[PATCH 4/8] smptests/*/*.doc: Change license to BSD-2
Fri Jun 10 15:52:57 UTC 2022
Updates #3053.
 testsuites/smptests/smp01/smp01.doc           | 25 ++++++++++++++++---
 testsuites/smptests/smp02/smp02.doc           | 25 ++++++++++++++++---
 testsuites/smptests/smp03/smp03.doc           | 25 ++++++++++++++++---
 testsuites/smptests/smp05/smp05.doc           | 25 ++++++++++++++++---
 testsuites/smptests/smp07/smp07.doc           | 25 ++++++++++++++++---
 testsuites/smptests/smp08/smp08.doc           | 25 ++++++++++++++++---
 testsuites/smptests/smp09/smp09.doc           | 25 ++++++++++++++++---
 .../smptests/smpaffinity01/smpaffinity01.doc  | 25 ++++++++++++++++---
 .../smppsxaffinity01/smppsxaffinity01.doc     | 25 ++++++++++++++++---
 .../smppsxaffinity02/smppsxaffinity02.doc     | 25 ++++++++++++++++---
 10 files changed, 220 insertions(+), 30 deletions(-)
diff --git a/testsuites/smptests/smp01/smp01.doc b/testsuites/smptests/smp01/smp01.doc
index e3bed542d7..4cfb25e2fa 100644
--- a/testsuites/smptests/smp01/smp01.doc
+++ b/testsuites/smptests/smp01/smp01.doc
@@ -1,9 +1,28 @@
+# SPDX-License-Identifier: BSD-2-Clause
 #  COPYRIGHT (c) 1989-2011.
 #  On-Line Applications Research Corporation (OAR).
-#  The license and distribution terms for this file may be
-#  found in the file LICENSE in this distribution or at
-#  http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+#    notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+#    notice, this list of conditions and the following disclaimer in the
+#    documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
 This is a simple test that verifies that each of the smp
diff --git a/testsuites/smptests/smp02/smp02.doc b/testsuites/smptests/smp02/smp02.doc
index ba916d32dc..a197328dc2 100644
--- a/testsuites/smptests/smp02/smp02.doc
+++ b/testsuites/smptests/smp02/smp02.doc
@@ -1,9 +1,28 @@
+# are met:
 This test creates tasks for each process (other than the
 one that Init is running on).  Then drops into a loop waiting
diff --git a/testsuites/smptests/smp03/smp03.doc b/testsuites/smptests/smp03/smp03.doc
index b7c3bb2853..c032ca6c60 100644
--- a/testsuites/smptests/smp03/smp03.doc
+++ b/testsuites/smptests/smp03/smp03.doc
@@ -1,9 +1,28 @@
+# are met:
 This test runs the init task on the first CPU at a priority
 of 5.  The Init task creates tasks for each remaining processor
diff --git a/testsuites/smptests/smp05/smp05.doc b/testsuites/smptests/smp05/smp05.doc
index 8132fa18d7..10e57b05b3 100644
--- a/testsuites/smptests/smp05/smp05.doc
+++ b/testsuites/smptests/smp05/smp05.doc
@@ -1,9 +1,28 @@
+# are met:
 This file describes the directives and concepts tested by this test set.
diff --git a/testsuites/smptests/smp07/smp07.doc b/testsuites/smptests/smp07/smp07.doc
index 1132584f10..c9d021fa83 100644
--- a/testsuites/smptests/smp07/smp07.doc
+++ b/testsuites/smptests/smp07/smp07.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/smptests/smp08/smp08.doc b/testsuites/smptests/smp08/smp08.doc
index a2feb9c45d..513dbc6036 100644
--- a/testsuites/smptests/smp08/smp08.doc
+++ b/testsuites/smptests/smp08/smp08.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/smptests/smp09/smp09.doc b/testsuites/smptests/smp09/smp09.doc
index 8836c94bc6..283234c858 100644
--- a/testsuites/smptests/smp09/smp09.doc
+++ b/testsuites/smptests/smp09/smp09.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/smptests/smpaffinity01/smpaffinity01.doc b/testsuites/smptests/smpaffinity01/smpaffinity01.doc
index fe6225ba62..c1f1c8518c 100644
--- a/testsuites/smptests/smpaffinity01/smpaffinity01.doc
+++ b/testsuites/smptests/smpaffinity01/smpaffinity01.doc
@@ -1,9 +1,28 @@
 #  COPYRIGHT (c) 1989-2014.
+# are met:
diff --git a/testsuites/smptests/smppsxaffinity01/smppsxaffinity01.doc b/testsuites/smptests/smppsxaffinity01/smppsxaffinity01.doc
index db4ab87c8e..9ed60c4616 100644
--- a/testsuites/smptests/smppsxaffinity01/smppsxaffinity01.doc
+++ b/testsuites/smptests/smppsxaffinity01/smppsxaffinity01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/smptests/smppsxaffinity02/smppsxaffinity02.doc b/testsuites/smptests/smppsxaffinity02/smppsxaffinity02.doc
index 857282c508..08d1000f0c 100644
--- a/testsuites/smptests/smppsxaffinity02/smppsxaffinity02.doc
+++ b/testsuites/smptests/smppsxaffinity02/smppsxaffinity02.doc
@@ -1,9 +1,28 @@
+# are met:
 directives:
2.24.4
