[PATCH 5/8] mptests/*/*.doc: Change license to BSD-2
Fri Jun 10 15:52:58 UTC 2022
Updates #3053.
 testsuites/mptests/mp01/mp01-node1.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp01/mp01-node2.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp03/mp03-node1.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp03/mp03-node2.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp04/mp04-node1.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp04/mp04-node2.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp05/mp05-node1.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp05/mp05-node2.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp06/mp06-node1.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp06/mp06-node2.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp07/mp07-node1.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp07/mp07-node2.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp08/mp08-node1.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp08/mp08-node2.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp09/mp09-node1.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp09/mp09-node2.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp10/mp10-node1.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp10/mp10-node2.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp11/mp11-node1.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp11/mp11-node2.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp12/mp12-node1.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp12/mp12-node2.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp13/mp13-node1.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp13/mp13-node2.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp14/mp14-node1.doc | 25 ++++++++++++++++++++++---
 testsuites/mptests/mp14/mp14-node2.doc | 25 ++++++++++++++++++++++---
 26 files changed, 572 insertions(+), 78 deletions(-)
diff --git a/testsuites/mptests/mp01/mp01-node1.doc b/testsuites/mptests/mp01/mp01-node1.doc
index dff9f2f8d2..db4be4808a 100644
--- a/testsuites/mptests/mp01/mp01-node1.doc
+++ b/testsuites/mptests/mp01/mp01-node1.doc
@@ -1,9 +1,28 @@
+# SPDX-License-Identifier: BSD-2-Clause
 #  COPYRIGHT (c) 1989-1999.
 #  On-Line Applications Research Corporation (OAR).
-#  The license and distribution terms for this file may be
-#  found in the file LICENSE in this distribution or at
-#  http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+#    notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+#    notice, this list of conditions and the following disclaimer in the
+#    documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
diff --git a/testsuites/mptests/mp01/mp01-node2.doc b/testsuites/mptests/mp01/mp01-node2.doc
index 981286480f..f56c0e1f4e 100644
--- a/testsuites/mptests/mp01/mp01-node2.doc
+++ b/testsuites/mptests/mp01/mp01-node2.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp03/mp03-node1.doc b/testsuites/mptests/mp03/mp03-node1.doc
index f2d149e85e..9fed0e2279 100644
--- a/testsuites/mptests/mp03/mp03-node1.doc
+++ b/testsuites/mptests/mp03/mp03-node1.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp03/mp03-node2.doc b/testsuites/mptests/mp03/mp03-node2.doc
--- a/testsuites/mptests/mp03/mp03-node2.doc
+++ b/testsuites/mptests/mp03/mp03-node2.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp04/mp04-node1.doc b/testsuites/mptests/mp04/mp04-node1.doc
index 4ff3647852..364201823f 100644
--- a/testsuites/mptests/mp04/mp04-node1.doc
+++ b/testsuites/mptests/mp04/mp04-node1.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp04/mp04-node2.doc b/testsuites/mptests/mp04/mp04-node2.doc
--- a/testsuites/mptests/mp04/mp04-node2.doc
+++ b/testsuites/mptests/mp04/mp04-node2.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp05/mp05-node1.doc b/testsuites/mptests/mp05/mp05-node1.doc
index a9042ada9c..641d1a6f9a 100644
--- a/testsuites/mptests/mp05/mp05-node1.doc
+++ b/testsuites/mptests/mp05/mp05-node1.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp05/mp05-node2.doc b/testsuites/mptests/mp05/mp05-node2.doc
--- a/testsuites/mptests/mp05/mp05-node2.doc
+++ b/testsuites/mptests/mp05/mp05-node2.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp06/mp06-node1.doc b/testsuites/mptests/mp06/mp06-node1.doc
index 03c278fd33..fb22dc3414 100644
--- a/testsuites/mptests/mp06/mp06-node1.doc
+++ b/testsuites/mptests/mp06/mp06-node1.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp06/mp06-node2.doc b/testsuites/mptests/mp06/mp06-node2.doc
--- a/testsuites/mptests/mp06/mp06-node2.doc
+++ b/testsuites/mptests/mp06/mp06-node2.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp07/mp07-node1.doc b/testsuites/mptests/mp07/mp07-node1.doc
index c66e75c08c..c44933ce7f 100644
--- a/testsuites/mptests/mp07/mp07-node1.doc
+++ b/testsuites/mptests/mp07/mp07-node1.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp07/mp07-node2.doc b/testsuites/mptests/mp07/mp07-node2.doc
--- a/testsuites/mptests/mp07/mp07-node2.doc
+++ b/testsuites/mptests/mp07/mp07-node2.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp08/mp08-node1.doc b/testsuites/mptests/mp08/mp08-node1.doc
index f71bc3c1a3..5526bbf7be 100644
--- a/testsuites/mptests/mp08/mp08-node1.doc
+++ b/testsuites/mptests/mp08/mp08-node1.doc
@@ -1,9 +1,28 @@
+# are met:
 This file describes the directives and concepts tested by this test set.
diff --git a/testsuites/mptests/mp08/mp08-node2.doc b/testsuites/mptests/mp08/mp08-node2.doc
--- a/testsuites/mptests/mp08/mp08-node2.doc
+++ b/testsuites/mptests/mp08/mp08-node2.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp09/mp09-node1.doc b/testsuites/mptests/mp09/mp09-node1.doc
index fce639b0f8..64a2f65348 100644
--- a/testsuites/mptests/mp09/mp09-node1.doc
+++ b/testsuites/mptests/mp09/mp09-node1.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp09/mp09-node2.doc b/testsuites/mptests/mp09/mp09-node2.doc
--- a/testsuites/mptests/mp09/mp09-node2.doc
+++ b/testsuites/mptests/mp09/mp09-node2.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp10/mp10-node1.doc b/testsuites/mptests/mp10/mp10-node1.doc
index fc926b0519..651a6a3c9b 100644
--- a/testsuites/mptests/mp10/mp10-node1.doc
+++ b/testsuites/mptests/mp10/mp10-node1.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp10/mp10-node2.doc b/testsuites/mptests/mp10/mp10-node2.doc
--- a/testsuites/mptests/mp10/mp10-node2.doc
+++ b/testsuites/mptests/mp10/mp10-node2.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp11/mp11-node1.doc b/testsuites/mptests/mp11/mp11-node1.doc
index 0722980766..bb1ab37981 100644
--- a/testsuites/mptests/mp11/mp11-node1.doc
+++ b/testsuites/mptests/mp11/mp11-node1.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp11/mp11-node2.doc b/testsuites/mptests/mp11/mp11-node2.doc
--- a/testsuites/mptests/mp11/mp11-node2.doc
+++ b/testsuites/mptests/mp11/mp11-node2.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp12/mp12-node1.doc b/testsuites/mptests/mp12/mp12-node1.doc
index e655bfdff8..9b3fbf8273 100644
--- a/testsuites/mptests/mp12/mp12-node1.doc
+++ b/testsuites/mptests/mp12/mp12-node1.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp12/mp12-node2.doc b/testsuites/mptests/mp12/mp12-node2.doc
--- a/testsuites/mptests/mp12/mp12-node2.doc
+++ b/testsuites/mptests/mp12/mp12-node2.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp13/mp13-node1.doc b/testsuites/mptests/mp13/mp13-node1.doc
index 2033d6e8b9..9bddb0bdcc 100644
--- a/testsuites/mptests/mp13/mp13-node1.doc
+++ b/testsuites/mptests/mp13/mp13-node1.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp13/mp13-node2.doc b/testsuites/mptests/mp13/mp13-node2.doc
--- a/testsuites/mptests/mp13/mp13-node2.doc
+++ b/testsuites/mptests/mp13/mp13-node2.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp14/mp14-node1.doc b/testsuites/mptests/mp14/mp14-node1.doc
index 3a9e7c6c4e..f743ca03f1 100644
--- a/testsuites/mptests/mp14/mp14-node1.doc
+++ b/testsuites/mptests/mp14/mp14-node1.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/mptests/mp14/mp14-node2.doc b/testsuites/mptests/mp14/mp14-node2.doc
--- a/testsuites/mptests/mp14/mp14-node2.doc
+++ b/testsuites/mptests/mp14/mp14-node2.doc
@@ -1,9 +1,28 @@
+# are met:
2.24.4
