[PATCH 02/26] cpukit/libdl Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Mar 18 16:21:09 UTC 2022
Updates #3053.
cpukit/libdl/dlfcn-shell.c | 25 ++++++++++++++++++++++---
cpukit/libdl/dlfcn.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rap-shell.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rap.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-alloc-heap.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-alloc-heap.h | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-allocator.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-archive.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-bit-alloc.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-bit-alloc.h | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-chain-iterator.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-chain-iterator.h | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-debugger.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-elf.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-elf.h | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-error.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-error.h | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-find-file.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-find-file.h | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-obj-cache.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-obj-comp.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-obj.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-rap.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-rap.h | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-shell.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-string.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-string.h | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-sym.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-trace.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-trampoline.h | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-unresolved.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-unwind-dw2.c | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-unwind-dw2.h | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl-unwind.h | 25 ++++++++++++++++++++++---
cpukit/libdl/rtl.c | 25 ++++++++++++++++++++++---
35 files changed, 770 insertions(+), 105 deletions(-)
diff --git a/cpukit/libdl/dlfcn-shell.c b/cpukit/libdl/dlfcn-shell.c
index 67a6e6b8b7..84a5d78e4a 100644
--- a/cpukit/libdl/dlfcn-shell.c
+++ b/cpukit/libdl/dlfcn-shell.c
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2012, 2018 Chris Johns <chrisj at rtems.org>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
* @file
diff --git a/cpukit/libdl/dlfcn.c b/cpukit/libdl/dlfcn.c
index e90ed43668..1eeb663b08 100644
--- a/cpukit/libdl/dlfcn.c
+++ b/cpukit/libdl/dlfcn.c
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rap-shell.c b/cpukit/libdl/rap-shell.c
index 78a3b539b9..dcb5c2ad1e 100644
--- a/cpukit/libdl/rap-shell.c
+++ b/cpukit/libdl/rap-shell.c
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2013 Chris Johns <chrisj at rtems.org>
+ * are met:
* @file
diff --git a/cpukit/libdl/rap.c b/cpukit/libdl/rap.c
index e6585c706b..a11695f2ee 100644
--- a/cpukit/libdl/rap.c
+++ b/cpukit/libdl/rap.c
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-alloc-heap.c b/cpukit/libdl/rtl-alloc-heap.c
index f1bdcca507..d843f491b0 100644
--- a/cpukit/libdl/rtl-alloc-heap.c
+++ b/cpukit/libdl/rtl-alloc-heap.c
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2012 Chris Johns <chrisj at rtems.org>
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-alloc-heap.h b/cpukit/libdl/rtl-alloc-heap.h
index 6b7018b400..b16778a467 100644
--- a/cpukit/libdl/rtl-alloc-heap.h
+++ b/cpukit/libdl/rtl-alloc-heap.h
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-allocator.c b/cpukit/libdl/rtl-allocator.c
index 647c0c89a4..7c6f972c02 100644
--- a/cpukit/libdl/rtl-allocator.c
+++ b/cpukit/libdl/rtl-allocator.c
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-archive.c b/cpukit/libdl/rtl-archive.c
index 6eba1585b6..17cb5f6e16 100644
--- a/cpukit/libdl/rtl-archive.c
+++ b/cpukit/libdl/rtl-archive.c
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2018 Chris Johns <chrisj at rtems.org>
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-bit-alloc.c b/cpukit/libdl/rtl-bit-alloc.c
index b494797e7d..4570a6d0f8 100644
--- a/cpukit/libdl/rtl-bit-alloc.c
+++ b/cpukit/libdl/rtl-bit-alloc.c
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2019 Chris Johns <chrisj at rtems.org>
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-bit-alloc.h b/cpukit/libdl/rtl-bit-alloc.h
index d977473a96..a4c264544d 100644
--- a/cpukit/libdl/rtl-bit-alloc.h
+++ b/cpukit/libdl/rtl-bit-alloc.h
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-chain-iterator.c b/cpukit/libdl/rtl-chain-iterator.c
index 4e98c203d1..2591e26567 100644
--- a/cpukit/libdl/rtl-chain-iterator.c
+++ b/cpukit/libdl/rtl-chain-iterator.c
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-chain-iterator.h b/cpukit/libdl/rtl-chain-iterator.h
index 5811715da0..860df0960b 100644
--- a/cpukit/libdl/rtl-chain-iterator.h
+++ b/cpukit/libdl/rtl-chain-iterator.h
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-debugger.c b/cpukit/libdl/rtl-debugger.c
index 1ab619d194..65e9db8a5b 100644
--- a/cpukit/libdl/rtl-debugger.c
+++ b/cpukit/libdl/rtl-debugger.c
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-elf.c b/cpukit/libdl/rtl-elf.c
index 75b3d9c953..4a8f1cb752 100644
--- a/cpukit/libdl/rtl-elf.c
+++ b/cpukit/libdl/rtl-elf.c
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2012-2019 Chris Johns <chrisj at rtems.org>
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-elf.h b/cpukit/libdl/rtl-elf.h
index 3bbc0bd9ee..8c14f16181 100644
--- a/cpukit/libdl/rtl-elf.h
+++ b/cpukit/libdl/rtl-elf.h
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2012-2018 Chris Johns <chrisj at rtems.org>
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-error.c b/cpukit/libdl/rtl-error.c
index f7c046861c..6132c376be 100644
--- a/cpukit/libdl/rtl-error.c
+++ b/cpukit/libdl/rtl-error.c
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-error.h b/cpukit/libdl/rtl-error.h
index 576384ed5d..7c04ac97e7 100644
--- a/cpukit/libdl/rtl-error.h
+++ b/cpukit/libdl/rtl-error.h
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-find-file.c b/cpukit/libdl/rtl-find-file.c
index b354a1dce2..23c7bc6024 100644
--- a/cpukit/libdl/rtl-find-file.c
+++ b/cpukit/libdl/rtl-find-file.c
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2012-2013 Chris Johns <chrisj at rtems.org>
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-find-file.h b/cpukit/libdl/rtl-find-file.h
index 86cd8fe313..52a1843a42 100644
--- a/cpukit/libdl/rtl-find-file.h
+++ b/cpukit/libdl/rtl-find-file.h
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-obj-cache.c b/cpukit/libdl/rtl-obj-cache.c
index 8791e2b1d5..bceca37c58 100644
--- a/cpukit/libdl/rtl-obj-cache.c
+++ b/cpukit/libdl/rtl-obj-cache.c
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-obj-comp.c b/cpukit/libdl/rtl-obj-comp.c
index 4608a41bf4..bc333424ce 100644
--- a/cpukit/libdl/rtl-obj-comp.c
+++ b/cpukit/libdl/rtl-obj-comp.c
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-obj.c b/cpukit/libdl/rtl-obj.c
index a7dd740549..6957100485 100644
--- a/cpukit/libdl/rtl-obj.c
+++ b/cpukit/libdl/rtl-obj.c
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-rap.c b/cpukit/libdl/rtl-rap.c
index 32f4bd6ff5..7eaa213218 100644
--- a/cpukit/libdl/rtl-rap.c
+++ b/cpukit/libdl/rtl-rap.c
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2012-2013, 2018 Chris Johns <chrisj at rtems.org>
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-rap.h b/cpukit/libdl/rtl-rap.h
index ae656c25ca..8ded95758f 100644
--- a/cpukit/libdl/rtl-rap.h
+++ b/cpukit/libdl/rtl-rap.h
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-shell.c b/cpukit/libdl/rtl-shell.c
index 9f8a1364a8..a58384f22f 100644
--- a/cpukit/libdl/rtl-shell.c
+++ b/cpukit/libdl/rtl-shell.c
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-string.c b/cpukit/libdl/rtl-string.c
index 61ab4925d5..373f9914cc 100644
--- a/cpukit/libdl/rtl-string.c
+++ b/cpukit/libdl/rtl-string.c
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-string.h b/cpukit/libdl/rtl-string.h
index 1aa2624fdf..6a1a4db8c7 100644
--- a/cpukit/libdl/rtl-string.h
+++ b/cpukit/libdl/rtl-string.h
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-sym.c b/cpukit/libdl/rtl-sym.c
index 593069fba0..3fea4b5d20 100644
--- a/cpukit/libdl/rtl-sym.c
+++ b/cpukit/libdl/rtl-sym.c
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2012-2014, 2018 Chris Johns <chrisj at rtems.org>
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-trace.c b/cpukit/libdl/rtl-trace.c
index 15d195ffad..884cab685c 100644
--- a/cpukit/libdl/rtl-trace.c
+++ b/cpukit/libdl/rtl-trace.c
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-trampoline.h b/cpukit/libdl/rtl-trampoline.h
index e04c20863b..21aed8a1c3 100644
--- a/cpukit/libdl/rtl-trampoline.h
+++ b/cpukit/libdl/rtl-trampoline.h
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-unresolved.c b/cpukit/libdl/rtl-unresolved.c
index 8e1c2abc90..caf7ac6b10 100644
--- a/cpukit/libdl/rtl-unresolved.c
+++ b/cpukit/libdl/rtl-unresolved.c
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-unwind-dw2.c b/cpukit/libdl/rtl-unwind-dw2.c
index 0526fa5e5b..f2299981d5 100644
--- a/cpukit/libdl/rtl-unwind-dw2.c
+++ b/cpukit/libdl/rtl-unwind-dw2.c
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2012-2016, 2018 Chris Johns <chrisj at rtems.org>
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-unwind-dw2.h b/cpukit/libdl/rtl-unwind-dw2.h
index ef76a3771b..7cc781c14f 100644
--- a/cpukit/libdl/rtl-unwind-dw2.h
+++ b/cpukit/libdl/rtl-unwind-dw2.h
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2016, 2018 Chris Johns <chrisj at rtems.org>
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl-unwind.h b/cpukit/libdl/rtl-unwind.h
index 36ec5c4a11..f24f83c23e 100644
--- a/cpukit/libdl/rtl-unwind.h
+++ b/cpukit/libdl/rtl-unwind.h
@@ -1,9 +1,28 @@
+ * are met:
* @file
diff --git a/cpukit/libdl/rtl.c b/cpukit/libdl/rtl.c
index b86f7cc850..57449d44b8 100644
--- a/cpukit/libdl/rtl.c
+++ b/cpukit/libdl/rtl.c
@@ -1,9 +1,28 @@
+ * are met:
* @file
2.24.4
