[PATCH 2/8] samples/*/*.doc: Change license to BSD-2
    Joel Sherrill
    joel at rtems.org
    Fri Jun 10 15:52:55 UTC 2022
Updates #3053.
 testsuites/samples/base_mp/base_mp-node1.doc | 25 +++++++++++++++++---
 testsuites/samples/base_mp/base_mp-node2.doc | 25 +++++++++++++++++---
 testsuites/samples/base_sp/base_sp.doc       | 25 +++++++++++++++++---
 testsuites/samples/capture/capture.doc       | 25 +++++++++++++++++---
 testsuites/samples/fileio/fileio.doc         | 25 +++++++++++++++++---
 testsuites/samples/hello/hello.doc           | 25 +++++++++++++++++---
 testsuites/samples/iostream/iostream.doc     | 25 +++++++++++++++++---
 testsuites/samples/minimum/minimum.doc       | 25 +++++++++++++++++---
 testsuites/samples/nsecs/nsecs.doc           | 25 +++++++++++++++++---
 testsuites/samples/paranoia/paranoia.doc     | 25 +++++++++++++++++---
 testsuites/samples/ticker/ticker.doc         | 25 +++++++++++++++++---
 testsuites/samples/unlimited/unlimited.doc   |  2 ++
 12 files changed, 244 insertions(+), 33 deletions(-)
diff --git a/testsuites/samples/base_mp/base_mp-node1.doc b/testsuites/samples/base_mp/base_mp-node1.doc
index 981286480f..f56c0e1f4e 100644
--- a/testsuites/samples/base_mp/base_mp-node1.doc
+++ b/testsuites/samples/base_mp/base_mp-node1.doc
@@ -1,9 +1,28 @@
+# SPDX-License-Identifier: BSD-2-Clause
 #  COPYRIGHT (c) 1989-1999.
 #  On-Line Applications Research Corporation (OAR).
-#  The license and distribution terms for this file may be
-#  found in the file LICENSE in this distribution or at
-#  http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+#    notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+#    notice, this list of conditions and the following disclaimer in the
+#    documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
diff --git a/testsuites/samples/base_mp/base_mp-node2.doc b/testsuites/samples/base_mp/base_mp-node2.doc
--- a/testsuites/samples/base_mp/base_mp-node2.doc
+++ b/testsuites/samples/base_mp/base_mp-node2.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/samples/base_sp/base_sp.doc b/testsuites/samples/base_sp/base_sp.doc
--- a/testsuites/samples/base_sp/base_sp.doc
+++ b/testsuites/samples/base_sp/base_sp.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/samples/capture/capture.doc b/testsuites/samples/capture/capture.doc
index bb8f4f321b..05b5d0478f 100644
--- a/testsuites/samples/capture/capture.doc
+++ b/testsuites/samples/capture/capture.doc
@@ -1,9 +1,28 @@
+# are met:
 Capture Engine Tutorial
diff --git a/testsuites/samples/fileio/fileio.doc b/testsuites/samples/fileio/fileio.doc
index 0a436014f6..a8f84966d6 100644
--- a/testsuites/samples/fileio/fileio.doc
+++ b/testsuites/samples/fileio/fileio.doc
@@ -1,12 +1,31 @@
 #  fileio.doc,v
+# are met:
 This sample implements some basic tests for the file systems
diff --git a/testsuites/samples/hello/hello.doc b/testsuites/samples/hello/hello.doc
--- a/testsuites/samples/hello/hello.doc
+++ b/testsuites/samples/hello/hello.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/samples/iostream/iostream.doc b/testsuites/samples/iostream/iostream.doc
--- a/testsuites/samples/iostream/iostream.doc
+++ b/testsuites/samples/iostream/iostream.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/samples/minimum/minimum.doc b/testsuites/samples/minimum/minimum.doc
--- a/testsuites/samples/minimum/minimum.doc
+++ b/testsuites/samples/minimum/minimum.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/samples/nsecs/nsecs.doc b/testsuites/samples/nsecs/nsecs.doc
--- a/testsuites/samples/nsecs/nsecs.doc
+++ b/testsuites/samples/nsecs/nsecs.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/samples/paranoia/paranoia.doc b/testsuites/samples/paranoia/paranoia.doc
--- a/testsuites/samples/paranoia/paranoia.doc
+++ b/testsuites/samples/paranoia/paranoia.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/samples/ticker/ticker.doc b/testsuites/samples/ticker/ticker.doc
--- a/testsuites/samples/ticker/ticker.doc
+++ b/testsuites/samples/ticker/ticker.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/samples/unlimited/unlimited.doc b/testsuites/samples/unlimited/unlimited.doc
index efab1de603..87dbb2e689 100644
--- a/testsuites/samples/unlimited/unlimited.doc
+++ b/testsuites/samples/unlimited/unlimited.doc
@@ -1,3 +1,5 @@
 #  COPYRIGHT (c) 1989-1997.
2.24.4
