[PATCH] arm/gicv3: Fix building arm/r52
Sebastian Huber
Wed Jun 29 15:42:31 UTC 2022
On 27/06/2022 08:27, Sebastian Huber wrote:
> On 27/06/2022 05:02, Chris Johns wrote:
>> On 24/6/2022 7:44 pm, Sebastian Huber wrote:
>>> On 20.06.22 04:03, chrisj at rtems.org wrote:
>>>> From: Chris Johns <chrisj at rtems.org>
>>>> bsps/include/dev/irq/arm-gicv3.h | 5 +++++
>>>> 1 file changed, 5 insertions(+)
>>>> diff --git a/bsps/include/dev/irq/arm-gicv3.h
>>>> b/bsps/include/dev/irq/arm-gicv3.h
>>>> index a79368ebdf..aac02fa191 100644
>>>> --- a/bsps/include/dev/irq/arm-gicv3.h
>>>> +++ b/bsps/include/dev/irq/arm-gicv3.h
>>>> @@ -335,7 +335,12 @@ static void gicv3_init_cpu_interface(uint32_t
>>>> cpu_index)
>>>> /* Enable interrupt groups 0 and 1 */
>>>> +#ifdef ARM_MULTILIB_ARCH_V4
>>>> + WRITE_SR(ICC_IGRPEN0, 0x1);
>>>> + WRITE_SR(ICC_IGRPEN1, 0x1);
>>>> +#else
>>>> gic_icc_write(IGRPEN1, 1);
>>>> +#endif
>>>> WRITE_SR(ICC_CTLR, 0x0);
>>> I have a different patch to fix this:
>>> https://lists.rtems.org/pipermail/devel/2022-June/072056.html
>> Does this change work on a real aarch64 with a suitably configured
>> TF-A? The
>> security profile of the TF-A needs to disable EL1 access to these
>> registers to
>> see the issue.
> I don't have a hardware to test this change. I can do tests on a
> Cortex-R52 hardware.
> For the Cortex-R52, group 0 interrupts are signaled through FIQ
> exceptions and group 1 interrupts are signaled through IRQ exceptions.
> This processor has no secore/non-secure states.
I checked the GICv3 manual. The group 0 interrupts are always Secure if
the system has at least two Security states. So, if RTEMS runs in
Non-Secure mode, it cannot modify group 0 interrupts. We have some
things to consider:
1. Count of system security states
2. In which state RTEMS runs
3. What RTEMS needs to initialize
We cannot simply use the target architecture to determine what to do
during GIC initialization. I think we need some BSP options to control
the initialization behaviour.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
