[libbsd 8/9] netstat: Do not use signals
Sebastian Huber
Fri Jun 10 06:08:34 UTC 2022
freebsd/usr.bin/netstat/if.c | 19 ++++---------------
.../netstat/rtems-bsd-netstat-if-data.h | 2 --
2 files changed, 4 insertions(+), 17 deletions(-)
diff --git a/freebsd/usr.bin/netstat/if.c b/freebsd/usr.bin/netstat/if.c
index c578629e..ffb639c6 100644
--- a/freebsd/usr.bin/netstat/if.c
+++ b/freebsd/usr.bin/netstat/if.c
@@ -512,6 +512,7 @@ intpr(void (*pfunc)(char *), int af)
freeifmaddrs(ifmap);
+#ifndef __rtems__
struct iftot {
u_long ift_ip; /* input packets */
u_long ift_ie; /* input errors */
@@ -575,6 +576,7 @@ catchalarm(int signo __unused)
signalled = true;
+#endif /* __rtems__ */
* Print a running summary of interface statistics.
@@ -585,6 +587,7 @@ catchalarm(int signo __unused)
static void
sidewaysintpr(void)
+#ifndef __rtems__
struct iftot ift[2], *new, *old;
struct itimerval interval_it;
int oldmask, line;
@@ -619,26 +622,11 @@ loop:
xo_close_list("interface-statistics");
return;
-#ifdef __rtems__
- sigset_t oldmask, desired, empty;
- sigemptyset(&empty);
- sigemptyset(&desired);
- sigaddset(&desired, SIGALRM);
- sigprocmask(SIG_BLOCK, &desired, &oldmask);
- while (!signalled)
- sigsuspend(&desired);
- signalled = false;
- sigprocmask(SIG_SETMASK, &oldmask, NULL);
-#else /* __rtems__ */
oldmask = sigblock(sigmask(SIGALRM));
while (!signalled)
sigpause(0);
signalled = false;
sigsetmask(oldmask);
-#endif /* __rtems__ */
line++;
fill_iftot(new);
@@ -681,4 +669,5 @@ loop:
goto loop;
/* NOTREACHED */
diff --git a/freebsd/usr.bin/netstat/rtems-bsd-netstat-if-data.h b/freebsd/usr.bin/netstat/rtems-bsd-netstat-if-data.h
index 9e12b65e..9a685f33 100644
--- a/freebsd/usr.bin/netstat/rtems-bsd-netstat-if-data.h
+++ b/freebsd/usr.bin/netstat/rtems-bsd-netstat-if-data.h
@@ -1,5 +1,3 @@
/* generated by userspace-header-gen.py */
#include <rtems/linkersets.h>
#include "rtems-bsd-netstat-data.h"
-/* if.c */
-RTEMS_LINKER_RWSET_CONTENT(bsd_prog_netstat, static sig_atomic_t signalled);
2.35.3
