[PATCH 2/2] cpukit/aarch64: Add Per_CPU_Control accessor
Sat Feb 26 18:50:27 UTC 2022
this part looks ok
On Fri, Feb 25, 2022 at 5:51 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> Add an architecture-specific implementation for
> _CPU_Get_current_per_CPU_control() to reduce overhead for getting the
> current CPU's Per_CPU_Control structure.
>  .../cpu/aarch64/include/rtems/score/cpuimpl.h | 23 +++++++++++++++++++
>  1 file changed, 23 insertions(+)
> diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
> index 90fd48ad4e..ffdef2f30a 100644
> --- a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
> +++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
> @@ -125,6 +125,29 @@ typedef struct {
>    uint64_t register_fpcr;
>  } CPU_Interrupt_frame;
> +#ifdef RTEMS_SMP
> +static inline
> +struct Per_CPU_Control *_AARCH64_Get_current_per_CPU_control( void )
> +  struct Per_CPU_Control *cpu_self;
> +  uint64_t value;
> +  __asm__ volatile (
> +    "mrs %0, TPIDR_EL1" : "=&r" ( value ) : : "memory"
> +  /* Use EL1 Thread ID Register (TPIDR_EL1) */
> +  cpu_self = (struct Per_CPU_Control *)(uintptr_t)value;
> +  return cpu_self;
> +#define _CPU_Get_current_per_CPU_control() \
> +  _AARCH64_Get_current_per_CPU_control()
> +#endif /* RTEMS_SMP */
>  void _CPU_Context_volatile_clobber( uintptr_t pattern );
>  void _CPU_Context_validate( uintptr_t pattern );
> 2.30.2
> devel mailing list
> devel at rtems.org
