These algorithms must be implemented
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/score/cpu/sparc/sparc-isr-install.c b/cpukit/score/cpu/sparc/sparc-isr-install.c
index 017173c489..3c8208ef24 100644
--- a/cpukit/score/cpu/sparc/sparc-isr-install.c
+++ b/cpukit/score/cpu/sparc/sparc-isr-install.c
@@ -1,3 +1,5 @@
  * @file
@@ -11,9 +13,26 @@
  *  COPYRIGHT (c) 1989-2007.
+ * are met:
2.24.4
