[PATCH 18/27] score/cpu/nios2: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Feb 25 18:06:03 UTC 2022
Updates #3053.
.../score/cpu/nios2/include/rtems/score/cpu.h | 25 ++++++++++++++++---
.../cpu/nios2/include/rtems/score/cpu_asm.h | 25 ++++++++++++++++---
.../cpu/nios2/include/rtems/score/cpuatomic.h | 25 ++++++++++++++++---
.../cpu/nios2/include/rtems/score/cpuimpl.h | 25 ++++++++++++++++---
.../include/rtems/score/nios2-count-zeros.h | 25 ++++++++++++++++---
.../nios2/include/rtems/score/nios2-utility.h | 25 ++++++++++++++++---
.../cpu/nios2/include/rtems/score/nios2.h | 25 ++++++++++++++++---
.../cpu/nios2/nios2-context-initialize.c | 25 ++++++++++++++++---
cpukit/score/cpu/nios2/nios2-context-switch.S | 25 ++++++++++++++++---
.../score/cpu/nios2/nios2-context-validate.S | 25 ++++++++++++++++---
.../nios2/nios2-context-volatile-clobber.S | 25 ++++++++++++++++---
.../score/cpu/nios2/nios2-eic-il-low-level.S | 25 ++++++++++++++++---
.../cpu/nios2/nios2-exception-frame-print.c | 25 ++++++++++++++++---
cpukit/score/cpu/nios2/nios2-fatal-halt.c | 25 ++++++++++++++++---
cpukit/score/cpu/nios2/nios2-iic-irq.c | 25 ++++++++++++++++---
cpukit/score/cpu/nios2/nios2-iic-low-level.S | 25 ++++++++++++++++---
cpukit/score/cpu/nios2/nios2-initialize.c | 25 ++++++++++++++++---
cpukit/score/cpu/nios2/nios2-isr-get-level.c | 25 ++++++++++++++++---
.../cpu/nios2/nios2-isr-install-vector.c | 25 ++++++++++++++++---
.../cpu/nios2/nios2-isr-is-in-progress.c | 25 ++++++++++++++++---
cpukit/score/cpu/nios2/nios2-isr-set-level.c | 25 ++++++++++++++++---
cpukit/score/cpu/nios2/nios2-mpu-add-region.c | 25 ++++++++++++++++---
.../score/cpu/nios2/nios2-mpu-configuration.c | 25 ++++++++++++++++---
cpukit/score/cpu/nios2/nios2-mpu-descriptor.c | 25 ++++++++++++++++---
.../cpu/nios2/nios2-mpu-disable-protected.c | 25 ++++++++++++++++---
cpukit/score/cpu/nios2/nios2-mpu-reset.c | 25 ++++++++++++++++---
.../nios2/nios2-thread-dispatch-disabled.c | 25 ++++++++++++++++---
27 files changed, 594 insertions(+), 81 deletions(-)
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpu.h b/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
index c26e57f88b..d7c484f9bc 100644
--- a/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
@@ -1,3 +1,5 @@
* @file
@@ -14,9 +16,26 @@
* COPYRIGHT (c) 1989-2004.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifndef _RTEMS_SCORE_CPU_H
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpu_asm.h b/cpukit/score/cpu/nios2/include/rtems/score/cpu_asm.h
index 81a19c8d69..fb80c7ed52 100644
--- a/cpukit/score/cpu/nios2/include/rtems/score/cpu_asm.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/cpu_asm.h
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
* COPYRIGHT (c) 1989-1999.
+ * are met:
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/nios2/include/rtems/score/cpuatomic.h
index 598ee76b20..01bb99cda3 100644
--- a/cpukit/score/cpu/nios2/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/cpuatomic.h
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2012-2013 Deng Hengyi.
+ * are met:
#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
index ad28960fe5..215df68f67 100644
--- a/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -7,9 +9,26 @@
* Copyright (c) 2013 embedded brains GmbH
+ * are met:
#ifndef _RTEMS_SCORE_CPUIMPL_H
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/nios2-count-zeros.h b/cpukit/score/cpu/nios2/include/rtems/score/nios2-count-zeros.h
index bf2390a51f..e0412412c6 100644
--- a/cpukit/score/cpu/nios2/include/rtems/score/nios2-count-zeros.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/nios2-count-zeros.h
@@ -1,3 +1,5 @@
* Author: Jeffrey O. Hill
@@ -11,9 +13,26 @@
* WARRANTY, EXPRESS OR IMPLIED, OR ASSUMES ANY LIABILITY FOR
* THE USE OF THIS SOFTWARE.
+ * are met:
#ifndef _NIOS2_COUNT_ZEROS_H
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/nios2-utility.h b/cpukit/score/cpu/nios2/include/rtems/score/nios2-utility.h
index 9367f73315..31277ff837 100644
--- a/cpukit/score/cpu/nios2/include/rtems/score/nios2-utility.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/nios2-utility.h
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
* Germany
* <rtems at embedded-brains.de>
+ * are met:
#ifndef _RTEMS_SCORE_NIOS2_UTILITY_H
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/nios2.h b/cpukit/score/cpu/nios2/include/rtems/score/nios2.h
index 26d76bcbfa..620a3bf3ba 100644
--- a/cpukit/score/cpu/nios2/include/rtems/score/nios2.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/nios2.h
@@ -1,3 +1,5 @@
* @file
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-context-initialize.c b/cpukit/score/cpu/nios2/nios2-context-initialize.c
index 6950ce4bd6..fe458cc2ca 100644
--- a/cpukit/score/cpu/nios2/nios2-context-initialize.c
+++ b/cpukit/score/cpu/nios2/nios2-context-initialize.c
@@ -1,3 +1,5 @@
* Copyright (c) 2011, 2021 embedded brains GmbH
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 1989-2006
+ * are met:
#ifdef HAVE_CONFIG_H
diff --git a/cpukit/score/cpu/nios2/nios2-context-switch.S b/cpukit/score/cpu/nios2/nios2-context-switch.S
index 3792f693da..87f6539076 100644
--- a/cpukit/score/cpu/nios2/nios2-context-switch.S
+++ b/cpukit/score/cpu/nios2/nios2-context-switch.S
@@ -1,3 +1,5 @@
* Copyright (c) 2011 embedded brains GmbH
@@ -6,9 +8,26 @@
* Derived from no_cpu/cpu_asm.S, copyright (c) 1989-1999,
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-context-validate.S b/cpukit/score/cpu/nios2/nios2-context-validate.S
index 00dcc6a2f3..65db34d1cc 100644
--- a/cpukit/score/cpu/nios2/nios2-context-validate.S
+++ b/cpukit/score/cpu/nios2/nios2-context-validate.S
@@ -1,3 +1,5 @@
* Copyright (c) 2013 embedded brains GmbH. All rights reserved.
@@ -7,9 +9,26 @@
* Germany
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S b/cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S
index e1c52d62b7..9cbe6d2fad 100644
--- a/cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S
+++ b/cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
* Germany
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-eic-il-low-level.S b/cpukit/score/cpu/nios2/nios2-eic-il-low-level.S
index fa4d1fb8f8..8f62617e05 100644
--- a/cpukit/score/cpu/nios2/nios2-eic-il-low-level.S
+++ b/cpukit/score/cpu/nios2/nios2-eic-il-low-level.S
@@ -1,3 +1,5 @@
* Copyright (c) 2011-2015 embedded brains GmbH. All rights reserved.
@@ -7,9 +9,26 @@
* Germany
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-exception-frame-print.c b/cpukit/score/cpu/nios2/nios2-exception-frame-print.c
index e54eb60e9f..106f153ba1 100644
--- a/cpukit/score/cpu/nios2/nios2-exception-frame-print.c
+++ b/cpukit/score/cpu/nios2/nios2-exception-frame-print.c
@@ -1,3 +1,5 @@
* Copyright (c) 2012 embedded brains GmbH. All rights reserved.
@@ -7,9 +9,26 @@
* Germany
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-fatal-halt.c b/cpukit/score/cpu/nios2/nios2-fatal-halt.c
index e2ea8ef13d..ab27de4b34 100644
--- a/cpukit/score/cpu/nios2/nios2-fatal-halt.c
+++ b/cpukit/score/cpu/nios2/nios2-fatal-halt.c
@@ -1,3 +1,5 @@
@@ -6,9 +8,26 @@
+ * are met:
#include <rtems/score/cpuimpl.h>
diff --git a/cpukit/score/cpu/nios2/nios2-iic-irq.c b/cpukit/score/cpu/nios2/nios2-iic-irq.c
index 665649f9d8..561ba3865e 100644
--- a/cpukit/score/cpu/nios2/nios2-iic-irq.c
+++ b/cpukit/score/cpu/nios2/nios2-iic-irq.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-2007.
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-iic-low-level.S b/cpukit/score/cpu/nios2/nios2-iic-low-level.S
index 11c2c5e9eb..b0b914f5c8 100644
--- a/cpukit/score/cpu/nios2/nios2-iic-low-level.S
+++ b/cpukit/score/cpu/nios2/nios2-iic-low-level.S
@@ -1,3 +1,5 @@
* This file contains all assembly code for the
* NIOS2 implementation of RTEMS.
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-initialize.c b/cpukit/score/cpu/nios2/nios2-initialize.c
index 4de6dab30b..1c8d97d565 100644
--- a/cpukit/score/cpu/nios2/nios2-initialize.c
+++ b/cpukit/score/cpu/nios2/nios2-initialize.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-isr-get-level.c b/cpukit/score/cpu/nios2/nios2-isr-get-level.c
index cb8be662e9..4879f60fff 100644
--- a/cpukit/score/cpu/nios2/nios2-isr-get-level.c
+++ b/cpukit/score/cpu/nios2/nios2-isr-get-level.c
@@ -1,3 +1,5 @@
* Copyright (c) 2011, 2016 embedded brains GmbH
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-isr-install-vector.c b/cpukit/score/cpu/nios2/nios2-isr-install-vector.c
index 7ffaf2ad4e..bb6fa67734 100644
--- a/cpukit/score/cpu/nios2/nios2-isr-install-vector.c
+++ b/cpukit/score/cpu/nios2/nios2-isr-install-vector.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-isr-is-in-progress.c b/cpukit/score/cpu/nios2/nios2-isr-is-in-progress.c
index cb6ddb8c6a..4ac109ec61 100644
--- a/cpukit/score/cpu/nios2/nios2-isr-is-in-progress.c
+++ b/cpukit/score/cpu/nios2/nios2-isr-is-in-progress.c
@@ -1,3 +1,5 @@
* Copyright (c) 2011 embedded brains GmbH. All rights reserved.
@@ -7,9 +9,26 @@
* Germany
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-isr-set-level.c b/cpukit/score/cpu/nios2/nios2-isr-set-level.c
index 74f1ce0cf8..c18def01e4 100644
--- a/cpukit/score/cpu/nios2/nios2-isr-set-level.c
+++ b/cpukit/score/cpu/nios2/nios2-isr-set-level.c
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-mpu-add-region.c b/cpukit/score/cpu/nios2/nios2-mpu-add-region.c
index db74cd6747..fa40223530 100644
--- a/cpukit/score/cpu/nios2/nios2-mpu-add-region.c
+++ b/cpukit/score/cpu/nios2/nios2-mpu-add-region.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
* Germany
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-mpu-configuration.c b/cpukit/score/cpu/nios2/nios2-mpu-configuration.c
index b77ee5fb0e..faf0ecb764 100644
--- a/cpukit/score/cpu/nios2/nios2-mpu-configuration.c
+++ b/cpukit/score/cpu/nios2/nios2-mpu-configuration.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
* Germany
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-mpu-descriptor.c b/cpukit/score/cpu/nios2/nios2-mpu-descriptor.c
index 9f85becb7c..4cda6960d4 100644
--- a/cpukit/score/cpu/nios2/nios2-mpu-descriptor.c
+++ b/cpukit/score/cpu/nios2/nios2-mpu-descriptor.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
* Germany
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c b/cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c
index 879105865f..91488c053f 100644
--- a/cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c
+++ b/cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
* Germany
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-mpu-reset.c b/cpukit/score/cpu/nios2/nios2-mpu-reset.c
index 2e5a19c1e2..1e01c73512 100644
--- a/cpukit/score/cpu/nios2/nios2-mpu-reset.c
+++ b/cpukit/score/cpu/nios2/nios2-mpu-reset.c
@@ -1,3 +1,5 @@
@@ -7,9 +9,26 @@
* Germany
+ * are met:
diff --git a/cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c b/cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c
index 8d1e3ee9b8..d2f628a21a 100644
--- a/cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c
+++ b/cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
* Germany
+ * are met:
2.24.4
