xz_crc64.c not compiled
Chris Johns
chrisj at rtems.org
Fri Nov 4 23:05:20 UTC 2022
On 5/11/2022 6:46 am, Gedare Bloom wrote:
> On Fri, Nov 4, 2022 at 1:39 PM Joel Sherrill <joel at rtems.org> wrote:
>> On Fri, Nov 4, 2022, 2:37 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> Hi all,
>>> I don't see an entry in spec/build anywhere for xz_crc64.c
>>> From what I can tell it is not compiled/tested. I guess the
>>> This leads me to believe it is not compiled. And therefore is not
>>> being called or tested anywhere.
>>> Should it be compiled, or should it be removed?
>> What about in 5 and the autotools build system?
> It appears to be omitted from 5's cpukit/Makefile.am
> I don't see the code in 4.11. It was added by Chris to support untar
> of tgz files.
Sorry I do not recall why it was not added into the build. There are no
calls in the code to it.
