[PATCH 10/26] cpukit/libpci: Change license to BSD-2
Fri Mar 18 16:21:17 UTC 2022
Updates #3053.
 cpukit/libpci/pci_access.c         | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_access_func.c    | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_access_io.c      | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_access_mem.c     | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_access_mem_be.c  | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_access_mem_le.c  | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_bus.c            | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_cfg.c            | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_cfg_auto.c       | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_cfg_peripheral.c | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_cfg_print_code.c | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_cfg_read.c       | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_cfg_static.c     | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_find.c           | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_find_dev.c       | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_for_each.c       | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_for_each_child.c | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_for_each_dev.c   | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_get_dev.c        | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_internal.h       | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_irq.c            | 25 ++++++++++++++++++++++---
 cpukit/libpci/pci_print.c          | 25 ++++++++++++++++++++++---
 22 files changed, 484 insertions(+), 66 deletions(-)
diff --git a/cpukit/libpci/pci_access.c b/cpukit/libpci/pci_access.c
index 11e48c1de7..8f79ac441f 100644
--- a/cpukit/libpci/pci_access.c
+++ b/cpukit/libpci/pci_access.c
@@ -1,10 +1,29 @@
 /*  PCI Access Library
  *  COPYRIGHT (c) 2010 Cobham Gaisler AB.
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #include <pci.h>
diff --git a/cpukit/libpci/pci_access_func.c b/cpukit/libpci/pci_access_func.c
index a6fd0bba96..fb77819745 100644
--- a/cpukit/libpci/pci_access_func.c
+++ b/cpukit/libpci/pci_access_func.c
@@ -1,10 +1,29 @@
+ * are met:
 #include <pci.h>
diff --git a/cpukit/libpci/pci_access_io.c b/cpukit/libpci/pci_access_io.c
index 4593b7958e..ffaf31395f 100644
--- a/cpukit/libpci/pci_access_io.c
+++ b/cpukit/libpci/pci_access_io.c
@@ -1,10 +1,29 @@
+ * are met:
 #include <pci.h>
diff --git a/cpukit/libpci/pci_access_mem.c b/cpukit/libpci/pci_access_mem.c
index ba94f54569..907b0a4a90 100644
--- a/cpukit/libpci/pci_access_mem.c
+++ b/cpukit/libpci/pci_access_mem.c
@@ -1,11 +1,30 @@
  *  Registers-over-Memory Space - Generic Big/Little endian PCI bus definitions
+ * are met:
 #include <pci.h>
diff --git a/cpukit/libpci/pci_access_mem_be.c b/cpukit/libpci/pci_access_mem_be.c
index e862b3ac70..13808f6cb8 100644
--- a/cpukit/libpci/pci_access_mem_be.c
+++ b/cpukit/libpci/pci_access_mem_be.c
@@ -1,11 +1,30 @@
  *  Registers-over-Memory Space - Generic Big endian PCI bus definitions
+ * are met:
 #include <pci.h>
diff --git a/cpukit/libpci/pci_access_mem_le.c b/cpukit/libpci/pci_access_mem_le.c
index 63393fe2db..bc043207c1 100644
--- a/cpukit/libpci/pci_access_mem_le.c
+++ b/cpukit/libpci/pci_access_mem_le.c
@@ -1,11 +1,30 @@
  *  Registers-over-Memory Space - Generic Little endian PCI bus definitions
+ * are met:
 #include <pci.h>
diff --git a/cpukit/libpci/pci_bus.c b/cpukit/libpci/pci_bus.c
index 115deebd8d..5c470a39ed 100644
--- a/cpukit/libpci/pci_bus.c
+++ b/cpukit/libpci/pci_bus.c
@@ -1,10 +1,29 @@
 /*  PCI bus driver.
  *  COPYRIGHT (c) 2008 Cobham Gaisler AB.
+ * are met:
 /* General part of PCI Bus driver. The driver is typically
diff --git a/cpukit/libpci/pci_cfg.c b/cpukit/libpci/pci_cfg.c
index 7a24d82b81..29120a4d3e 100644
--- a/cpukit/libpci/pci_cfg.c
+++ b/cpukit/libpci/pci_cfg.c
@@ -1,10 +1,29 @@
 /*  PCI Configuration Library
+ * are met:
 #include <pci/cfg.h>
diff --git a/cpukit/libpci/pci_cfg_auto.c b/cpukit/libpci/pci_cfg_auto.c
index 60708106a0..a35bd83eb8 100644
--- a/cpukit/libpci/pci_cfg_auto.c
+++ b/cpukit/libpci/pci_cfg_auto.c
@@ -1,10 +1,29 @@
 /*  PCI (Auto) configuration Library. Setup PCI configuration space and IRQ.
+ * are met:
diff --git a/cpukit/libpci/pci_cfg_peripheral.c b/cpukit/libpci/pci_cfg_peripheral.c
index 10629fe8e4..b6006d0b89 100644
--- a/cpukit/libpci/pci_cfg_peripheral.c
+++ b/cpukit/libpci/pci_cfg_peripheral.c
@@ -1,10 +1,29 @@
 /*  PCI (Peripheral) Configuration Library
  *  COPYRIGHT (c) 2011 Cobham Gaisler AB.
+ * are met:
diff --git a/cpukit/libpci/pci_cfg_print_code.c b/cpukit/libpci/pci_cfg_print_code.c
index e0979db74a..f1ffec4f2c 100644
--- a/cpukit/libpci/pci_cfg_print_code.c
+++ b/cpukit/libpci/pci_cfg_print_code.c
@@ -1,11 +1,30 @@
 /* PCI (Static) Configuration Library. PCI Configuration C code console
  * printout routines that can be used to build a static PCI configuration.
+ * are met:
diff --git a/cpukit/libpci/pci_cfg_read.c b/cpukit/libpci/pci_cfg_read.c
index 3cb6f86ae5..09e1aab6c4 100644
--- a/cpukit/libpci/pci_cfg_read.c
+++ b/cpukit/libpci/pci_cfg_read.c
@@ -1,11 +1,30 @@
 /*  Read current PCI configuration that bootloader or BIOS has already setup
  *  and initialize the PCI structures.
+ * are met:
diff --git a/cpukit/libpci/pci_cfg_static.c b/cpukit/libpci/pci_cfg_static.c
index c6b3820b8f..be933c1bd1 100644
--- a/cpukit/libpci/pci_cfg_static.c
+++ b/cpukit/libpci/pci_cfg_static.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/cpukit/libpci/pci_find.c b/cpukit/libpci/pci_find.c
index cd5eb7fa3b..abf2407eb1 100644
--- a/cpukit/libpci/pci_find.c
+++ b/cpukit/libpci/pci_find.c
@@ -1,10 +1,29 @@
 /*  PCI Help function, Find a PCI device by VENDOR/DEVICE ID
+ * are met:
 #include <pci.h>
diff --git a/cpukit/libpci/pci_find_dev.c b/cpukit/libpci/pci_find_dev.c
index a2e35301d1..81fd065585 100644
--- a/cpukit/libpci/pci_find_dev.c
+++ b/cpukit/libpci/pci_find_dev.c
@@ -1,10 +1,29 @@
+ * are met:
 #include <pci.h>
diff --git a/cpukit/libpci/pci_for_each.c b/cpukit/libpci/pci_for_each.c
index f3b877d38c..366e5dfb0b 100644
--- a/cpukit/libpci/pci_for_each.c
+++ b/cpukit/libpci/pci_for_each.c
@@ -1,10 +1,29 @@
 /*  PCI Help Function, iterate over all PCI devices. Find devices by cfg access.
+ * are met:
 #include <pci.h>
diff --git a/cpukit/libpci/pci_for_each_child.c b/cpukit/libpci/pci_for_each_child.c
index e5e33e44d6..9739e1000c 100644
--- a/cpukit/libpci/pci_for_each_child.c
+++ b/cpukit/libpci/pci_for_each_child.c
@@ -1,10 +1,29 @@
 /*  PCI Help function, iterate all PCI device children of PCI bus.
+ * are met:
diff --git a/cpukit/libpci/pci_for_each_dev.c b/cpukit/libpci/pci_for_each_dev.c
index 4cc6e63f3f..791a3b000d 100644
--- a/cpukit/libpci/pci_for_each_dev.c
+++ b/cpukit/libpci/pci_for_each_dev.c
@@ -1,10 +1,29 @@
 /*  PCI Help function, iterate all PCI devices.
+ * are met:
diff --git a/cpukit/libpci/pci_get_dev.c b/cpukit/libpci/pci_get_dev.c
index 0a0229fd06..647e9ca075 100644
--- a/cpukit/libpci/pci_get_dev.c
+++ b/cpukit/libpci/pci_get_dev.c
@@ -1,10 +1,29 @@
 /*  PCI Help function, Find a PCI device by BUS|SLOT|FUNCTION
+ * are met:
 #include <pci.h>
diff --git a/cpukit/libpci/pci_internal.h b/cpukit/libpci/pci_internal.h
index d0bb83ca14..7f34778776 100644
--- a/cpukit/libpci/pci_internal.h
+++ b/cpukit/libpci/pci_internal.h
@@ -1,10 +1,29 @@
 /* Private libpci declarations
  * COPYRIGHT (c) 2015 Cobham Gaisler AB.
+ * are met:
 /* Number of buses */
diff --git a/cpukit/libpci/pci_irq.c b/cpukit/libpci/pci_irq.c
index a3933b7701..f8f2b2af02 100644
--- a/cpukit/libpci/pci_irq.c
+++ b/cpukit/libpci/pci_irq.c
@@ -1,10 +1,29 @@
 /*  PCI IRQ Library
+ * are met:
 #include <pci.h>
diff --git a/cpukit/libpci/pci_print.c b/cpukit/libpci/pci_print.c
index 7c021d8df9..fe36359542 100644
--- a/cpukit/libpci/pci_print.c
+++ b/cpukit/libpci/pci_print.c
@@ -1,10 +1,29 @@
 /*  PCI Print Current Configuration To Terminal
+ * are met:
 #include <inttypes.h>
2.24.4
