[PATCH 20/27] score/cpu/or1k: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Feb 25 18:06:05 UTC 2022
cpukit/score/cpu/or1k/cpu.c | 25 ++++++++++++++++---
.../score/cpu/or1k/include/rtems/score/cpu.h | 25 ++++++++++++++++---
.../cpu/or1k/include/rtems/score/cpu_asm.h | 25 ++++++++++++++++---
.../cpu/or1k/include/rtems/score/cpuatomic.h | 25 ++++++++++++++++---
.../cpu/or1k/include/rtems/score/cpuimpl.h | 25 ++++++++++++++++---
.../or1k/include/rtems/score/or1k-utility.h | 25 ++++++++++++++++---
.../score/cpu/or1k/include/rtems/score/or1k.h | 25 ++++++++++++++++---
.../score/cpu/or1k/or1k-context-initialize.c | 25 ++++++++++++++++---
cpukit/score/cpu/or1k/or1k-context-switch.S | 25 ++++++++++++++++---
cpukit/score/cpu/or1k/or1k-context-validate.S | 25 ++++++++++++++++---
.../cpu/or1k/or1k-context-volatile-clobber.S | 25 ++++++++++++++++---
.../score/cpu/or1k/or1k-exception-default.c | 25 ++++++++++++++++---
.../cpu/or1k/or1k-exception-frame-print.c | 25 ++++++++++++++++---
.../cpu/or1k/or1k-exception-handler-low.S | 25 ++++++++++++++++---
14 files changed, 308 insertions(+), 42 deletions(-)
diff --git a/cpukit/score/cpu/or1k/cpu.c b/cpukit/score/cpu/or1k/cpu.c
index 785fb2a084..507e1d7104 100644
--- a/cpukit/score/cpu/or1k/cpu.c
+++ b/cpukit/score/cpu/or1k/cpu.c
@@ -1,3 +1,5 @@
* Opencore OR1K CPU Dependent Source
@@ -5,9 +7,26 @@
* COPYRIGHT (c) 1989-1999.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
index 02a574affa..83d46010ba 100644
--- a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
+ * are met:
* This file adapted from no_cpu example of the RTEMS distribution.
* The body has been modified for the Opencores OR1k implementation by
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpu_asm.h b/cpukit/score/cpu/or1k/include/rtems/score/cpu_asm.h
index a5659f35ce..601508c153 100644
--- a/cpukit/score/cpu/or1k/include/rtems/score/cpu_asm.h
+++ b/cpukit/score/cpu/or1k/include/rtems/score/cpu_asm.h
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/or1k/include/rtems/score/cpuatomic.h
index 598ee76b20..01bb99cda3 100644
--- a/cpukit/score/cpu/or1k/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/or1k/include/rtems/score/cpuatomic.h
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2012-2013 Deng Hengyi.
+ * are met:
#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h
index ace9273da9..37cd1db436 100644
--- a/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -7,9 +9,26 @@
* Copyright (c) 2013 embedded brains GmbH
+ * are met:
#ifndef _RTEMS_SCORE_CPUIMPL_H
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/or1k-utility.h b/cpukit/score/cpu/or1k/include/rtems/score/or1k-utility.h
index 98bbe41b00..c7618c9355 100644
--- a/cpukit/score/cpu/or1k/include/rtems/score/or1k-utility.h
+++ b/cpukit/score/cpu/or1k/include/rtems/score/or1k-utility.h
@@ -1,3 +1,5 @@
* @file
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 2014 Hesham ALMatary <heshamelmatary at gmail.com>
+ * are met:
#ifndef _RTEMS_SCORE_OR1K_UTILITY_H
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/or1k.h b/cpukit/score/cpu/or1k/include/rtems/score/or1k.h
index 01ba05c15e..974f21f190 100644
--- a/cpukit/score/cpu/or1k/include/rtems/score/or1k.h
+++ b/cpukit/score/cpu/or1k/include/rtems/score/or1k.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
* COPYRIGHT (c) 1989-1999, 2010.
+ * are met:
#ifndef _RTEMS_SCORE_OR1K_H
diff --git a/cpukit/score/cpu/or1k/or1k-context-initialize.c b/cpukit/score/cpu/or1k/or1k-context-initialize.c
index ade23b949c..49a5ff1079 100644
--- a/cpukit/score/cpu/or1k/or1k-context-initialize.c
+++ b/cpukit/score/cpu/or1k/or1k-context-initialize.c
@@ -1,12 +1,31 @@
* COPYRIGHT (c) 1989-2006
+ * are met:
#ifdef HAVE_CONFIG_H
diff --git a/cpukit/score/cpu/or1k/or1k-context-switch.S b/cpukit/score/cpu/or1k/or1k-context-switch.S
index 4c8b422d7f..0bcadbe3b5 100644
--- a/cpukit/score/cpu/or1k/or1k-context-switch.S
+++ b/cpukit/score/cpu/or1k/or1k-context-switch.S
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/cpukit/score/cpu/or1k/or1k-context-validate.S b/cpukit/score/cpu/or1k/or1k-context-validate.S
index 5b2afbb44a..286f4027cd 100644
--- a/cpukit/score/cpu/or1k/or1k-context-validate.S
+++ b/cpukit/score/cpu/or1k/or1k-context-validate.S
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/cpukit/score/cpu/or1k/or1k-context-volatile-clobber.S b/cpukit/score/cpu/or1k/or1k-context-volatile-clobber.S
index 669a937e07..f43ec0ccf0 100644
--- a/cpukit/score/cpu/or1k/or1k-context-volatile-clobber.S
+++ b/cpukit/score/cpu/or1k/or1k-context-volatile-clobber.S
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/cpukit/score/cpu/or1k/or1k-exception-default.c b/cpukit/score/cpu/or1k/or1k-exception-default.c
index a85ef1c7a7..c7e5cb5b82 100644
--- a/cpukit/score/cpu/or1k/or1k-exception-default.c
+++ b/cpukit/score/cpu/or1k/or1k-exception-default.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/cpukit/score/cpu/or1k/or1k-exception-frame-print.c b/cpukit/score/cpu/or1k/or1k-exception-frame-print.c
index a35ee8a900..dbeb5bab04 100644
--- a/cpukit/score/cpu/or1k/or1k-exception-frame-print.c
+++ b/cpukit/score/cpu/or1k/or1k-exception-frame-print.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/cpukit/score/cpu/or1k/or1k-exception-handler-low.S b/cpukit/score/cpu/or1k/or1k-exception-handler-low.S
index 5bf6492946..55c220d41c 100644
--- a/cpukit/score/cpu/or1k/or1k-exception-handler-low.S
+++ b/cpukit/score/cpu/or1k/or1k-exception-handler-low.S
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
2.24.4
