[PATCH v2 06/13] score: Add CPU_THREAD_LOCAL_STORAGE_VARIANT
Fri Oct 7 04:33:52 UTC 2022
On 07.10.22 06:31, Chris Johns wrote:
> On 7/10/2022 3:23 pm, Sebastian Huber wrote:
>> On 07.10.22 05:44, Chris Johns wrote:
>>> On 6/10/2022 7:23 pm, Sebastian Huber wrote:
>>>> +#if CPU_THREAD_LOCAL_STORAGE_VARIANT == 10
>>>> +  tls_data = (void *)
>>>> +    RTEMS_ALIGN_UP( (uintptr_t) tls_area + sizeof( *tcb ), alignment );
>>>> +  tcb = (TLS_Thread_control_block *) ((char *) tls_data - sizeof( *tcb ));
>>>> +  return_value = tls_data;
>>>> +#elif CPU_THREAD_LOCAL_STORAGE_VARIANT == 11
>>>> +  tcb_size = RTEMS_ALIGN_UP( sizeof( *tcb ), alignment );
>>>> +    RTEMS_ALIGN_UP( (uintptr_t) tls_area + tcb_size, alignment );
>>>> +  tcb = (TLS_Thread_control_block *) ((char *) tls_data - tcb_size);
>>>> +  return_value = tcb;
>>>> +#elif CPU_THREAD_LOCAL_STORAGE_VARIANT == 20
>>>> +  alignment_2 = RTEMS_ALIGN_UP( alignment, CPU_SIZEOF_POINTER );
>>>> +  tls_area = (void *) RTEMS_ALIGN_UP( (uintptr_t) tls_area, alignment_2 );
>>>> +  size = _TLS_Get_size();
>>>> +    ((char *) tls_area + RTEMS_ALIGN_UP( size, alignment_2 ));
>>>> +  tls_data = (char *) tcb - RTEMS_ALIGN_UP( size, alignment );
>>>> +#else
>>>> +#error "unexpected CPU_THREAD_LOCAL_STORAGE_VARIANT value"
>>> What are the expected values? I can see 10, 11, 20.
>>> Can this please be changed to something readable? For example:
>>> #if CPU_THREAD_LOCAL_STORAGE_VARIANT == CPU_THREAD_LOCAL_STORAGE_BLAH
>>> #elif CPU_THREAD_LOCAL_STORAGE_VARIANT == CPU_THREAD_LOCAL_STORAGE_BLAH_BLAH
>> This is documented in the no_cpu/cpuimpl.h. I think the numbers are all right if
>> you know the TLS variants. Otherwise we would have to add an extra header file
>> just for the CPU_THREAD_LOCAL_STORAGE_* defines.
> Is the doco in this patch? I could not find it.
Yes, all the CPU port options are documented in the no_cpu port:
diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
b/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
index d5082383e8..72d223de24 100644
--- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
@@ -54,6 +54,24 @@
  #define CPU_PER_CPU_CONTROL_SIZE 0
+ * @brief Defines the thread-local storage (TLS) variant.
+ * Use one of the following values:
+ * 10: The architecture uses Variant I and the TLS offsets emitted by the
+ *     linker neglect the TCB (examples: nios2, m68k, microblaze, powerpc,
+ *     riscv).  The thread pointer directly references the thread-local
data
+ *     area.
+ * 11: The architecture uses Variant I and the TLS offsets emitted by the
+ *     linker take the TCB into account (examples: arm, aarch64).
+ *     The thread pointer references the TCB.
+ * 20: The architecture uses Variant II (examples: i386, sparc).
+#define CPU_THREAD_LOCAL_STORAGE_VARIANT 10
  #ifndef ASM
  #ifdef __cplusplus
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
