[PATCH 6/8] sptests/*/*.doc: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Jun 10 15:52:59 UTC 2022
Updates #3053.
testsuites/sptests/spheapprot/spheapprot.doc | 23 +++++++++++++++++---
1 file changed, 20 insertions(+), 3 deletions(-)
diff --git a/testsuites/sptests/spheapprot/spheapprot.doc b/testsuites/sptests/spheapprot/spheapprot.doc
index 9d01a7b005..0ac3545ece 100644
--- a/testsuites/sptests/spheapprot/spheapprot.doc
+++ b/testsuites/sptests/spheapprot/spheapprot.doc
@@ -2,9 +2,26 @@
# Copyright (c) 2010 embedded brains GmbH. All rights reserved.
-# The license and distribution terms for this file may be
-# found in the file LICENSE in this distribution or at
-# http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+# notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+# notice, this list of conditions and the following disclaimer in the
+# documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
This file describes the directives and concepts tested by this test set.
2.24.4
