[PATCH 11/26] cpukit/libtest: Change license to BSD-2
Fri Mar 18 16:21:18 UTC 2022
Updates #3053.
 cpukit/libtest/testbeginend.c  | 25 ++++++++++++++++++++++---
 cpukit/libtest/testbusy.c      | 25 ++++++++++++++++++++++---
 cpukit/libtest/testextension.c | 25 ++++++++++++++++++++++---
 cpukit/libtest/testparallel.c  | 25 ++++++++++++++++++++++---
 cpukit/libtest/testwrappers.c  | 25 ++++++++++++++++++++++---
 5 files changed, 110 insertions(+), 15 deletions(-)
diff --git a/cpukit/libtest/testbeginend.c b/cpukit/libtest/testbeginend.c
index 7d598e268f..6ff52d67c4 100644
--- a/cpukit/libtest/testbeginend.c
+++ b/cpukit/libtest/testbeginend.c
@@ -1,11 +1,30 @@
  * Copyright (c) 2014, 2018 embedded brains GmbH.  All rights reserved.
  * Copyright (c) 2017 Chris Johns <chrisj at rtems.org>. All rights reserved.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/cpukit/libtest/testbusy.c b/cpukit/libtest/testbusy.c
index c871c2f3a5..69fb34cb32 100644
--- a/cpukit/libtest/testbusy.c
+++ b/cpukit/libtest/testbusy.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/cpukit/libtest/testextension.c b/cpukit/libtest/testextension.c
index 1bd53ac47b..6bfe61eb0c 100644
--- a/cpukit/libtest/testextension.c
+++ b/cpukit/libtest/testextension.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/cpukit/libtest/testparallel.c b/cpukit/libtest/testparallel.c
index 18a343541b..d7a7068a35 100644
--- a/cpukit/libtest/testparallel.c
+++ b/cpukit/libtest/testparallel.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2013, 2016 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/cpukit/libtest/testwrappers.c b/cpukit/libtest/testwrappers.c
index 9679f75b6c..3c6e8fccc3 100644
--- a/cpukit/libtest/testwrappers.c
+++ b/cpukit/libtest/testwrappers.c
@@ -1,9 +1,28 @@
+ * are met:
2.24.4
