[PATCH] cpukit/include/dev/can: Disabled debug prints in CAN Framework
Gedare Bloom
gedare at rtems.org
Tue Nov 29 04:57:14 UTC 2022
Hi Prashanth,
On Mon, Nov 28, 2022 at 8:46 PM Prashanth S <fishesprashanth at gmail.com> wrote:
> cpukit/include/dev/can/can.h | 2 +-
> testsuites/libtests/can01/init.c | 14 ++++++++------
> 2 files changed, 9 insertions(+), 7 deletions(-)
> diff --git a/cpukit/include/dev/can/can.h b/cpukit/include/dev/can/can.h
> index 9e55395039..27afd00088 100644
> --- a/cpukit/include/dev/can/can.h
> +++ b/cpukit/include/dev/can/can.h
> @@ -53,7 +53,7 @@
> printf(str, ##__VA_ARGS__); \
> } while (false);
> -#define CAN_DEBUG(str, ...) DEBUG(str, ##__VA_ARGS__)
> +#define CAN_DEBUG(str, ...) //DEBUG(str, ##__VA_ARGS__)
This is not the right way to disable this, for several reasons.
I should have caught this DEBUG printing stuff earlier. My guess is
that you should just remove it all from the production code, or it
should be controlled at a higher level with -DDEBUG kind of flag.
However, I agree that the current implementation is overly verbose in
debug mode. I'd just strip it all out.
> #define CAN_DEBUG_BUF(str, ...) CAN_DEBUG(str, ##__VA_ARGS__)
> #define CAN_DEBUG_ISR(str, ...) CAN_DEBUG(str, ##__VA_ARGS__)
> #define CAN_DEBUG_LOCK(str, ...) CAN_DEBUG(str, ##__VA_ARGS__)
> diff --git a/testsuites/libtests/can01/init.c b/testsuites/libtests/can01/init.c
> index 0675fe606f..c19d45602e 100644
> --- a/testsuites/libtests/can01/init.c
> +++ b/testsuites/libtests/can01/init.c
> @@ -97,8 +97,10 @@ static void test_task(rtems_task_argument data)
> rtems_test_assert(fd >= 0);
> + printf("test_task %u\n", task_num);
> for (int i = 0; i < NUM_TEST_MSGS; i++) {
> - printf("test_task %u\n", task_num);
> + CAN_DEBUG("test_task %u\n", task_num);
> msg.id = task_num;
> //FIXME: Implement Test cases for other flags also.
There shouldn't be // comments anywhere.
> @@ -111,18 +113,18 @@ static void test_task(rtems_task_argument data)
> msg_size = ((char *)&msg.data[msg.len] - (char *)&msg);
> - printf("calling write task = %u\n", task_num);
> + CAN_DEBUG("calling write task = %u\n", task_num);
The general philosophy in our test suite is to only print something if
there's a failure. So just remove these debug statements that are
leftover from your development approach.
> count = write(fd, &msg, sizeof(msg));
> rtems_test_assert(count == msg_size);
> - printf("task = %u write count = %u\n", task_num, count);
> + CAN_DEBUG("task = %u write count = %u\n", task_num, count);
> - printf("calling read task = %u\n", task_num);
> + CAN_DEBUG("calling read task = %u\n", task_num);
> count = read(fd, &msg, sizeof(msg));
> rtems_test_assert(count > 0);
Since you send the messages, you know their sizes. You should be able
to assert the exact amount received?
> - printf("task = %u read count = %u\n", task_num, count);
> + CAN_DEBUG("task = %u read count = %u\n", task_num, count);
> - printf("received message\n");
> + CAN_DEBUG("received message\n");
> can_print_msg(&msg);
> sleep(1);
> 2.25.1
> devel mailing list
> devel at rtems.org
