[PATCH 2/2] bsps/stm32h7: remove external memory initialization from nucleo-h743zi BSP
Karel Gardas karel at functional.vision
Fri Jun 3 09:59:26 UTC 2022
Nucleo board does not provide any external memory so code does not have
any function here anyway.
Sponsored-By:	Precidata
 .../boards/stm/nucleo-h743zi/ext-mem-ctl.c    | 478 ------------------
 .../stm/nucleo-h743zi/stm32h7-bspstarthooks.c |   1 -
 .../bsps/arm/stm32h7/bspnucleoh743zi.yml      |   1 -
 3 files changed, 480 deletions(-)
 delete mode 100644 bsps/arm/stm32h7/boards/stm/nucleo-h743zi/ext-mem-ctl.c
diff --git a/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/ext-mem-ctl.c b/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/ext-mem-ctl.c
deleted file mode 100644
index a2ab9d8f1f..0000000000
--- a/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/ext-mem-ctl.c
+++ /dev/null
@@ -1,478 +0,0 @@
-  * @file    system_stm32h7xx.c
-  * @author  MCD Application Team
-  * @brief   CMSIS Cortex-M Device Peripheral Access Layer System Source File.
-  *   This file provides two functions and one global variable to be called from
-  *   user application:
-  *      - SystemInit(): This function is called at startup just after reset and
-  *                      before branch to main program. This call is made inside
-  *                      the "startup_stm32h7xx.s" file.
-  *      - SystemCoreClock variable: Contains the core clock (HCLK), it can be used
-  *                                  by the user application to setup the SysTick
-  *                                  timer or configure other parameters.
-  *      - SystemCoreClockUpdate(): Updates the variable SystemCoreClock and must
-  *                                 be called whenever the core clock is changed
-  *                                 during program execution.
-  * @attention
-  * <h2><center>© Copyright (c) 2017 STMicroelectronics.
-  * All rights reserved.</center></h2>
-  * This software component is licensed by ST under BSD 3-Clause license,
-  * the "License"; You may not use this file except in compliance with the
-  * License. You may obtain a copy of the License at:
-  *                        opensource.org/licenses/BSD-3-Clause
-#include <stm32h7xx_hal.h>
-#define DATA_IN_ExtSRAM
-#define DATA_IN_ExtSDRAM
-void  SystemInit_ExtMemCtl(void)
-  #define  FMC_BMAP_Value    0x02000000    /* FMC Bank Mapping 2 (SDRAM Bank2 remapped) */
-  __IO uint32_t  tmp = 0;
-  /********** SDRAM + SRAM ***********************************************************************/
-  #if defined (DATA_IN_ExtSDRAM) && defined (DATA_IN_ExtSRAM)
-  register uint32_t       tmpreg = 0, timeout = 0xFFFF;
-  register __IO uint32_t  index;
-  /*-- I/O Ports Configuration ------------------------------------------------------*/
-  /* Enable GPIOD, GPIOE, GPIOF, GPIOG, GPIOH and GPIOI interface clock */
-  RCC->AHB4ENR |= 0x000001F8;
-  /* Delay after an RCC peripheral clock enabling */
-  tmp = READ_BIT(RCC->AHB4ENR, RCC_AHB4ENR_GPIOEEN);
-  /* Connect PDx pins to FMC Alternate function */
-  GPIOD->AFR[0]  = 0x00CC00CC;
-  GPIOD->AFR[1]  = 0xCCCCCCCC;
-  /* Configure PDx pins in Alternate function mode */
-  GPIOD->MODER   = 0xAAAAFAFA;
-  /* Configure PDx pins speed to 100 MHz */
-  GPIOD->OSPEEDR = 0xFFFF0F0F;
-  /* Configure PDx pins Output type to push-pull */
-  GPIOD->OTYPER  = 0x00000000;
-  /* Configure PDx pins in Pull-up */
-  GPIOD->PUPDR   = 0x55550505;
-  /* Connect PEx pins to FMC Alternate function */
-  GPIOE->AFR[0]  = 0xC00CC0CC;
-  GPIOE->AFR[1]  = 0xCCCCCCCC;
-  /* Configure PEx pins in Alternate function mode */
-  GPIOE->MODER   = 0xAAAABEBA;
-  /* Configure PEx pins speed to 100 MHz */
-  GPIOE->OSPEEDR = 0xFFFFC3CF;
-  /* Configure PEx pins Output type to push-pull */
-  GPIOE->OTYPER  = 0x00000000;
-  /* Configure PEx pins in Pull-up */
-  GPIOE->PUPDR   = 0x55554145;
-  /* Connect PFx pins to FMC Alternate function */
-  GPIOF->AFR[0]  = 0x00CCCCCC;
-  GPIOF->AFR[1]  = 0xCCCCC000;
-  /* Configure PFx pins in Alternate function mode */
-  GPIOF->MODER   = 0xAABFFAAA;
-  /* Configure PFx pins speed to 100 MHz */
-  GPIOF->OSPEEDR = 0xFFC00FFF;
-  /* Configure PFx pins Output type to push-pull */
-  GPIOF->OTYPER  = 0x00000000;
-  /* Configure PFx pins in Pull-up */
-  GPIOF->PUPDR   = 0x55400555;
-  /* Connect PGx pins to FMC Alternate function */
-  GPIOG->AFR[0]  = 0x00CCCCCC;
-  GPIOG->AFR[1]  = 0xC0000C0C;
-  /* Configure PGx pins in Alternate function mode */
-  GPIOG->MODER   = 0xBFEEFAAA;
-  /* Configure PGx pins speed to 100 MHz */
-  GPIOG->OSPEEDR = 0xC0330FFF;
-  /* Configure PGx pins Output type to push-pull */
-  GPIOG->OTYPER  = 0x00000000;
-  /* Configure PGx pins in Pull-up */
-  GPIOG->PUPDR   = 0x40110555;
-  /* Connect PHx pins to FMC Alternate function */
-  GPIOH->AFR[0]  = 0xCCC00000;
-  GPIOH->AFR[1]  = 0xCCCCCCCC;
-  /* Configure PHx pins in Alternate function mode */
-  GPIOH->MODER   = 0xAAAAABFF;
-  /* Configure PHx pins speed to 100 MHz */
-  GPIOH->OSPEEDR = 0xFFFFFC00;
-  /* Configure PHx pins Output type to push-pull */
-  GPIOH->OTYPER  = 0x00000000;
-  /* Configure PHx pins in Pull-up */
-  GPIOH->PUPDR   = 0x55555400;
-  /* Connect PIx pins to FMC Alternate function */
-  GPIOI->AFR[0]  = 0xCCCCCCCC;
-  GPIOI->AFR[1]  = 0x00000CC0;
-  /* Configure PIx pins in Alternate function mode */
-  GPIOI->MODER   = 0xFFEBAAAA;
-  /* Configure PIx pins speed to 100 MHz */
-  GPIOI->OSPEEDR = 0x003CFFFF;
-  /* Configure PIx pins Output type to push-pull */
-  GPIOI->OTYPER  = 0x00000000;
-  /* Configure PIx pins in Pull-up */
-  GPIOI->PUPDR   = 0x00145555;
-  /*-- FMC Configuration ------------------------------------------------------*/
-  /* Enable the FMC/FSMC interface clock */
-  (RCC->AHB3ENR |= (RCC_AHB3ENR_FMCEN));
-  /* Configure and enable Bank1_SRAM2 */
-  FMC_Bank1_R->BTCR[4]  = 0x00001091;
-  FMC_Bank1_R->BTCR[5]  = 0x00110212;
-  FMC_Bank1E_R->BWTR[4] = 0x0FFFFFFF;
-  /* SDRAM Timing and access interface configuration */
-  /*SDBank               = FMC_SDRAM_BANK2
-    ColumnBitsNumber     = FMC_SDRAM_COLUMN_BITS_NUM_9           CC
-    RowBitsNumber        = FMC_SDRAM_ROW_BITS_NUM_12             RR
-    MemoryDataWidth      = FMC_SDRAM_MEM_BUS_WIDTH_32            MM
-    InternalBankNumber   = FMC_SDRAM_INTERN_BANKS_NUM_4          N
-    CASLatency           = FMC_SDRAM_CAS_LATENCY_2               LL   // 2 oder 3, s.u.
-    WriteProtection      = FMC_SDRAM_WRITE_PROTECTION_DISABLE    W
-    SDClockPeriod        = FMC_SDRAM_CLOCK_PERIOD_2              KK
-    ReadBurst            = FMC_SDRAM_RBURST_ENABLE               B
-    ReadPipeDelay        = FMC_SDRAM_RPIPE_DELAY_0               PP
-    LoadToActiveDelay    = 2  -> 1     LLLL     TMRD
-    ExitSelfRefreshDelay = 6  -> 5     EEEE     TXSR
-    SelfRefreshTime      = 4  -> 3     SSSS     TRAS
-    RowCycleDelay        = 6  -> 5     RRRR     TRC
-    WriteRecoveryTime    = 2  -> 1     WWWW     TWR
-    RPDelay              = 2  -> 1     PPPP     TRP
-    RCDDelay             = 2  -> 1     CCCC     TRCD              */
-  #if 0
-  FMC_Bank5_6_R->SDCR[0] = 0x00005965;  // 0000 0000 0000 0000 0101 1001 0110 0101  Bank 1
-                                        //                      PPB KKWL LNMM RRCC
-  FMC_Bank5_6_R->SDCR[1] = 0x00005965;  // 0000 0000 0000 0000 0101 1001 0110 0101  Bank 2  // CAS Latency = 2
-                                        //                            WL LNMM RRCC
-  FMC_Bank5_6_R->SDTR[0] = 0x00105000;  // 0000 0000 0001 0000 0101 0000 0000 0000  Bank 1  // Original,
-                                        //      CCCC PPPP WWWW RRRR SSSS EEEE LLLL          // mit CAS Latency = 2 (s.o.)
-  FMC_Bank5_6_R->SDTR[1] = 0x01010351;  // 0000 0001 0000 0001 0000 0011 0101 0001  Bank 2
-                                        //      CCCC      WWWW      SSSS EEEE LLLL
-  #endif
-  #if 0
-  FMC_Bank5_6_R->SDTR[0] = 0x00206000;  // 0000 0000 0010 0000 0110 0000 0000 0000  Bank 1  // Original + 1 bei allen Werten,
-                                        //      CCCC PPPP WWWW RRRR SSSS EEEE LLLL          // mit CAS Latency = 3 (s.o.)
-  FMC_Bank5_6_R->SDTR[1] = 0x02020462;  // 0000 0010 0000 0010 0000 0100 0110 0010  Bank 2
-  #endif
-  #if 0
-  FMC_Bank5_6_R->SDTR[0] = 0x00209000;  // 0000 0000 0010 0000 1001 0000 0000 0000  Bank 1  // Versuch anhand ISSI-Datenblatt,
-  FMC_Bank5_6_R->SDTR[1] = 0x020306B1;  // 0000 0010 0000 0011 0000 0110 1011 0001  Bank 2
-  #endif
-  FMC_Bank5_6_R->SDCR[0] = 0x00001800;
-  FMC_Bank5_6_R->SDCR[1] = 0x00000165;
-  /* SDRAM initialization sequence */
-  /* Clock enable command */
-  FMC_Bank5_6_R->SDCMR = 0x00000009;
-  tmpreg = FMC_Bank5_6_R->SDSR & 0x00000020;
-  while ((tmpreg != 0) && (timeout-- > 0))
-  /* Delay */
-  for (index=0; index<1000; index++);
-  /* PALL command */
-  FMC_Bank5_6_R->SDCMR = 0x0000000A;
-  timeout = 0xFFFF;
-  FMC_Bank5_6_R->SDCMR = 0x000000EB;
-  timeout = 0xFFFF;
-  FMC_Bank5_6_R->SDCMR = 0x0004400C;
-  timeout = 0xFFFF;
-  /* Set refresh count */
-  tmpreg = FMC_Bank5_6_R->SDRTR;
-  FMC_Bank5_6_R->SDRTR = (tmpreg | (0x00000603 << 1));
-  /* Disable write protection */
-  tmpreg = FMC_Bank5_6_R->SDCR[1];
-  FMC_Bank5_6_R->SDCR[1] = (tmpreg & 0xFFFFFDFF);
-  /* Configure FMC Bank Mapping */
-  FMC_Bank1_R->BTCR[0] |= FMC_BMAP_Value;
-   /* FMC controller Enable */
-  FMC_Bank1_R->BTCR[0] |= 0x80000000;
-  /********** SDRAM only *************************************************************************/
-  #elif defined (DATA_IN_ExtSDRAM)
-  GPIOD->AFR[0]  = 0x000000CC;
-  GPIOD->AFR[1]  = 0xCC000CCC;
-  GPIOD->MODER   = 0xAFEAFFFA;
-  GPIOD->OSPEEDR = 0xF03F000F;
-  GPIOD->PUPDR   = 0x50150005;
-  GPIOE->AFR[0]  = 0xC00000CC;
-  GPIOE->MODER   = 0xAAAABFFA;
-  GPIOE->OSPEEDR = 0xFFFFC00F;
-  GPIOE->PUPDR   = 0x55554005;
-  GPIOG->AFR[1]  = 0xC000000C;
-  GPIOG->MODER   = 0xBFFEFAAA;
-  GPIOG->OSPEEDR = 0xC0030FFF;
-  GPIOG->PUPDR   = 0x40010555;
-  /* Enable the FMC interface clock */
-  /*LoadToActiveDelay    = 2
-    RowCycleDelay        = 6
-    RPDelay              = 2
-    RCDDelay             = 2
-    SDBank               = FMC_SDRAM_BANK2
-    ReadPipeDelay        = FMC_SDRAM_RPIPE_DELAY_0*/
-  /* Delay */
-  timeout = 0xFFFF;
-  timeout = 0xFFFF;
-  timeout = 0xFFFF;
-  FMC_Bank5_6_R->SDRTR = (tmpreg | (0x00000603<<1));
-  /********** SRAM only **************************************************************************/
-  #elif defined(DATA_IN_ExtSRAM)
-  /*-- I/O Ports Configuration -----------------------------------------------------*/
-  /* Enable GPIOD, GPIOE, GPIOF and GPIOG interface clock */
-  RCC->AHB4ENR |= 0x00000078;
-  GPIOD->MODER   = 0xAAAAFABA;
-  GPIOF->AFR[1]  = 0xCCCC0000;
-  GPIOF->MODER   = 0xAAFFFAAA;
-  GPIOF->OSPEEDR = 0xFF000FFF;
-  GPIOF->PUPDR   = 0x55000555;
-  GPIOG->AFR[1]  = 0x00000C00;
-  GPIOG->MODER   = 0xFFEFFAAA;
-  GPIOG->OSPEEDR = 0x00300FFF;
-  GPIOG->PUPDR   = 0x00100555;
-  /*-- FMC/FSMC Configuration --------------------------------------------------*/
-  #endif /* DATA_IN_ExtSRAM */
-  (void)(tmp);
diff --git a/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-bspstarthooks.c b/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-bspstarthooks.c
index 8d34e357ee..eda503925f 100644
--- a/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-bspstarthooks.c
+++ b/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-bspstarthooks.c
@@ -51,7 +51,6 @@ void bsp_start_hook_0(void)
     stm32h7_init_peripheral_clocks();
     HAL_RCC_MCOConfig(RCC_MCO1, RCC_MCO1SOURCE_HSI, RCC_MCODIV_1);
     HAL_Init();
-    SystemInit_ExtMemCtl();
 #if __CORTEX_M == 0x07U
diff --git a/spec/build/bsps/arm/stm32h7/bspnucleoh743zi.yml b/spec/build/bsps/arm/stm32h7/bspnucleoh743zi.yml
index f36c93a8ae..20fdbf30a3 100644
--- a/spec/build/bsps/arm/stm32h7/bspnucleoh743zi.yml
+++ b/spec/build/bsps/arm/stm32h7/bspnucleoh743zi.yml
@@ -19,6 +19,5 @@ source:
 - bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-osc.c
 - bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-per.c
 - bsps/arm/stm32h7/boards/stm/nucleo-h743zi/system_stm32h7xx.c
-- bsps/arm/stm32h7/boards/stm/nucleo-h743zi/ext-mem-ctl.c
 - bsps/arm/shared/cache/cache-v7m.c
 type: build
2.25.1
