[newlib 09/22] iflib: Improve mapping of TX/RX queues to CPUs
Sebastian Huber
Wed Jun 22 08:24:32 UTC 2022
iflib now supports mapping each (TX,RX) queue pair to the same CPU
(default), to separate CPUs, or to a pair of physical and logical CPUs
that share the same L2 cache. The mapping mechanism supports unequal
numbers of TX and RX queues, with the excess queues always being
mapped to consecutive physical CPUs. When the platform cannot
distinguish between physical and logical CPUs, all are treated as
physical CPUs. See the comment on get_cpuid_for_queue() for the
entire matrix.
The following device-specific tunables influence the mapping process:
dev.<device>.<unit>.iflib.core_offset (existing)
dev.<device>.<unit>.iflib.separate_txrx (existing)
dev.<device>.<unit>.iflib.use_logical_cores (new)
The following new, read-only sysctls provide visibility of the mapping
results:
dev.<device>.<unit>.iflib.{t,r}xq<n>.cpu
When an iflib driver allocates TX softirqs without providing reference
RX IRQs, iflib now binds those TX softirqs to CPUs using the above
mapping mechanism (that is, treats them as if they were TX IRQs).
Previously, such bindings were left up to the grouptaskqueue code and
thus fell outside of the iflib CPU mapping strategy.
Reviewed by: kbowling
Tested by: olivier, pkelsey
MFC after: 3 weeks
Differential Revision: https://reviews.freebsd.org/D24094
newlib/libc/sys/rtems/include/sys/cpuset.h | 1 +
1 file changed, 1 insertion(+)
diff --git a/newlib/libc/sys/rtems/include/sys/cpuset.h b/newlib/libc/sys/rtems/include/sys/cpuset.h
index 7958e3b1a..a321bddc2 100644
--- a/newlib/libc/sys/rtems/include/sys/cpuset.h
+++ b/newlib/libc/sys/rtems/include/sys/cpuset.h
@@ -61,6 +61,7 @@
#define CPU_OR_ATOMIC(d, s) BIT_OR_ATOMIC(CPU_SETSIZE, d, s)
#define CPU_COPY_STORE_REL(f, t) BIT_COPY_STORE_REL(CPU_SETSIZE, f, t)
#define CPU_FFS(p) BIT_FFS(CPU_SETSIZE, p)
+#define CPU_FLS(p) BIT_FLS(CPU_SETSIZE, p)
#define CPUSET_FSET BITSET_FSET(_NCPUWORDS)
#define CPUSET_T_INITIALIZER BITSET_T_INITIALIZER
2.35.3
