STM32H7 HAL update, merge ready.
Sebastian Huber
Thu Mar 10 15:10:21 UTC 2022
On 10/03/2022 15:24, Karel Gardas wrote:
> On 3/10/22 15:06, Sebastian Huber wrote:
>>> So, the only way out of the chaos was to:
>>> 1) replace all HAL files with new files
>> Yes, this is fine, but if all the new files have now UNIX line endings
>> why didn't you change the existing files to UNIX line endings before
>> the update? I guess you copied the files from a Git repository. Can't
>> you first change the existing files to UNIX line endings and make a
>> commit. Then copy the files from your upstream Git repository.
> Honestly, I've tried that IIRC, but result was that the diff was still
> not right. I investigated at that time and found out that there were
> file(s) (few) which were using mixed line encoding at that time. E.g.
> someone edited LF file with CRLF editor and then file was using LF +
> CRLF on edited lines. Something like that.
I converted the files to UNIX line endings using:
dos2unix `find -type f `
https://github.com/sebhub/rtems/tree/stm32h7-unix-line-endings
I can't rebase your branch on top if it, however, from the looking at
the merge conflicts it is clear that the individual files are related.
> So the pain of dealing with this mess was so high and unnecessary since
> those were HAL files anyway that I changed the approach to just simply
> replace the files.
Replacing the files is fine, but please copy them on top of the original
files converted to UNIX line endings. Do you still have a checkout of
the STM Git repository available to copy the files again?
> If you would like to review changes in HAL files, then you may diff
> original merged projects files. They both are on github.com so you can
> investigate either there or on local copy. But this is HAL code,
> something STMicro provided and I don't see any point in dealing with
> that -- unless there is some bug to report...
It is quite likely that this update breaks something and a reviewable
history could help here. Another option would be to do the updates in
smaller steps so that a git bisect is more effective.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
