[PATCH 2/3] bsps/riscv: Add Microchip PolarFire SoC BSP variant
Padmarao.Begari at microchip.com Padmarao.Begari at microchip.com
Tue Sep 13 04:57:03 UTC 2022
Hi Sebastian,
On Mon, 2022-09-12 at 14:57 +0200, Sebastian Huber wrote:
> EXTERNAL EMAIL: Do not click links or open attachments unless you
> know the content is safe
> On 08/09/2022 17:43, Padmarao Begari wrote:
> > +++ b/bsps/riscv/riscv/clock/clockdrv.c
> > @@ -93,7 +93,7 @@ static void riscv_clock_at_tick(riscv_timecounter
> > *tc)
> >     volatile RISCV_CLINT_regs *clint;
> >     uint64_t value;
> > -  uint32_t cpu = rtems_scheduler_get_processor();
> > +  uint32_t cpu = rtems_scheduler_get_processor() +
> > RTEMS_BOOT_HARTID;
> Defines and functions starting with RTEMS_ or rtems_ should belong to
> the architecture-independent RTEMS API. This is specific to RISC-V,
> so
> it should be RISCV_BOOT_HARDID. I am not sure if your approach is
> correct.
Ok, will use 'RISCV_BOOT_HARDID'
> The numbers returned by rtems_scheduler_get_processor() (also known
> as
> _CPU_SMP_Get_current_processor()) should range from 0 to the
> configured
> (and available) processor count minus one. If your SoC has four
> processors then the valid numbers are 0, 1, 2, and 3. If the HARDIDs
> of
> your SoC range from 1 to n, then you have to map these HARDID numbers
> so
> that they start with 0 in _CPU_SMP_Get_current_processor().
> Another issue is if you boot from a processor other than 0 (as
> returned
> by _CPU_SMP_Get_current_processor()).
The function _CPU_SMP_Get_current_processor() returns in the range of 0
to configured processor count minus one for the PolarFire SoC HARTID's
1 to n.
Regards
Padmarao
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas
> Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
