[PATCH] arm/gicv3: Fix building arm/r52
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Jun 28 03:38:30 UTC 2022
On 6/27/2022 01:27, Sebastian Huber wrote:
> On 27/06/2022 05:02, Chris Johns wrote:
>> On 24/6/2022 7:44 pm, Sebastian Huber wrote:
>>> On 20.06.22 04:03, chrisj at rtems.org wrote:
>>>> From: Chris Johns <chrisj at rtems.org>
>>>> bsps/include/dev/irq/arm-gicv3.h | 5 +++++
>>>> 1 file changed, 5 insertions(+)
>>>> diff --git a/bsps/include/dev/irq/arm-gicv3.h
>>>> b/bsps/include/dev/irq/arm-gicv3.h
>>>> index a79368ebdf..aac02fa191 100644
>>>> --- a/bsps/include/dev/irq/arm-gicv3.h
>>>> +++ b/bsps/include/dev/irq/arm-gicv3.h
>>>> @@ -335,7 +335,12 @@ static void gicv3_init_cpu_interface(uint32_t
>>>> cpu_index)
>>>> /* Enable interrupt groups 0 and 1 */
>>>> +#ifdef ARM_MULTILIB_ARCH_V4
>>>> + WRITE_SR(ICC_IGRPEN0, 0x1);
>>>> + WRITE_SR(ICC_IGRPEN1, 0x1);
>>>> +#else
>>>> gic_icc_write(IGRPEN1, 1);
>>>> +#endif
>>>> WRITE_SR(ICC_CTLR, 0x0);
>>> I have a different patch to fix this:
>>> https://lists.rtems.org/pipermail/devel/2022-June/072056.html
>> Does this change work on a real aarch64 with a suitably configured
>> TF-A? The
>> security profile of the TF-A needs to disable EL1 access to these
>> registers to
>> see the issue.
> I don't have a hardware to test this change. I can do tests on a
> Cortex-R52 hardware.
> For the Cortex-R52, group 0 interrupts are signaled through FIQ
> exceptions and group 1 interrupts are signaled through IRQ exceptions.
> This processor has no secore/non-secure states.
I have reverified that this code works on my ZCU102 (ZynqMP) dev board
with just the write to IGRPEN1, but I'm not sure it's what Chris would
consider a suitably configured TF-A since it's a bit stale.
Kinsey
