[PATCH] arm/gicv3: Fix building arm/r52
Fri Jun 24 09:44:23 UTC 2022
On 20.06.22 04:03, chrisj at rtems.org wrote:
> From: Chris Johns <chrisj at rtems.org>
>   bsps/include/dev/irq/arm-gicv3.h | 5 +++++
>   1 file changed, 5 insertions(+)
> diff --git a/bsps/include/dev/irq/arm-gicv3.h b/bsps/include/dev/irq/arm-gicv3.h
> index a79368ebdf..aac02fa191 100644
> --- a/bsps/include/dev/irq/arm-gicv3.h
> +++ b/bsps/include/dev/irq/arm-gicv3.h
> @@ -335,7 +335,12 @@ static void gicv3_init_cpu_interface(uint32_t cpu_index)
>     /* Enable interrupt groups 0 and 1 */
> +#ifdef ARM_MULTILIB_ARCH_V4
> +  WRITE_SR(ICC_IGRPEN0, 0x1);
> +  WRITE_SR(ICC_IGRPEN1, 0x1);
> +#else
>     gic_icc_write(IGRPEN1, 1);
> +#endif
>     WRITE_SR(ICC_CTLR, 0x0);
I have a different patch to fix this:
https://lists.rtems.org/pipermail/devel/2022-June/072056.html
Why was the isb added? Why was the IGRPEN0 write removed in
e70384d3f406251422bac64d11ff44570a678434?
I have to check if the removed ICC_BPR0 is an issue for AArch32.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
