[PATCH 12/26] cpukit/libmisc/bspcmdline: Change license to BSD-2
Fri Mar 18 16:21:19 UTC 2022
Updates #3053.
 cpukit/libmisc/bspcmdline/bspcmdline_get.c    | 25 ++++++++++++++++---
 .../libmisc/bspcmdline/bspcmdline_getparam.c  | 25 ++++++++++++++++---
 .../bspcmdline/bspcmdline_getparamraw.c       | 25 ++++++++++++++++---
 .../bspcmdline/bspcmdline_getparamrhs.c       | 25 ++++++++++++++++---
 4 files changed, 88 insertions(+), 12 deletions(-)
diff --git a/cpukit/libmisc/bspcmdline/bspcmdline_get.c b/cpukit/libmisc/bspcmdline/bspcmdline_get.c
index 029cb6b8e6..f867e8b0d1 100644
--- a/cpukit/libmisc/bspcmdline/bspcmdline_get.c
+++ b/cpukit/libmisc/bspcmdline/bspcmdline_get.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
  *  COPYRIGHT (c) 1989-2009.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/cpukit/libmisc/bspcmdline/bspcmdline_getparam.c b/cpukit/libmisc/bspcmdline/bspcmdline_getparam.c
index f18773a49a..1920b3a98e 100644
--- a/cpukit/libmisc/bspcmdline/bspcmdline_getparam.c
+++ b/cpukit/libmisc/bspcmdline/bspcmdline_getparam.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c b/cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c
index db4a01aed3..833ddbccc2 100644
--- a/cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c
+++ b/cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c b/cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c
index aab5b02850..71fe4b6e60 100644
--- a/cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c
+++ b/cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
2.24.4
