[PATCH 19/27] score/cpu/no_cpu: Change license to BSD-2
Fri Feb 25 18:06:04 UTC 2022
Updates #3053.
 cpukit/score/cpu/no_cpu/cpu.c                 | 25 ++++++++++++++++---
 cpukit/score/cpu/no_cpu/cpu_asm.c             | 25 ++++++++++++++++---
 cpukit/score/cpu/no_cpu/cpucounterfrequency.c | 25 ++++++++++++++++---
 cpukit/score/cpu/no_cpu/cpucounterread.c      | 25 ++++++++++++++++---
 cpukit/score/cpu/no_cpu/cpuidle.c             | 25 ++++++++++++++++---
 .../cpu/no_cpu/include/rtems/score/cpu.h      | 25 ++++++++++++++++---
 .../cpu/no_cpu/include/rtems/score/cpu_asm.h  | 25 ++++++++++++++++---
 .../cpu/no_cpu/include/rtems/score/cpuimpl.h  | 25 ++++++++++++++++---
 .../cpu/no_cpu/include/rtems/score/no_cpu.h   | 25 ++++++++++++++++---
 9 files changed, 198 insertions(+), 27 deletions(-)
diff --git a/cpukit/score/cpu/no_cpu/cpu.c b/cpukit/score/cpu/no_cpu/cpu.c
index 34e1c99a61..8d3a17d88e 100644
--- a/cpukit/score/cpu/no_cpu/cpu.c
+++ b/cpukit/score/cpu/no_cpu/cpu.c
@@ -1,3 +1,5 @@
  *  @file
@@ -8,9 +10,26 @@
  *  COPYRIGHT (c) 1989-1999.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/cpukit/score/cpu/no_cpu/cpu_asm.c b/cpukit/score/cpu/no_cpu/cpu_asm.c
index 1583cb4a40..36474b28a5 100644
--- a/cpukit/score/cpu/no_cpu/cpu_asm.c
+++ b/cpukit/score/cpu/no_cpu/cpu_asm.c
@@ -1,3 +1,5 @@
  *  @file
@@ -15,9 +17,26 @@
+ * are met:
diff --git a/cpukit/score/cpu/no_cpu/cpucounterfrequency.c b/cpukit/score/cpu/no_cpu/cpucounterfrequency.c
index bbb8c127fe..89d1113708 100644
--- a/cpukit/score/cpu/no_cpu/cpucounterfrequency.c
+++ b/cpukit/score/cpu/no_cpu/cpucounterfrequency.c
@@ -1,3 +1,5 @@
  * Copyright (c) 2018 embedded brains GmbH.  All rights reserved.
@@ -7,9 +9,26 @@
  *  Germany
  *  <rtems at embedded-brains.de>
+ * are met:
 #include <rtems/score/cpu.h>
diff --git a/cpukit/score/cpu/no_cpu/cpucounterread.c b/cpukit/score/cpu/no_cpu/cpucounterread.c
index b5dc02a40f..7f7e280d99 100644
--- a/cpukit/score/cpu/no_cpu/cpucounterread.c
+++ b/cpukit/score/cpu/no_cpu/cpucounterread.c
@@ -1,3 +1,5 @@
  * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
@@ -7,9 +9,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/no_cpu/cpuidle.c b/cpukit/score/cpu/no_cpu/cpuidle.c
index de66b39faa..b83ed13cee 100644
--- a/cpukit/score/cpu/no_cpu/cpuidle.c
+++ b/cpukit/score/cpu/no_cpu/cpuidle.c
@@ -1,3 +1,5 @@
  * Copyright (c) 2013-2014 embedded brains GmbH.  All rights reserved.
@@ -7,9 +9,26 @@
  *  Germany
+ * are met:
diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
index f2b2a75a39..5403cc8a10 100644
--- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
@@ -1,3 +1,5 @@
  * @file
@@ -28,9 +30,26 @@
  *  COPYRIGHT (c) 1989-2008.
+ * are met:
 #ifndef _RTEMS_SCORE_CPU_H
diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu_asm.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu_asm.h
index 747fd3a1c1..222b01982f 100644
--- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu_asm.h
+++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu_asm.h
@@ -1,3 +1,5 @@
  * @file
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
index 5f9196042c..6f4abfcfc3 100644
--- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
@@ -1,3 +1,5 @@
  * @file
@@ -7,9 +9,26 @@
  * Copyright (c) 2013, 2016 embedded brains GmbH
+ * are met:
 #ifndef _RTEMS_SCORE_CPUIMPL_H
diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/no_cpu.h b/cpukit/score/cpu/no_cpu/include/rtems/score/no_cpu.h
index d1bbceccc0..23ad58a1bc 100644
--- a/cpukit/score/cpu/no_cpu/include/rtems/score/no_cpu.h
+++ b/cpukit/score/cpu/no_cpu/include/rtems/score/no_cpu.h
@@ -1,3 +1,5 @@
 /*  no_cpu.h
  *  This file sets up basic CPU dependency settings based on
@@ -9,9 +11,26 @@
+ * are met:
2.24.4
