[PATCH 3/8] psxtmtests/*/*.doc: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Jun 10 15:52:56 UTC 2022
Updates #3053.
.../psxtmbarrier01/psxtmbarrier01.doc | 25 ++++++++++++++++---
.../psxtmbarrier02/psxtmbarrier02.doc | 25 ++++++++++++++++---
.../psxtmbarrier03/psxtmbarrier03.doc | 25 ++++++++++++++++---
.../psxtmbarrier04/psxtmbarrier04.doc | 25 ++++++++++++++++---
.../psxtmclocknanosleep01.doc | 25 ++++++++++++++++---
.../psxtmclocknanosleep02.doc | 25 ++++++++++++++++---
.../psxtmclocknanosleep03.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmcond02/psxtmcond02.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmcond03/psxtmcond03.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmcond04/psxtmcond04.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmcond05/psxtmcond05.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmcond06/psxtmcond06.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmcond07/psxtmcond07.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmcond08/psxtmcond08.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmcond09/psxtmcond09.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmkey01/psxtmkey01.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmkey02/psxtmkey02.doc | 25 ++++++++++++++++---
testsuites/psxtmtests/psxtmmq01/psxtmmq01.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmmutex01/psxtmmutex01.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmmutex02/psxtmmutex02.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmmutex03/psxtmmutex03.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmmutex04/psxtmmutex04.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmmutex05/psxtmmutex05.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmmutex06/psxtmmutex06.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmmutex07/psxtmmutex07.doc | 25 ++++++++++++++++---
.../psxtmnanosleep01/psxtmnanosleep01.doc | 25 ++++++++++++++++---
.../psxtmnanosleep02/psxtmnanosleep02.doc | 25 ++++++++++++++++---
.../psxtmrwlock01/psxtmrwlock01.doc | 25 ++++++++++++++++---
.../psxtmrwlock02/psxtmrwlock02.doc | 25 ++++++++++++++++---
.../psxtmrwlock03/psxtmrwlock03.doc | 25 ++++++++++++++++---
.../psxtmrwlock04/psxtmrwlock04.doc | 25 ++++++++++++++++---
.../psxtmrwlock05/psxtmrwlock05.doc | 25 ++++++++++++++++---
.../psxtmrwlock06/psxtmrwlock06.doc | 25 ++++++++++++++++---
.../psxtmrwlock07/psxtmrwlock07.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmsem01/psxtmsem01.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmsem02/psxtmsem02.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmsem03/psxtmsem03.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmsem04/psxtmsem04.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmsem05/psxtmsem05.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmsleep01/psxtmsleep01.doc | 25 ++++++++++++++++---
.../psxtmtests/psxtmsleep02/psxtmsleep02.doc | 25 ++++++++++++++++---
.../psxtmthread01/psxtmthread01.doc | 25 ++++++++++++++++---
.../psxtmthread03/psxtmthread03.doc | 25 ++++++++++++++++---
.../psxtmthread04/psxtmthread04.doc | 25 ++++++++++++++++---
.../psxtmthread05/psxtmthread05.doc | 25 ++++++++++++++++---
45 files changed, 990 insertions(+), 135 deletions(-)
diff --git a/testsuites/psxtmtests/psxtmbarrier01/psxtmbarrier01.doc b/testsuites/psxtmtests/psxtmbarrier01/psxtmbarrier01.doc
index 74f74c67d5..9e9fba5e0d 100644
--- a/testsuites/psxtmtests/psxtmbarrier01/psxtmbarrier01.doc
+++ b/testsuites/psxtmtests/psxtmbarrier01/psxtmbarrier01.doc
@@ -1,9 +1,28 @@
+# SPDX-License-Identifier: BSD-2-Clause
# COPYRIGHT (c) 1989-2011.
# On-Line Applications Research Corporation (OAR).
-# The license and distribution terms for this file may be
-# found in the file LICENSE in this distribution or at
-# http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+# notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+# notice, this list of conditions and the following disclaimer in the
+# documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
This test benchmarks the following operations:
diff --git a/testsuites/psxtmtests/psxtmbarrier02/psxtmbarrier02.doc b/testsuites/psxtmtests/psxtmbarrier02/psxtmbarrier02.doc
index 276f878c8b..4099a21557 100644
--- a/testsuites/psxtmtests/psxtmbarrier02/psxtmbarrier02.doc
+++ b/testsuites/psxtmtests/psxtmbarrier02/psxtmbarrier02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmbarrier03/psxtmbarrier03.doc b/testsuites/psxtmtests/psxtmbarrier03/psxtmbarrier03.doc
index 6a5cab0d81..a5f576902d 100644
--- a/testsuites/psxtmtests/psxtmbarrier03/psxtmbarrier03.doc
+++ b/testsuites/psxtmtests/psxtmbarrier03/psxtmbarrier03.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmbarrier04/psxtmbarrier04.doc b/testsuites/psxtmtests/psxtmbarrier04/psxtmbarrier04.doc
index 767fd36484..bbb75b9af5 100644
--- a/testsuites/psxtmtests/psxtmbarrier04/psxtmbarrier04.doc
+++ b/testsuites/psxtmtests/psxtmbarrier04/psxtmbarrier04.doc
@@ -1,9 +1,28 @@
# COPYRIGHT (c) 1989-2012.
+# are met:
diff --git a/testsuites/psxtmtests/psxtmclocknanosleep01/psxtmclocknanosleep01.doc b/testsuites/psxtmtests/psxtmclocknanosleep01/psxtmclocknanosleep01.doc
index 67370cfa36..b228c9b3d4 100644
--- a/testsuites/psxtmtests/psxtmclocknanosleep01/psxtmclocknanosleep01.doc
+++ b/testsuites/psxtmtests/psxtmclocknanosleep01/psxtmclocknanosleep01.doc
@@ -1,8 +1,27 @@
# Copyright 2016. Gedare Bloom.
+# are met:
diff --git a/testsuites/psxtmtests/psxtmclocknanosleep02/psxtmclocknanosleep02.doc b/testsuites/psxtmtests/psxtmclocknanosleep02/psxtmclocknanosleep02.doc
index 4724ae50f3..12f8baf32c 100644
--- a/testsuites/psxtmtests/psxtmclocknanosleep02/psxtmclocknanosleep02.doc
+++ b/testsuites/psxtmtests/psxtmclocknanosleep02/psxtmclocknanosleep02.doc
@@ -1,8 +1,27 @@
# Copyright (c) 2016. Gedare Bloom
+# are met:
diff --git a/testsuites/psxtmtests/psxtmclocknanosleep03/psxtmclocknanosleep03.doc b/testsuites/psxtmtests/psxtmclocknanosleep03/psxtmclocknanosleep03.doc
index 8ea20f6efd..31dcdda21b 100644
--- a/testsuites/psxtmtests/psxtmclocknanosleep03/psxtmclocknanosleep03.doc
+++ b/testsuites/psxtmtests/psxtmclocknanosleep03/psxtmclocknanosleep03.doc
@@ -1,8 +1,27 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmcond02/psxtmcond02.doc b/testsuites/psxtmtests/psxtmcond02/psxtmcond02.doc
index 3aab0e7cdd..c3353964b1 100644
--- a/testsuites/psxtmtests/psxtmcond02/psxtmcond02.doc
+++ b/testsuites/psxtmtests/psxtmcond02/psxtmcond02.doc
@@ -1,9 +1,28 @@
# COPYRIGHT (c) 2013
+# are met:
diff --git a/testsuites/psxtmtests/psxtmcond03/psxtmcond03.doc b/testsuites/psxtmtests/psxtmcond03/psxtmcond03.doc
index 436f1fe302..2934e34a7f 100644
--- a/testsuites/psxtmtests/psxtmcond03/psxtmcond03.doc
+++ b/testsuites/psxtmtests/psxtmcond03/psxtmcond03.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmcond04/psxtmcond04.doc b/testsuites/psxtmtests/psxtmcond04/psxtmcond04.doc
index 42188820af..2ba306f7a9 100644
--- a/testsuites/psxtmtests/psxtmcond04/psxtmcond04.doc
+++ b/testsuites/psxtmtests/psxtmcond04/psxtmcond04.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmcond05/psxtmcond05.doc b/testsuites/psxtmtests/psxtmcond05/psxtmcond05.doc
index 32ea709e23..3ed4b09eb1 100644
--- a/testsuites/psxtmtests/psxtmcond05/psxtmcond05.doc
+++ b/testsuites/psxtmtests/psxtmcond05/psxtmcond05.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmcond06/psxtmcond06.doc b/testsuites/psxtmtests/psxtmcond06/psxtmcond06.doc
index 77d835d478..92d8d3cfcb 100644
--- a/testsuites/psxtmtests/psxtmcond06/psxtmcond06.doc
+++ b/testsuites/psxtmtests/psxtmcond06/psxtmcond06.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmcond07/psxtmcond07.doc b/testsuites/psxtmtests/psxtmcond07/psxtmcond07.doc
index 0cdfe271f7..66a8995c50 100644
--- a/testsuites/psxtmtests/psxtmcond07/psxtmcond07.doc
+++ b/testsuites/psxtmtests/psxtmcond07/psxtmcond07.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmcond08/psxtmcond08.doc b/testsuites/psxtmtests/psxtmcond08/psxtmcond08.doc
index 68ca20512e..7002430c6c 100644
--- a/testsuites/psxtmtests/psxtmcond08/psxtmcond08.doc
+++ b/testsuites/psxtmtests/psxtmcond08/psxtmcond08.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmcond09/psxtmcond09.doc b/testsuites/psxtmtests/psxtmcond09/psxtmcond09.doc
index 459a871d7c..b49a3d65b6 100644
--- a/testsuites/psxtmtests/psxtmcond09/psxtmcond09.doc
+++ b/testsuites/psxtmtests/psxtmcond09/psxtmcond09.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmkey01/psxtmkey01.doc b/testsuites/psxtmtests/psxtmkey01/psxtmkey01.doc
index 266e6d6202..143687fb8e 100644
--- a/testsuites/psxtmtests/psxtmkey01/psxtmkey01.doc
+++ b/testsuites/psxtmtests/psxtmkey01/psxtmkey01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmkey02/psxtmkey02.doc b/testsuites/psxtmtests/psxtmkey02/psxtmkey02.doc
index 626a8dbe27..490f3fa6c3 100644
--- a/testsuites/psxtmtests/psxtmkey02/psxtmkey02.doc
+++ b/testsuites/psxtmtests/psxtmkey02/psxtmkey02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmmq01/psxtmmq01.doc b/testsuites/psxtmtests/psxtmmq01/psxtmmq01.doc
index 5a13e02b3c..18714df593 100644
--- a/testsuites/psxtmtests/psxtmmq01/psxtmmq01.doc
+++ b/testsuites/psxtmtests/psxtmmq01/psxtmmq01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmmutex01/psxtmmutex01.doc b/testsuites/psxtmtests/psxtmmutex01/psxtmmutex01.doc
index 55fcc81389..8387ecf7f8 100644
--- a/testsuites/psxtmtests/psxtmmutex01/psxtmmutex01.doc
+++ b/testsuites/psxtmtests/psxtmmutex01/psxtmmutex01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmmutex02/psxtmmutex02.doc b/testsuites/psxtmtests/psxtmmutex02/psxtmmutex02.doc
index ce460f0f1c..b3fb1b0800 100644
--- a/testsuites/psxtmtests/psxtmmutex02/psxtmmutex02.doc
+++ b/testsuites/psxtmtests/psxtmmutex02/psxtmmutex02.doc
@@ -1,9 +1,28 @@
# COPYRIGHT (c) 1989-2010.
+# are met:
diff --git a/testsuites/psxtmtests/psxtmmutex03/psxtmmutex03.doc b/testsuites/psxtmtests/psxtmmutex03/psxtmmutex03.doc
index 2a1f007194..9c444a05a3 100644
--- a/testsuites/psxtmtests/psxtmmutex03/psxtmmutex03.doc
+++ b/testsuites/psxtmtests/psxtmmutex03/psxtmmutex03.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmmutex04/psxtmmutex04.doc b/testsuites/psxtmtests/psxtmmutex04/psxtmmutex04.doc
index 38860aae68..60c0a20f81 100644
--- a/testsuites/psxtmtests/psxtmmutex04/psxtmmutex04.doc
+++ b/testsuites/psxtmtests/psxtmmutex04/psxtmmutex04.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmmutex05/psxtmmutex05.doc b/testsuites/psxtmtests/psxtmmutex05/psxtmmutex05.doc
index 10b6ca0aab..9360a05852 100644
--- a/testsuites/psxtmtests/psxtmmutex05/psxtmmutex05.doc
+++ b/testsuites/psxtmtests/psxtmmutex05/psxtmmutex05.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmmutex06/psxtmmutex06.doc b/testsuites/psxtmtests/psxtmmutex06/psxtmmutex06.doc
index 88cece9e28..7213fab2f3 100644
--- a/testsuites/psxtmtests/psxtmmutex06/psxtmmutex06.doc
+++ b/testsuites/psxtmtests/psxtmmutex06/psxtmmutex06.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmmutex07/psxtmmutex07.doc b/testsuites/psxtmtests/psxtmmutex07/psxtmmutex07.doc
index 3eecb346bf..8be220bb80 100644
--- a/testsuites/psxtmtests/psxtmmutex07/psxtmmutex07.doc
+++ b/testsuites/psxtmtests/psxtmmutex07/psxtmmutex07.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmnanosleep01/psxtmnanosleep01.doc b/testsuites/psxtmtests/psxtmnanosleep01/psxtmnanosleep01.doc
index c8601464ea..b48acb9c91 100644
--- a/testsuites/psxtmtests/psxtmnanosleep01/psxtmnanosleep01.doc
+++ b/testsuites/psxtmtests/psxtmnanosleep01/psxtmnanosleep01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmnanosleep02/psxtmnanosleep02.doc b/testsuites/psxtmtests/psxtmnanosleep02/psxtmnanosleep02.doc
index 2f2797f84d..a3077b8f41 100644
--- a/testsuites/psxtmtests/psxtmnanosleep02/psxtmnanosleep02.doc
+++ b/testsuites/psxtmtests/psxtmnanosleep02/psxtmnanosleep02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmrwlock01/psxtmrwlock01.doc b/testsuites/psxtmtests/psxtmrwlock01/psxtmrwlock01.doc
index 00bbd7a758..0166b4fb24 100644
--- a/testsuites/psxtmtests/psxtmrwlock01/psxtmrwlock01.doc
+++ b/testsuites/psxtmtests/psxtmrwlock01/psxtmrwlock01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmrwlock02/psxtmrwlock02.doc b/testsuites/psxtmtests/psxtmrwlock02/psxtmrwlock02.doc
index 87ea8ef71e..7378cca31f 100644
--- a/testsuites/psxtmtests/psxtmrwlock02/psxtmrwlock02.doc
+++ b/testsuites/psxtmtests/psxtmrwlock02/psxtmrwlock02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmrwlock03/psxtmrwlock03.doc b/testsuites/psxtmtests/psxtmrwlock03/psxtmrwlock03.doc
index 7941646a43..9dab57a0dc 100644
--- a/testsuites/psxtmtests/psxtmrwlock03/psxtmrwlock03.doc
+++ b/testsuites/psxtmtests/psxtmrwlock03/psxtmrwlock03.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmrwlock04/psxtmrwlock04.doc b/testsuites/psxtmtests/psxtmrwlock04/psxtmrwlock04.doc
index a398ca44ca..c3c12baf0b 100644
--- a/testsuites/psxtmtests/psxtmrwlock04/psxtmrwlock04.doc
+++ b/testsuites/psxtmtests/psxtmrwlock04/psxtmrwlock04.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmrwlock05/psxtmrwlock05.doc b/testsuites/psxtmtests/psxtmrwlock05/psxtmrwlock05.doc
index b1a467fc80..b910db70de 100644
--- a/testsuites/psxtmtests/psxtmrwlock05/psxtmrwlock05.doc
+++ b/testsuites/psxtmtests/psxtmrwlock05/psxtmrwlock05.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmrwlock06/psxtmrwlock06.doc b/testsuites/psxtmtests/psxtmrwlock06/psxtmrwlock06.doc
index 8984eafc85..04cb933558 100644
--- a/testsuites/psxtmtests/psxtmrwlock06/psxtmrwlock06.doc
+++ b/testsuites/psxtmtests/psxtmrwlock06/psxtmrwlock06.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmrwlock07/psxtmrwlock07.doc b/testsuites/psxtmtests/psxtmrwlock07/psxtmrwlock07.doc
index 3b643cf408..c373a4ac78 100644
--- a/testsuites/psxtmtests/psxtmrwlock07/psxtmrwlock07.doc
+++ b/testsuites/psxtmtests/psxtmrwlock07/psxtmrwlock07.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmsem01/psxtmsem01.doc b/testsuites/psxtmtests/psxtmsem01/psxtmsem01.doc
index ceb7691bc7..1912f114e5 100644
--- a/testsuites/psxtmtests/psxtmsem01/psxtmsem01.doc
+++ b/testsuites/psxtmtests/psxtmsem01/psxtmsem01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmsem02/psxtmsem02.doc b/testsuites/psxtmtests/psxtmsem02/psxtmsem02.doc
index bec8910adc..fa894f9b80 100644
--- a/testsuites/psxtmtests/psxtmsem02/psxtmsem02.doc
+++ b/testsuites/psxtmtests/psxtmsem02/psxtmsem02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmsem03/psxtmsem03.doc b/testsuites/psxtmtests/psxtmsem03/psxtmsem03.doc
index 7b27c269b4..320cbed3ad 100644
--- a/testsuites/psxtmtests/psxtmsem03/psxtmsem03.doc
+++ b/testsuites/psxtmtests/psxtmsem03/psxtmsem03.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmsem04/psxtmsem04.doc b/testsuites/psxtmtests/psxtmsem04/psxtmsem04.doc
index bcab3f3d7a..6ff2eede30 100644
--- a/testsuites/psxtmtests/psxtmsem04/psxtmsem04.doc
+++ b/testsuites/psxtmtests/psxtmsem04/psxtmsem04.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmsem05/psxtmsem05.doc b/testsuites/psxtmtests/psxtmsem05/psxtmsem05.doc
index 713d7403e6..7e17512a4d 100644
--- a/testsuites/psxtmtests/psxtmsem05/psxtmsem05.doc
+++ b/testsuites/psxtmtests/psxtmsem05/psxtmsem05.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmsleep01/psxtmsleep01.doc b/testsuites/psxtmtests/psxtmsleep01/psxtmsleep01.doc
index e650ecf9f1..a4e86ba69d 100644
--- a/testsuites/psxtmtests/psxtmsleep01/psxtmsleep01.doc
+++ b/testsuites/psxtmtests/psxtmsleep01/psxtmsleep01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmsleep02/psxtmsleep02.doc b/testsuites/psxtmtests/psxtmsleep02/psxtmsleep02.doc
index dfd4720006..e9e3a2e477 100644
--- a/testsuites/psxtmtests/psxtmsleep02/psxtmsleep02.doc
+++ b/testsuites/psxtmtests/psxtmsleep02/psxtmsleep02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmthread01/psxtmthread01.doc b/testsuites/psxtmtests/psxtmthread01/psxtmthread01.doc
index a8284e00a2..edc9667008 100644
--- a/testsuites/psxtmtests/psxtmthread01/psxtmthread01.doc
+++ b/testsuites/psxtmtests/psxtmthread01/psxtmthread01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmthread03/psxtmthread03.doc b/testsuites/psxtmtests/psxtmthread03/psxtmthread03.doc
index 2fde771fff..a2a2eb07dd 100644
--- a/testsuites/psxtmtests/psxtmthread03/psxtmthread03.doc
+++ b/testsuites/psxtmtests/psxtmthread03/psxtmthread03.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/psxtmtests/psxtmthread04/psxtmthread04.doc b/testsuites/psxtmtests/psxtmthread04/psxtmthread04.doc
index ed75cab026..6aaa03b339 100644
--- a/testsuites/psxtmtests/psxtmthread04/psxtmthread04.doc
+++ b/testsuites/psxtmtests/psxtmthread04/psxtmthread04.doc
@@ -1,9 +1,28 @@
# COPYRIGHT (c) 1989-2013.
+# are met:
diff --git a/testsuites/psxtmtests/psxtmthread05/psxtmthread05.doc b/testsuites/psxtmtests/psxtmthread05/psxtmthread05.doc
index d635f1d80b..34554df1d3 100644
--- a/testsuites/psxtmtests/psxtmthread05/psxtmthread05.doc
+++ b/testsuites/psxtmtests/psxtmthread05/psxtmthread05.doc
@@ -1,9 +1,28 @@
+# are met:
2.24.4
