xz_crc64.c not compiled
Mon Nov 7 16:23:07 UTC 2022
On Fri, Nov 4, 2022 at 5:05 PM Chris Johns <chrisj at rtems.org> wrote:
> On 5/11/2022 6:46 am, Gedare Bloom wrote:
> > On Fri, Nov 4, 2022 at 1:39 PM Joel Sherrill <joel at rtems.org> wrote:
> >> On Fri, Nov 4, 2022, 2:37 PM Gedare Bloom <gedare at rtems.org> wrote:
> >>> Hi all,
> >>> I don't see an entry in spec/build anywhere for xz_crc64.c
> >>>  From what I can tell it is not compiled/tested. I guess the
> >>> This leads me to believe it is not compiled. And therefore is not
> >>> being called or tested anywhere.
> >>> Should it be compiled, or should it be removed?
> >> What about in 5 and the autotools build system?
> > It appears to be omitted from 5's cpukit/Makefile.am
> > I don't see the code in 4.11. It was added by Chris to support untar
> > of tgz files.
> Sorry I do not recall why it was not added into the build. There are no
> calls in the code to it.
I guess the question then is whether to add it to the build and write
a testsuite call to it, or to remove it from the tree.
